Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 06-08-2016, 02:10 AM   #176
First c10
First c10's Avatar
Re: Project "Hulk Jr"
Front view
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 06-08-2016, 02:11 AM   #177
First c10
First c10's Avatar
Another outside picture
GO GO!!!
Old 06-08-2016, 10:19 AM   #178
First c10
First c10's Avatar
This is the valve adjusting procedure I used.
GO GO!!!
Old 06-08-2016, 03:40 PM   #179
First c10
First c10's Avatar
Here's a quick link of the rocker in action. Also my sons football buddies goofing around.
https://youtu.be/-BQd1aaoT6E
GO GO!!!
Old 06-08-2016, 06:05 PM   #180
Birdman72
First c10 have you been able to get in touch with anyone from fitech. I have tried for two days and no answer or returned phone call. I am having issues with there fuel command center but can't get any customer service
Birdman72 is offline   Reply With Quote
Old 06-08-2016, 06:59 PM   #181
First c10
First c10's Avatar
I haven't tried to because the last email I received from Jegs (which is who I ordered my stuff from) saying a ship date of 6/27/16. I did receive my FCC. I did see your post about having problems with fuel going out the vent on he fcc. I put a fuel gauge on my discharge side of my mechanical fuel pump to see the fuel pressure. I think the FCC only like less than 9 psi. It is basically just a big float bowl like on a Holley carb. I am concerned about them not contacting you or anyone else. As before I ordered I never had a problem with someone answering the phone every time I call.
GO GO!!!
Old 06-08-2016, 07:33 PM   #182
Birdman72
Ya I thought the same thing , press at there FCC is 7psi from my mechanical fuel pump. Man it is really frustrating not being able to get them to answer or return calls .They did reply to one email, all they said was vent has to be plumbed back to the tank. To me if that's the case I should just save the money and by a efi tank.
Old 06-08-2016, 07:52 PM   #183
First c10
First c10's Avatar
If fuel is coming out I bet you have something on/in the needle valve/seat. Did you check? It probably had debri in the tank from manufacturing. But I do get your frustration.
GO GO!!!
Old 06-08-2016, 09:44 PM   #184
Birdman72
Ya me and my dad discusses that, but are scared to take it apart for warranty. Are you going to run your vent all the way to tank. By the way you have some awesome builds love the hulk with ls motor.
Old 06-09-2016, 12:52 AM   #185
First c10
First c10's Avatar
Yes I installed a 1/4" line for a vent at the sending unit mount. Then I ran the line on the driver side to the front inner fender at the head light
GO GO!!!
Old 06-09-2016, 12:53 AM   #186
First c10
First c10's Avatar
Another view of the sender
GO GO!!!
Old 06-09-2016, 12:56 AM   #187
First c10
First c10's Avatar
Ran the line down beside the original fuel line
GO GO!!!
Old 06-09-2016, 01:02 AM   #188
First c10
First c10's Avatar
Thank you for checking out my builds I appreciate the comments. Having done a SBC and a LS. I will go the LS anytime. After I get Jr completed I will get back on the original hulk.
Also I understand stand about the warranty. But I am sure you will need to take the top off.
GO GO!!!
Old 06-09-2016, 07:45 AM   #189
Birdman72
Yes I believe I will have to so I can hopefully get my truck running.Man I sure was hopeing I didn't have to run vent to tank cause I relocated mine to back of truck.
Old 06-09-2016, 09:29 AM   #190
First c10
First c10's Avatar
I think you probably will have to run the line. I just bought brake line from the local parts store and used it as a return line.....like 20 bucks
GO GO!!!
Old 06-10-2016, 03:47 PM   #191
First c10
First c10's Avatar
Well the saga continues. I had a little whine in the transmission when I put it in gear. I took it to the transmission guy and he said sounds like a bad torque converter. But since he rebuilt it and sold me the converter he would do The work for free. Makes me mad as it is all in and fits nice and it has to come out. So now the truck is down for another week.
GO GO!!!
Old 06-10-2016, 04:36 PM   #192
DWilbur
That sucks. I have installed 4 transmissions in my Car in the last year the first 2 pumped oil out of the front seal just running the engine. The 3rd one slipped could hardly drive the car and all 3 came from TCI. The 4th one I bought from a local guy and it works great.
DWilbur is offline   Reply With Quote
Old 06-10-2016, 04:41 PM   #193
First c10
First c10's Avatar
yes I remember your car issue glad you got it going!!! .... but this truck has been full of crazy stupid issues...
GO GO!!!
Old 06-10-2016, 05:55 PM   #194
DWilbur
My car is a nightmare from hell. my plan is to restore it. every thing I touch is a battle. engine, transmission, rear end, I hope when I start the interior thing will smooth out. Good luck on your truck.
Old 06-11-2016, 01:19 PM   #195
7dee2
7dee2's Avatar
Wow, you've made a lot of progress this last month congratulations!
Suckie about the rocker arm I've never had a new one do that before. Do you think it was way out of adjustment?
I can say we have had our fair share of old ones break over the years. Thinking the factory stamped steel probably gets fatigued after a bazillion cycles.
Also double suckie on the trans good thing you have the crew eager to help fix this new issue.
Keep up the fight it's going be a sweetheart in the end!
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 06-11-2016, 03:32 PM   #196
First c10
First c10's Avatar
Thanks Brett nice to see you are back.
I think the rockers were junk and that is why they discontinued them but a nice set of roller rockers was pretty go trade.... as for the trans I am just worried about how they will remove it and reinstall....I am torn between should I remove it or just let them. My son gets his license by July so would love to have it up and running. yesterday I drove it the farthest about 4 miles around town and it rode and felt great. Brake and steering were better than the C10 but don't tell my other son!!!
GO GO!!!
Old 06-12-2016, 01:33 AM   #197
swamp rat
swamp rat's Avatar
Sorry to hear about yet another setback, i feel the pain. If ya trust the shop and can afford it let them do it.
Whats this? i haven't even seen a pic of your truck put together and your driving it? I musta missed something..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 06-12-2016, 04:58 PM   #198
First c10
First c10's Avatar
Hey mike. I am going to let the shop do it since he said he would do it for free. He said it may even be the pressure regulator but that he was just going to replace it when he has it apart.
Can you not view the pictures of the truck assembled with tires and wheels on it? Only a couple but there are some. Just dark as it was night when we pulled it out of the shop. More to come.
GO GO!!!
Old 06-12-2016, 11:48 PM   #199
swamp rat
swamp rat's Avatar
Showing up today!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 06-13-2016, 10:44 AM   #200
7dee2
7dee2's Avatar
Hey free is good, I like free! It's great your guy is standing behind his work and you trusted him to build it so I'm sure he'll do a great job on the R&R. The wheels and tires look sharp on JR.
Brett
