05-12-2017, 06:31 PM | #176 |
Re: Introduction, nostalgia, and '68 build, oh my
It is actually 20th if anybody else is interested. I understand how it goes. I really hope one of these fine days I'll be driving my ole pickup to the show and not just working. Lol. I think if you keep at it you'll do good.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
05-19-2017, 08:05 AM | #177 |
And the results are in: The timing set WAS changed, but the pan was never pulled. After pulling everything apart I discovered a scored damper and mangled bottom edge of the timing cover that were both contributing to my oil leak, a very loose timing chain, and a "custom" grooved cam gear! Overall I'm glad I decided to inspect this stuff because it all needed attention.
Fortunately, I finally reached the end of the parts destruction and started reassembly. Ultimately, I had to replace the rear main seal, oil pump (Melling M55), pan gasket, timing set (Cloyes 3001K), and rework the timing cover, but the bottom end should be sealed up nicely now. I also noticed that my truck has entered the stage of the project where it begins to be absorbed by it's surroundings and become a place for additional storage in the garage. At least it's still getting used as a truck I suppose... And lastly, some fitment motivation. While the truck's up on stands, I somewhat mocked up where the rear will be once I finally add in the drop blocks. Even with only 4" backspace on the 9" wide rears, I still think they are tucked a little too deep. I'd really love to throw the wider rear end in there with the 6 lugs from '69, but for the meantime I am going to put in some longer studs (Moser 7/16-20 x 2 7/8") and 1/2" spacers. I ran spacers for years on my Malibu, and with the Moser studs I think I'll be alright. I don't beat on this truck anywhere near what I did to my Malibu. Next up is getting the transmission reassembled and installed. I hope to have that done within the next month. Then maybe I can actually get back to painting the bed.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
05-19-2017, 02:08 PM | #178 |
My schedule cleared up for this weekend and I think I will try to make it out to the show (without the truck of course). I was going to go to the VW show at Farmington Dragway, but since I've sold my Beetle and have moved on to the truck, I think I'd prefer to attend this show. Where will you be working at the show?
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread Last edited by hewittca; 05-19-2017 at 02:16 PM. |
05-19-2017, 03:33 PM | #179 | |
As for the rear wheel being too far in, it looks good from the pic posted (and I am picky about it). It could be the angle but again, looks right to me. On the 'wider' 69/later 6-lug housing... Seemed the change to the wider housing happened sometime in 70. That's where there were 2 different length 6-lug housings. Measure the distance between the backing plate & T/A perch on your current housing to ensure you're getting a longer one if you go shopping around.
05-19-2017, 05:15 PM | #180 |
PM sent
05-19-2017, 06:01 PM | #181 | |
do you have this guys contact info? i would be VERY interested in a set of transits in 5 lug |
05-19-2017, 08:57 PM | #182 | |
05-20-2017, 06:46 PM | #183 |
It was great meeting you today. I wish it would have been a little cooler. A few more trucks did show up. This year seemed to be off. I feel the heat and the race down in Charolette may had something to do with it. Either way we still had fun and saw some cool stuff.
05-21-2017, 07:22 PM | #184 | |
05-26-2017, 08:26 PM | #185 |
I have updated my build thread title to "Green Gus the 68 shortbed convert" to better reflect my build, but for some reason it got added as a duplicate copy. I will no longer post updates in this thread even though it still exists. Please follow the photo link below to continue the build progress!
