11-20-2017, 11:58 AM | #176 |
Re: 1972 Blazer CST Frame off Project in NC
Thanks for the support and kind words! It’s at this point in the project you ask yourself ‘why am I doing this again?!?!?!?!?’.
I bought the wiper transmission (what they called it) from Southern Kentucky Classics. The original was toast. I bought the wipers, motor, etc from GMCPaul’s. He always seems to have the ‘best’ of the repop stuff. The taillight/marker light bezels came from All American Billet. Please don’t tease me about (or tell my wife) what I paid for them! They do look great though and saved LOTS of holes in new metal/fresh paint. |
11-20-2017, 01:34 PM | #177 |
Like Jim, I am also interested in hearing about the taillight bezels. Those look different than what I have seen.
BR549 |
11-20-2017, 07:48 PM | #178 |
That price isn't as bad as I expected, my fittings and hose were way more
Thanks for the help, maybe they will end up under the tree
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
11-20-2017, 08:19 PM | #179 |
Yeah. I’ve spent more on less too. But at $300 ish for taillights and markers, it’s spendy when the stock ones are less than $75 or so. They just look so good!
11-21-2017, 10:54 PM | #180 |
Carpe manana
Great to see an update. Progress looks great!
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
01-28-2018, 05:30 PM | #181 |
Hey guys - Been busy between Thanksgiving and now tidying up stuff all over the Blazer. Finished all the underhood wiring, got the core support on, radiator, fans, gauges, steering wheel and tons of little stuff. Here are a few pics:
01-28-2018, 05:53 PM | #182 |
All that, to get to this - as of 1:15 pm today, S H E ' S A L I V E ! ! ! !
https://youtu.be/4BtYSYDt0pM |
01-28-2018, 07:26 PM | #183 |
That is quite the milestone, great work. I wouldn't know, but that must feel good. LOL
She's a beaut
01-28-2018, 08:59 PM | #184 |
I'm trying....
Congrats. No small feat. Continues to look great...super clean.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
01-28-2018, 09:49 PM | #185 |
Thanks guys - it does feel awesome. I finally feel like I am on the down hill side now!
So, here is what got added to the list after letting the engine run in a bit today: 1) Temp Gauge is slamming all the way to the far right (past H) when the key is turned. Bad ground maybe? 2) Tranny hard cooling line (top on, the pressure side, TH350) is leaking at the line nut and fitting to the case. Anyone know an easy source for the case fitting? After searching, I found various descriptions of what size it is. 1/4 NPT, NPTS, tapered, straight, etc. I just need one. Bottom one is fine. It seemed buggered when I hooked up about 45 days ago - kicking myself for not changing it then. I hate the smell of ATF. Ha! 3) My Accel ceramic 8mm plug wires that are designed to fit this engine DON'T. I'll trim them all to fit - just another chore. Honestly, if that's I have to fuss about for the first start, I'm in good shape! |
01-28-2018, 10:25 PM | #186 | |
2) NPT tapered will pull fitting into trans, sealing better. Maybe a little thread sealant, but skip the first couple threads, so it doesn't go inside trans. Plus ATF is flammable
03-19-2018, 11:11 AM | #187 |
Ok guys - Been super busy solving problems, assembling (and reassembling) things and trying to get this truck ready for a Spring ride!
I solved my trans cooling line by replacing the fittings on both the trans and the cooler line - - problem solved. I solved my temp gauge issue by following TBONE1964's suggestion at the bottom of the this response - Thanks Tom! Fixing the spark plug wires just took a little time, but I got that accomplished too. Temp Gauge Solution From Tom: Try and run a ground wire from the lower center stud on the temp gauge to a known good ground. This is a very common problem when a temp gauge has been removed from the tin in the past. There is usually a small retainer on the lower center stud that provides a ground though the tin and gauge. When the retainer is removed, there is no ground. That is what the ground wire I am suggesting will fix. |
03-19-2018, 11:26 AM | #188 |
I found a fuel leak around the pressure regulator and needed to replumb it - helps when you read the instructions and use Teflon paste on the NPT threads (duh), so I re ran it more efficiently and added a pressure gauge.
I hooked up the kickdown cable and installed the Lokar custom throttle cable - just couldn't get the stock one to fit the curvature that was needed. I also had to add a 3/4 spacer between the carb and air cleaner to get proper clearance for the throttle return springs. Here are some pics |
03-19-2018, 11:40 AM | #189 |
I had many other odds and ends to do - hook up vacuum lines, run some under hood wiring, get the ignition box and coil wired in permanently - basically finish up anything that would be hard to reach after the fenders were on, then I installed the inner fenders. While I was waiting for some help hanging the fenders, I went to work on window felts so I could finish up the doors. Nothing ever goes easily, but the folks at Precision weatherstriping were awesome and took pictures for me and drew in arrows so I knew exactly how they installed. Turns out my problem was that my repop doors had one slot not cut out, so I had to get creative and make it work.
The Precision folks told me that would be making a video within the next 30 days for this product and our trucks - so go to their site - or let me know and I can share their pics they sent me. The door panels went on easily enough - and these are one of the FEW originals pieces that have made it this far. It took a TON of cleaning, but these are the original 46 year old panels. They look SO much better that the repops. I also finally put the dash pad on - - - so stupid. I thought I was being smart to not put the pad on till late in the game. That should have been the FIRST thing I put on the dash. Was a HUGE pain getting to the bolts to tighten it down, AND I had to take the glove box out to reach many of them. Ugh. More pics: |
03-19-2018, 11:47 AM | #190 |
And the last photo update for awhile.
Fenders on! And a quick peek at my buddy Richie who did all the painting. First fender took us 2 hours to hang, second one about an hour. Next pic is after I got the front marker lights in and working - and the 383 badge I wanted so badly. Subtle, but awesome and worth the search, price, etc. Last pic is of the puke jug installed - thanks to Wes at Classic Heartbeat for the advice and sourcing of that one. You can also see where I mounted the MSD ignition box. I really started to put it on the firewall, but MSD suggested a horizontal mounting, not vertical. I am slowly learning to listen to the advice of people who actually make the stuff! Oh - and these are original hood springs, rebuilt (re-revitted and painted) from a shop in Va. I've heard nothing good about the repops. |
03-19-2018, 11:50 AM | #191 |
Now that I have paid the photo toll - does anyone have a source for front seat belts? I don't have the stock ones that came with it.
Rears are easy, but I am struggling to find front retractors in black. I need both passenger and drivers side - and would appreciate what others have done to figure out how to solve this. Thanks guys! |
03-19-2018, 05:31 PM | #192 |
Can you post some more detail pics of your 8-383 badge? Any info on them you can provide?
03-19-2018, 08:58 PM | #193 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=701118 |
03-21-2018, 09:50 PM | #194 | |
http://www.pythonrestoration.com/
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
03-21-2018, 10:08 PM | #195 | |
03-22-2018, 02:37 AM | #196 |
I need to have my parchment belts restored. I'm thinking about going to python restorations. Would you mind letting me know how your belts turned out when done?
03-22-2018, 07:42 AM | #197 |
Absolutely, I will start a whole new thread once I get the seat belts back. I've been told that Stewart does amazing work and I can't wait to see the results.
03-22-2018, 08:08 PM | #198 | |
And thank you too 2006gmcdmax |
03-22-2018, 08:15 PM | #199 |
03-25-2018, 07:41 PM | #200 |
Today was hood, cowl and tailgate day. Took about 3 hours, but only because I started having issues with the driver's door and the way it closes. The tailgate fits really well, the hood still need some tweaks - but the door has become the new problem. Can be fixed, will just take some time. As usual, 2 steps forward and 3 steps to the side.
