Old 07-29-2019, 05:09 PM   #176
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: 1971 Stepside LS Build
FYI -- I am going to mock the whole truck up and then going to disassemble for all the paint. My gut says if I painted everything ahead of time I would be needing to cut and weld something already painted. With that being said you are way ahead of me.
Mine is going back on the frame one last time to do a final fit before it gets paint. I was planning my last removal to be it, but I have gone this far I might as well check it one more time
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 07-29-2019, 09:36 PM   #177
bikertim
No doubt, it looks great now but all it takes is one thing!
bikertim is offline   Reply With Quote
Old 08-05-2019, 10:36 AM   #178
1971Stepside
Almost Satisfied
Didn't make near the progress that I had hoped for this weekend. I did get all the surface rust cleaned off the bottom of the cab and it sealed it up. One more test fit coming up and then a little CRE Epoxy.
Old 08-05-2019, 11:07 AM   #179
TA_C10
TA_C10's Avatar
Progress is progress, looking good! Is that POR15?
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 08-05-2019, 11:35 AM   #180
MDPotter
MDPotter's Avatar
I know the feeling. But like TA said, progress is progress. It's never quick enough!
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 08-05-2019, 02:59 PM   #181
1971Stepside
Almost Satisfied
Well, I call it RichMan15 at $50 a quart
Agreed. I spend the first 10 minutes sanding off surface rust that formed since my last round. Hopefully we can get the primer down soon. It's so rainy and humid here that even in an ac garage it is fun to keep it off.
Old 08-05-2019, 04:50 PM   #182
MDPotter
MDPotter's Avatar
[QUOTE=1971Stepside;8571079]Well, I call it RichMan15 at $50 a quart
I use Chassis Saver, it's the same as POR15 but cheaper. I buy it from Amazon and they have a couple different sheens. I've used it on all of my frame components and it is nasty to work with, but incredibly tough.
Old 08-06-2019, 12:50 PM   #183
beaterku
beaterku's Avatar
Looking good! This humidity has been down right oppressive.
beaterku is offline   Reply With Quote
Old 08-14-2019, 05:41 AM   #184
my kids toy
Nice build, I have not read all of it yet but I want to comment on the cold case rad, I am shocked to hear about what they did to you , I purchased mine a year ago and I complained about the steam port problem back then and they should have fixed it then but I see they did not and they went ahead and still shipped off the stock they had on hand, shame on them for thinking it would be OK.
I have a Holley pump set up and it had the steam port in the pump so I cut the steam port off the rad and welded the hole shut to make it work.
You made a nice rad mount for the cold case , would you like to sell it to me ?
my kids toy is offline   Reply With Quote
Old 08-14-2019, 09:25 AM   #185
1971Stepside
Almost Satisfied
I think I have $22 in it. How about $20 and you pay for the ride? Glad to help out. I need to fab something similar for my Entropy. PM me your address and I will get a quote on what shipping is.
Thanks for the compliments on the build.
Old 08-14-2019, 07:16 PM   #186
my kids toy
Message sent
Old 08-16-2019, 09:39 AM   #187
Flubyu
Project is looking great, I need to come check it out!
'71 C-10 SWB Shop Truck
Currently 350/350, soon to be LS'd.
Flubyu is offline   Reply With Quote
Old 08-17-2019, 06:08 AM   #188
my kids toy
I sent message but did not hear back from you incase you replied.
Old 08-19-2019, 11:12 AM   #189
1971Stepside
Almost Satisfied
Let me know when you would like to see it. Hoping to have the primer on and doing the final test fit by Labor Day.
I sent you a message.
Old 08-26-2019, 09:59 AM   #190
1971Stepside
Almost Satisfied
Got some time out in the garage this weekend. Had a little help sanding which was really cool. While the boys were inside playing video games the girls came out and worked on the truck.
Planning to put some primer on her this week and start re-test fitting all panels for final prep.
I also worked on the tailgate a little by installing these so called hidden latches. They need more work. I'm not sure I really like them, but I haven't seen better options for the stepside gates. Hopefully once it is all painted I will like it better.
Old 08-26-2019, 10:05 AM   #191
MDPotter
MDPotter's Avatar
My hat's off to you for having the ability to get the ladies in your house to sand on your truck!
Old 08-26-2019, 01:06 PM   #192
67C10GS
67C10GS's Avatar
subbed for the amazing info, cant wait to see it finished.
1967 GMC C15 sb 6.0 lq4 pro daily. Named the “formula 10”
67C10GS is offline   Reply With Quote
Old 08-26-2019, 04:55 PM   #193
TA_C10
TA_C10's Avatar
Interesting. Do those slide metal on metal or is there a bushing of some kind that will keep them free sliding for many years down the road?
"It's only money".
Old 08-26-2019, 05:00 PM   #194
1971Stepside
Almost Satisfied
They are designed to be greased. The pin holds the whole thing in place so if you ever need to re-grease it you can simply unscrew the pin lever and lube it up. The newer versions of these have a chrome knob instead of the lever pin. I'm going to shorten these and see if they will work. Going to paint it all and hope they aren't super noticeable.
Old 09-03-2019, 10:08 AM   #195
1971Stepside
Almost Satisfied
Finally got her loaded and to the body shop so we can use a booth. Hope to get primer sprayed sometime in the next week depending on their schedule and when I can jump in.
Started the preliminary body work on the bed. It is mostly new, so not a whole lot to do. I cut the side marker out of the passenger fender because at one point I was going to remove them all. I have now decided to keep them, so I have to weld it back in. One step forward...two steps back.
Old 09-03-2019, 10:10 AM   #196
MDPotter
MDPotter's Avatar
That's exciting! I've only spent about 3 hours sanding on my cab so far and I already hate it.
Old 09-03-2019, 10:14 AM   #197
beaterku
beaterku's Avatar
Looks great! I did body work and paint "one" time. I apparently was not blessed with the patience to do body work. I get way to frustrated way to fast. Another step closer!
Old 09-03-2019, 10:24 PM   #198
TA_C10
TA_C10's Avatar
Lol, all this sounds like the hell I went through and didn't realize it till you guys say it in writing... I'm crackin up. That is exciting stepside, hope it goes quickly for you man.
"It's only money".
Old 09-05-2019, 09:28 AM   #199
1971Stepside
Almost Satisfied
Long night, but we got three coats of epoxy down. Will have to flip the panels and do the other side tonight. Should be able to start test fitting panels this weekend. Overall, was pretty happy with my initial filler work. Found several spots on the back of the cab that will need more work when blocking. Was exciting to see it back in one color and looking fairly straight. Couldn't go to sleep last night after getting home...maybe it was the paint fumes
Old 09-05-2019, 10:30 AM   #200
67C10GS
67C10GS's Avatar
im dreading the day my project gets to the point of bodywork, but i take solace in knowing plenty of people have walked the tedious path of body and paint and that countless more will follow me.
