12-01-2021, 10:08 AM | #176 |
Re: 1950 Chevy 3600 Woody R
ahh, we’ll be using a Vintage Air gen II compac. The lines will run under the inner fender (I’m welding a custom strap to the backside to hold them) and exit right by the compressor. The #6 runs along the inside of the inner all the way to the front.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
12-01-2021, 10:10 AM | #177 |
Thanks. When you get that far, please post pictures, especially the bracket you are making.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
12-01-2021, 10:12 AM | #178 |
You know I will buddy!
12-01-2021, 09:41 PM | #179 |
The 3x10 u bolts I ordered turned out to be 3.5x10,so I had to buy new ones at Autozone tonight
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 12-02-2021 at 11:27 AM. |
12-01-2021, 09:43 PM | #180 |
we got the transmission crossmember complete today
And photographic proof that the frame is fully painted Tomorrow we build the motor mounts and finish up those AC lines to get after bodywork, I’m hoping to have the cab in paint before the new year
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 12-02-2021 at 11:26 AM. |
12-02-2021, 09:34 AM | #181 |
In paint, now that's moving along!
12-02-2021, 10:32 AM | #182 |
That’s the goal
12-02-2021, 11:02 PM | #183 |
We got the correct U-bolts installed today and put in the rear shocks
Looks pretty good next we started building motor mounts
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 12-03-2021 at 11:28 AM. |
12-02-2021, 11:04 PM | #184 |
Then we put it on the ground to check out the new stance!
Looks much better lower!
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 12-03-2021 at 11:27 AM. |
12-03-2021, 09:43 AM | #185 |
That looks great.
I missed it earlier, what bracket is that on the LS? It looks wide, does it fit or will the inner fenders need some custom work?
12-03-2021, 10:02 AM | #186 |
The bracket fits in the inners. It’s an ICT billet bracket
12-03-2021, 10:08 AM | #187 |
Thank you.
12-03-2021, 09:09 PM | #188 |
Today we built the motor mounts and put the new 10.5mm plug wires on
Then we put the motor in the chassis for the final time! Next week we start getting it ready to run and buttoning up bodywork on the cab
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 12-04-2021 at 11:03 AM. |
12-06-2021, 11:06 PM | #189 |
We took out a dent along the beltline. It was a PITA!
Next we finished up the AC hoses And buttened up the passenger cowl. We did cut an access hole in the kick panel which we’ll cover it when we do the interior.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 12-07-2021 at 10:56 AM. |
12-07-2021, 09:22 AM | #190 |
Do you have some type of grommet around the hoses where they go into the kick panel? It looks like you drilled a hole with a hole saw.
12-07-2021, 10:10 AM | #191 |
yes, the grommet we ordered didn’t work, so we wound up lining the hole with door edge guard
12-07-2021, 11:08 PM | #192 |
Some of the bodywork done before us was not to hot. So as a result the metal got really thin and wavy near the edge. When we ground down our welds it burned through in a couple places. we will use Duraglass (fiberglass hair impregnated filler) to try to rebuild the door opening
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 12-08-2021 at 11:19 AM. |
12-07-2021, 11:12 PM | #193 |
Next we ground everything smooth
we did some work to the beltline and A-pillar Sanded down the left cowl And applied the first coat of filler to the right
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 12-08-2021 at 11:20 AM. |
12-07-2021, 11:16 PM | #194 |
nice work man!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
12-08-2021, 01:08 AM | #195 |
Thanks joedoe!
12-08-2021, 01:14 AM | #196 |
What kinda paint is that blue? Looks great.
12-08-2021, 01:20 AM | #197 |
That sucks about the door opening edge. Are you using a flap disc? I find them great for rough work but they flex a bunch so around an edge or a body line you gotta be real careful. Same when grinding the high spots off a weld, it's easy to also bring the surrounding sheet metal and then you have a thin spot. They heat the metal up around the weld you are grinding down and it oil cans a bit so the surrounding sheet metal is easy to find itself high and get flap disced a bit.
12-08-2021, 01:31 AM | #198 |
That’s Hot Rod Flatz "speed blue” we did use a flap, I think the Duraglass will do the trick
12-09-2021, 10:33 AM | #199 |
so today was all about getting the engine ready to run
we cleaned and installed the valley cover and knock sensor harness Then we construct an AN line and installed AN adapters for the high pressure power steering line And we installed the ETC
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 12-09-2021 at 10:40 AM. |
12-09-2021, 10:34 AM | #200 |
Then we built the exhaust back to the muffler
And bolted down the intake
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by Rickysnickers; 12-09-2021 at 10:41 AM. |
