Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 01-16-2013, 10:35 PM   #1976
bk04z66
Re: PO has me PO'd
Cool build, TPI's are really well suited for trucks, I have installed several of them for myself and friends and been happy overall.
bk04z66 is offline   Reply With Quote
Old 01-17-2013, 02:15 PM   #1977
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Just filling in some slack time, waiting on the 1" isolation blocks to come in from cavan@service rubber.com. He sent them out n/c! Promised him i would give him a plug, really good guy and into old cars and trucks.
Anyway, thought i would build on dale99's idea of mounting the coil on the cowl. Took the factory coil mount that belongs on the intake and cut it to fit the coil. Still have to make someside mounts to equalize the weight
Thanks bk04 for looking, and i agree the TPI should be a good fit for our trucks
20130117_125853 by jarosaj, on Flickr
20130117_125955 by jarosaj, on Flickr
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-17-2013, 02:43 PM   #1978
Dale99
Re: PO has me PO'd
ahh, you were missing part of the bracket system. But that works as well.
Dale99 is offline   Reply With Quote
Old 01-17-2013, 03:06 PM   #1979
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Yeah, that and the fact the mounting holes didnt line up with my vortec intake, or i did something wrong which is possible
I may continue the cut further, to get more of the coil weight further into the bracket, dunno
SAFETY FIRST
AS usual, off topic
Jim
Old 01-17-2013, 03:57 PM   #1980
bk04z66
Re: PO has me PO'd
What made you run a crank trigger insead of using a small cap GM distributer?
Old 01-17-2013, 05:05 PM   #1981
Dale99
Re: PO has me PO'd
Nope, standard sbc bolt pattern, and vortec pattern is different.
Old 01-21-2013, 09:45 PM   #1982
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
EDIT
Sorry bk 04, didnt notice you slipped that question in there...in the future, i will be building a higher hp engine, and was told it will give me a more accurate signal, since i was doing all the modifying of the wire harness, just thought it was a good time to upgrade
I have the dual sync distributor, which allows me to run sequential injector timing instead of bank to bank. Bank to bank would fire twice, which would put unused fuel in the combustion chamber, so sequential would put fuel in only when firing the plug.
Timing is controlled by the cam and crank position
SAFETY FIRST
AS usual, off topic
Jim
Old 01-21-2013, 10:44 PM   #1983
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Got alittle progress on my day off...
20130121_211610 by jarosaj, on Flickr
20130121_210101 by jarosaj, on Flickr
20130121_205218 by jarosaj, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 01-21-2013, 10:58 PM   #1984
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Changed the mounting of the igntion box somewhat, since it was going on the inner fender well, i needed a little clearance for the double curvature. Used the isolater mounts on the bracket instead of the box, gives me alittle better then a 1/4" clearance all the way around
20130121_120916 by jarosaj, on Flickr
20130121_121100 by jarosaj, on Flickr
20130121_121442 by jarosaj, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 01-21-2013, 11:04 PM   #1985
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Moved my oem engine harness to the right side of the firewall, then down and across the bellhousing, trying to keep the high voltage wires away from the injector harness and sensors
20130121_121547 by jarosaj, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 01-27-2013, 01:03 AM   #1986
dujobu
Re: PO has me PO'd
Hey Jim. Are you getting my PMs? I'm getting the feeling you may not be. Let me know.
dujobu is offline   Reply With Quote
Old 01-27-2013, 11:21 AM   #1987
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Sorry, just got to wrapped up in my build to reply. This wiring has all my attention. Cut the oem engine harness apart, to bring the wires down the drivers side of the engine, and run power wires for the ignition box
This nerve racking, trying to mount a non oem part, but still have a pleasing overall look. I hope they look good where i placed them
Plan to contact M&H to see if they will sell me a full piece of channel to hide the wiring harness going across the firewall
Bought the other half of my coil connector from TPI Parts, now just have to splice in the double connector
Orange and Black go to the coil
Red goes to 12 volt switched
White goes to points wire in the fast harness
Grey goes to the tach lead
Yellow has voltage off of pink, and goes to starter solenoid
SAFETY FIRST
AS usual, off topic
Jim
Old 01-27-2013, 11:39 AM   #1988
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
20130127_102211 by jarosaj, on Flickr
20130127_102354 by jarosaj, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 03-09-2013, 03:10 AM   #1989
Captainfab
60-66 Nut
Re: PO has me PO'd
Any updates in the last month?
Old 03-10-2013, 10:17 AM   #1990
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Well sorta, had a couple set backs.....
Took a winter vacation with the wifey, flew into Clearwater Fla., rented a conv. Camaro, and cruised the Gulf Coast
MSD set back. Wanted to extend the coil wires, but after numerous attempts couldnt get the right terminal for the ignition box. MSD was no help, they couldnt identify the terminal i needed, so they just sent me another complete cable assembly. Solved the problem by running coil wires to another location.
Coil had to be moved since it hit the distr. Speciality Retail hooked me up with a fender lug that imounted on the firewall for switched 12 volt pink
20130308_141640 by jarosaj, on Flickr
Wires that still need to be spliced...pink w/ black tracer goes to orange, and white goes to black on the coil.
I wanted to keep the colors(orange and black) but, one of the coil connectors was molded together, so i couldnt take it apart to change the wires
Ill keep looking for a connector that i can take apart
Grey tach wires get spliced together
Red wire, plus red wire from the distr. get tied into the switched pink lug. I split the original engine harness to run the 12 volt wires away from the sensor wires at the back of the engine. Pinks have to be tied together, since the smaller pink supplies power to the headlight harness
SAFETY FIRST
AS usual, off topic
Jim
Old 03-10-2013, 10:22 AM   #1991
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Ignition box is all wired up, with the exception of the white points wire going back into the harness under dash. Keep this wire away from power, cant help that it is going into ignition box connector. Noise being the biggest factor here
Red power wires are going to the starter lug, ground located at a good source in the starter area, as recommended by fast. Not going to the battery
20130224_104047 by jarosaj, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 03-10-2013, 10:29 AM   #1992
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Found a descreet source for power and ground, as recommended by FAST. These wires CAN NOT go into lugs, or any other source of power other then the battery. So, i am using the side posts
20130309_115711 by jarosaj, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 03-10-2013, 10:36 AM   #1993
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
My son fixed my intake, used a 3" fly cutter, and did a plunge cut to get the clearance on the waterneck. He only had to cut about a 1/32", amazingly that was enough to cause problems
20130308_143341 by jarosaj, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 03-10-2013, 10:44 AM   #1994
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Last area that im still working on is the cam/hall connector, some changes has to be done in this area since i am using a crank trigger
20130308_141856 by jarosaj, on Flickr
Screenshot_2013-03-08-14-22-37 by jarosaj, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 03-10-2013, 12:52 PM   #1995
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Re: PO has me PO'd
Guess I haven't been paying attention, just saw the posts about adding the TPI. You'll be really happy with it J. I love the one in the 71. As usual, you are going whole hog! I just bought my setup with a Speed Density upgrade and went with all the stock electronics. Can't wait to see you get this thing running!
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 03-11-2013, 02:07 PM   #1996
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks Red,.....yeah, i was trying to get your input, thought i would get better product support if i bought one that has a forum, plus techies available. They have been invalueable so far!
Ran the ground wire today, went through the fender and the inner fender to try and hide it somewhat
url=http://www.flickr.com/photos/87678561@N08/8549763746/][/url]
20130311_140100 by jarosaj, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 03-11-2013, 09:31 PM   #1997
red71cheyenne
Back in the sticks
Re: PO has me PO'd
Good call, I did the same thing, went with someone that had a lot of stuff out there and it really helped when I had tech issues or part return issues.
2011 K1500 Suburban
2014 K1500 Pickup
Old 06-26-2013, 10:37 AM   #1998
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
A liitle update...had some medical issues over the last few months. Plantar Faciitus has keptme on the couch in a cast. Blood work, MRA and MRI indicated that ive had four strokes over a period of time, which explains the numbness in the right hand. Tend to drop things, as long as i dont drop a bolt down the intake, i should be ok
Working on the fuel system, since all the sensers are wired, and power to the ECU are completed. Found an in tank fuel pump from a 2002 f body at Racetronics, after i bought it, i found out that a truck version of the same year would have worked without mods. Our tanks are about 13" deep, so i had to extend the 3 tubes in the pump to accommadate this demension. Waiting on the new tank from brothers to arrive.....keeping the oem sending unit, and adding pump to another location behind it
Kinda got a little ahead of myself, and had to redo the power harness running to the battery, since i had to add in the harness for the fuel pump, and relays. Using tubing and proclassic hose as recommended by JJH Jimmy, still waiting for fittings to arrive from Jegs
Bought a Camero fuel rail, JBClassic, to get my fuel lines headed towards the drivers side, plus, i was able to combine the corvette fuel rail to eliminate the ninth injecter
One of the tubes has been modified(return line) the other two support rods havent been done. Fuel pump comes apart relatively easy. Also, you have to extend the power harness, inside the upper pump housing and basket (harness removed, and not shown in pic)
20130619_113515 by jarosaj, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 06-26-2013, 11:10 AM   #1999
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
20130619_102104 by jarosaj, on Flickr
If you cut the two flares on the support rods, the two halves can be separated. Just release the two snap tangs on the fuel basket first
Parts required: three pieces of 1/4" ss tubing about 9" long, and 3 compression splices
SAFETY FIRST
AS usual, off topic
Jim
Old 06-26-2013, 11:21 AM   #2000
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
20130626_105856 by jarosaj, on Flickr
Camero fuel rails mounted
SAFETY FIRST
AS usual, off topic
Jim
