03-08-2020, 04:56 PM | #2101 |
Re: How to: Ruin a perfectly good C10
Really like the truck Chris. U went thru several changes with the truck along the way. Thanks 4 a few ideas I have for mine. My question to u is the holley injection u have. Knowing u are more than stock, do u think /feel the single plane design is giving something up to the ls truck/car intakes down low? There isnt alot out there that i can find on this. The few articles I have read have the motor in more race than street trim. Just wanted ur thoughts.
03-08-2020, 11:31 PM | #2102 |
A guy with a truck
Working on a couple things here and there, this afternoon I finally got an AC compressor mounted. There are lots of types of mounts available for the LS these days, but I wanted a low mount, and that leaves only a few options. I settled on the Dirty Dingo bracket setup, as it provides the narrowest measurement and most clearance to the framerail.
Unfortunately, as with most things I try to “bolt on” it needed modification, as the tensioner was trying to occupy the same space as the steering rack hard lines. I thought about a few different ways of fixing the issue, including re-routing the line, moving the rack, or trying a different bracket, but settled on just moving the tensioner over about 3/4”. I ended up building a doubler bracket out of 1/4” aluminum plate, as there wasn’t enough meat on the bracket to drill the new holes as delivered. All seems to be well with (minor) clearance all around, just need to find the correct length belt. 5 pound sack...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 03-08-2020 at 11:53 PM. |
03-08-2020, 11:38 PM | #2103 |
A guy with a truck
It’s really packed in there, but it all fits, and is hidden away nicely
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
03-08-2020, 11:46 PM | #2104 | |
A guy with a truck
The short runner/single plane intake is almost certainly losing a few hp/lbs-ft low in the rev range, and the cam exacerbates the issue, but I’m willing to make that sacrifice for the look/sound I’m after. Really all comes down to what your priorities are. If it becomes an issue, there’s always forced induction, more cubic inches, or deeper rear gears to help make up for it
03-12-2020, 07:20 PM | #2105 |
The truck looks great, Chris....amazing transformation....its come a long way!
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
03-17-2020, 12:22 PM | #2106 |
Nice fix. Didn't your bracket come with a belt? Mine did. I can look at the part number later if you need it. Let me know.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
03-18-2020, 06:58 PM | #2107 | |
A guy with a truck
No belt with mine, but I bought bracket only, not the kit. From reading, it sounds like the DD compressor is a knockoff and I found a good deal on a new Sanden. I did finally get a belt on it after measuring twice and only two trips to the LAPS
03-18-2020, 09:06 PM | #2108 |
03-20-2020, 07:09 PM | #2109 |
Look at you and your fancy cool air maker thingy....
03-21-2020, 10:29 AM | #2110 |
PROJECT 7DEUCE
Just checking in...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
03-25-2020, 02:24 PM | #2111 |
A guy with a truck
Thanks man, pretty happy with how it’s turning out. Just a few minor tweaks and I’ll consider it “done”.
Haha, way too much head-scratching spent getting the silly thing in there... I’m still chipping away. Here it is sitting in the rear bumpstops to check clearance for the driveshaft, wheel tubs, and over-the-axle exhaust. Kinda makes me want to “air-out” the front just to see what it would look like:
03-25-2020, 11:42 PM | #2112 |
You know you can swap out those pesky coil-overs for Shockwaves, right?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
03-26-2020, 09:25 PM | #2113 |
A guy with a truck
No bags right now, this was supposed to be a simple suspension upgrade
03-26-2020, 11:31 PM | #2114 |
Simple...... Pfff.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
03-27-2020, 12:59 AM | #2115 |
Going from a 7.5” ride height to 4 will close some gaps.
Will you have to run your tunnel all the way to the hump ? |
03-27-2020, 09:19 AM | #2116 |
A guy with a truck
It was supposed to just be a simple coilover upgrade with mild dropmember and a NoLimit rear kit, until Nathan Porter got in my ear. He was right, I would have never been happy with the mild setup. Add the LS swap into the mix and it’s gotten out of control. Glad I went this way, but the snowball is in full effect...
Definitely have lots of things competing for the same space when you get this low. The driveshaft tunnel runs from the rib behind the high hump to the rear cab wall. The hump itself will also need clearancing for the quite large TKO to sit at the correct driveline angle.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 03-27-2020 at 01:38 PM. |
03-27-2020, 01:37 PM | #2117 |
A guy with a truck
...and here it is all complete. Fully seam welded, etch primed, seam sealed, and undercoated. I used the factory-style brush technique on the sealer, though if I had it to do again, I’d probably just use my finger to smooth it. Thankfully it will be buried under insulation, carpet, and a seat
03-27-2020, 01:58 PM | #2118 |
Nicely done. Even on the 64-66's the floor needs clearance on a 1pc. driveshaft. I also had to make the trans-hump a 1pc deal vs. the 64-66 2pc set-up.
Similar but different. I used flat sheet to form my parts since it was easier to source locally....
03-27-2020, 02:04 PM | #2119 |
A guy with a truck
Thanks Scoti. Yours looks very-well executed. I started with a pre-fab tunnel, but only ended up using the very top couple inches of it. A 2 piece shaft might have been easier than all of this. Just glad to be done with it, honestly, so now I can move on to head-scratching the high-hump panel.
03-27-2020, 02:36 PM | #2120 | |
But, after discussion w/Nathan, I prefer the budget/simplicity of the 1pc. as well as the potential additional costs toward minimizing driveline related vibrations (which are a serious Pet Peeve of mine). Advice I'd give for others reading is to definitely check clearance under your seat if building/tweaking the trans tunnel. Although I planned for it, mine is close.... but clears the frame (Buddy Buckets).
03-27-2020, 03:00 PM | #2121 | |
A guy with a truck
03-27-2020, 06:31 PM | #2122 |
Looks Awesome.
NHRA Super Street 469C It only runs 10.90 at 156 mph |
03-27-2020, 09:35 PM | #2123 | |
Last edited by BustedTruck; 03-27-2020 at 09:44 PM. Reason: Nevermind I think I found it. Thanks |
03-27-2020, 11:21 PM | #2124 |
A guy with a truck
Thanks!
SD7B10, model 7176, if you’re still looking
03-28-2020, 06:59 PM | #2125 |
A guy with a truck
With the driveshaft tunnel complete, it was time to move on to the high hump. First order of business: fill the Muncie shifter hole. That was the easy part...
