#2126 |
Post Whore
![]() Join Date: Aug 2014
Re: A '54 named Busty
the last two washer are super fun to get out as they had 67 years to get acquainted with the rust
I used a liberal amount of forty water and a flat screw driver (and a hammer) to slide it off 1 millimeter at a time |
#2127 |
Post Whore
and I think this is the order of how they all go back on (not sure about the top two as they fell out and may have flipped like a bad coin toss)
CORRECTION: the top two washers need to be reversed the D shaped one goes on top then two of these plasticy ones (I later learned that in this pic I am missing one) later in the thread I show all of them in the proper order Last edited by Gregski; 09-14-2021 at 11:14 PM. |
#2128 |
Post Whore
the L shaped strip was next to come out, that last bottom 1/3 of it was rock hard
#2129 |
Post Whore
and finally around the final bend the last strip is riveted on, but these are really weak rusted tubular rivets so a dull screwdriver pops the strip right off
#2130 |
Post Whore
and a small punch knocks out the rivets nicely and easily
#2131 |
Post Whore
and here are the sticks painted and ready for new rubber
Note: I only painted inside the channels and left the rest "patinaed" |
#2132 |
![]() Join Date: Sep 2017
I did that on the Jeep. The hardest part was getting that little rivet to "squish" properly. I got the tool and put the bottom on an anvil and used the tool and a BFH to collapse that little rivet.
How did you do that?
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
#2133 |
Post Whore
ha ha, haven't yet, still working on growing that third arm to help me hold it in place while I swing some 3 pound Gentle Persuasion its way
#2134 |
In my experience, that 3rd hand will be very helpful in this endeavor!
#2135 |
Post Whore
#2136 |
Yes it, it happens. Be sure to compliment her on how well she did!!!
#2137 |
Post Whore
so a little nonsense update, we all know the details belong to the devil, so here we have some black stainless steel #8 x 1/2" screws to use on them doors, some will hold the vent window in place others will hold that metal retainer strip on the bottom of the doors
got these cause The Filling Station only has bright shinny ones and we all know Chrome won't get you Home but Black will get you Back on a serious note, I aint no metallurgist so I read that stainless steel won't rust but again we don't want shinny, we know that Zinc will rust as fast as it can and black oxide will do the same, so this gets the best of both worlds it's stainless and black and I promise to let you know in 40 years how they did |
#2138 |
Post Whore
the rest of the door/window parts arrived today, I must say The Filling Station ships really fast, and as you can see below looks like the Feds have been getting some training from FedEx, ha ha
#2139 |
Post Whore
so let's take a look at what came in the boxes
in the bigger box we got new metal retainer brackets to hold the weather strip against the bottom of each door notice they are raw and not painted Last edited by Gregski; 09-14-2021 at 11:15 PM. |
#2140 |
Post Whore
in the smaller aka mangled box we got the window vertical retainer channels
notice how these are painted black I find it interesting how the parts that will be hidden inside the doors came to us painted and the parts that will go on the outside were not, things that make you go hmmmmm |
#2141 |
Post Whore
and we also got some tubular rivets for the vent windows and a special punch to collapse them properly
we also got a set of pivot rivets (and another extra set just in case) Last edited by Gregski; 09-14-2021 at 11:03 AM. |
#2142 |
Post Whore
here is the Jerry Kassis vent window re assembly video we're going to follow
Vent Window Restoration-1967-72 Chevy Pickup |
#2143 |
Post Whore
progress was made today as we assemeblinated the triangles
this first rubber piece is excellent quality and goes in super easily using our cooking spray its a little different than in the video: you no longer need to drill out the two top rivets to loop it around the top edge, now it just snaps into place, super easy there is a left and a right one, but even a Pollack like me can figure that out |
#2144 |
Post Whore
Christ on crutches this next part was a Nightmare !
Fun Level: -2 with a Annoyance Factor of 54! |
#2145 |
Post Whore
the punch tool you buy from them is a Joke, how are you supposed to swing a hammer while keeping it perpendicular to the rivet, no way in Nova Scotia can it be done, not even with the Punch Blue Tape Socket Extender 3000 aka PBTSE3K
#2146 |
Post Whore
tried the C clip routine but that failed miserably, as one needs to be an octopus to control it properly
#2147 |
Post Whore
and can someone explain to me how is this possible? how can a tubular aluminum rivet take out a punch, is it made out of softainium or something
#2148 |
Post Whore
anyway we kept tappin' and somehow we got it done, we kept hammering till there was no more wiggability
#2149 |
Post Whore
then it was time for the glass to go back in
#2150 |
Post Whore
this is a two step process, and once you get the stud in then you have to enlarge the hole for the new rivet a little bit
