05-28-2021, 08:24 AM | #2151 |
Mr. Cheyenne
Re: What did you do to your truck today.The 3rd chapter
My brother brought me a 72 C10 Cheyenne truck to go along with mine :-D
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
05-28-2021, 09:39 AM | #2152 |
Swapped over to 5 lug axles, and new wheels & tires.
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
05-30-2021, 09:09 PM | #2153 |
Finally got around to fabbing up some temporary linkage for the Saginaw swap.
-Mike from Alabama Why do we park on a driveway, and drive on a parkway? Jake - '67 Short Step Dirty Dan - '80 Short Fleet |
06-01-2021, 03:22 PM | #2154 |
Getting the differential rebuilt tomorrow, and will hopefully have pics to post. Pinion bearing is definitely bad in it.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
06-01-2021, 03:54 PM | #2155 |
Dropped in an LS...
[IMG][/IMG] |
06-01-2021, 06:05 PM | #2156 |
My fuel gauge wasn't reading correctly and using a decade box I isolated it to the dash side. Pulled the cluster and found a nut that wasn't quite tight on the sender side of the gauge. I removed the seat to do this and also fixed the seat adjuster wire that kept coming off.
06-01-2021, 06:05 PM | #2157 |
Finished up one side of the 68 Golden
06-01-2021, 07:23 PM | #2158 |
06-01-2021, 07:43 PM | #2159 |
After I peel off the crappy repaint started with 600 and water worked up to 1500 then buffed with ultra cut compound with a rotory buffer then went to a orbital with swirl remover . Polish then wax all with Maquiars .
As I said peel
06-03-2021, 01:00 AM | #2160 |
Mr. Cheyenne
Had my drive shafts and rear end inspected. All in great shape, though they did say the oil in my rear end looked like swamp mud but otherwise no issues to be found. So just needed a new gasket (I did have a very small leak) and filled with new oil!
That was my last major section of my truck to have looked at / worked on since I got her a little over a year ago. Next week, my plan is to drive her to East Texas for the Model A 2021 Texas Tour - my brother wants me to be a chase vehicle. Anyways, it should be a nice leisurely 300 mile drive going the back way to Kilgore via US Hwy 79.
06-03-2021, 01:31 AM | #2161 |
Worked on transmission lines. I am not good at bending lines. I see that Davidf is using the factory truck lines. Great idea. However the lines are different diameters and not sure how one can get The new lines attached to the radiator. Are adapters available? Can you use the same year truck radiator?
06-03-2021, 09:39 AM | #2162 | |
06-03-2021, 06:08 PM | #2163 |
In my prior life I have installed compression fittings on a 10,000 psi system.
06-03-2021, 11:50 PM | #2164 |
Got the truck on the hoist today, box going on tomarrow, new 6" drop is installed and the flip kit/C notch has been done. Now I need to remanufacture the tilt hinges and reinstall the drivetrain. Would like to be done by end of month
06-04-2021, 08:21 AM | #2165 |
cab,
Wow! Interesting. Did you take the 4x4 in your avatar and make it 2wd? Love the blue.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
06-05-2021, 03:29 AM | #2166 |
70+ ( Old Skool Club )
Had my 255/60 17 inch Bridgestones delivered, Fed Ex contractor left like this, that will be going on my truck probably next year. Now to save for the Torque Thrusts.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-06-2021, 07:40 PM | #2167 |
72 died on me today in the driveway. Starter must have a dead short tried jumping the solenoid with the tester starter button . Nothing and the button got hot quick. So I have a new one on the way as it was under warranty but I’m done with DBElectric . 3 in two years on 2 different vehicles. So I ordered a Powermaster mini .
I also tried one of the M/T wheels that came off the Tacoma on the 68 . Pain in the butt sanding them to this finish by hand ,may just sand with 400 and paint them black .
06-06-2021, 08:43 PM | #2168 |
I completed several small projects today, some of which have been on my to-do list for a long time:
Replaced the output seal on my recently rebuilt 700R4. Either I damaged it or it was defective. Went with a GM seal this time. Made a mirror image tailpipe hanger bracket for a full length exhaust system I'm planning on getting. Also installed stock hangers on both sides of the chassis in the middle of the truck Installed a replacement hood hinge I painted yesterday. The original Hinge was bent sideways enough that the open limit stop no longer worked. Painted and installed a set of shorty 5/16 body screws in the left inner fender brace. These screws are hard to find. |
06-06-2021, 08:58 PM | #2169 | |
Also there is 3 coats of purple pearl on top of that blue. |
06-09-2021, 03:00 PM | #2170 |
Mr. Cheyenne
Got tint and clear windshield over with tint visor!
Now I’m all set for the Texas sun and my trip up to East Texas!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 06-09-2021 at 03:22 PM. |
06-09-2021, 03:21 PM | #2171 |
Washed, Clay bar, compound, polished.
Damn, she looks good! I love this truck!
1972 Cheyenne Super LWB, 350V8, AC, PS, PB, all original 46k survivor |
06-09-2021, 03:24 PM | #2172 |
Mr. Cheyenne
Jealous, I'd love to have that color and yours being "Super" - it's the only one that I like (love) better than mine.
What's that other badge on your cow! Makes me wonder, what am I missing LOL
06-09-2021, 03:28 PM | #2173 | |
Allen Cook Chevrolet Buick. They went out of business in the late 80's. Found out they did ambulance conversions for a few years in the 60's.
06-09-2021, 04:24 PM | #2174 | |
i remembered this post and gave Manes a call for my right hand mirror. She had one left, pulled it for me and will get it out by tomorrow. Have to love a place that answers the phone, and runs back to check stock. Very happy to give them my business. And now, like you Rich, I'll have a mirror I can adjust without thinking I'm gonna break it!
06-09-2021, 04:24 PM | #2175 |
C-Notch, 2” blocks, POL brake conversion, 2.5” drop spindles, tie rod & ball joint replacement. Just a 2 day project this past wknd…boy was it a butt kicker!
