#201 |
Re: 52 Project
Cole, Sorry I missed your post. I think that a good small block would be a better choice. The reason I say that is because a big block is really tight. The distributor is going to hit the already recessed firewall and the water pump pulley is only about 1/4 inch from the radiator fan. We had a radiator and fan setup custom built and everything is still really tight. The reason we are running a big block is because we already had it and I was up to the challenge. If it was mine and I was starting from scratch the small block would be the motor of choice. This truck is going to be cool when it is done but it has been a ton of work and for your first truck I think keeping it simple would be the way to go. There are a lot of projects out there that never get finished because the owner gets in over his head. Get the thing running and then you can do other thing to it as you can afford it or have the abilities to do them. That way you can enjoy the truck. I have been working on this thing for 2 years and hopefully we are going to have the running gear in it soon and then we are going to do the body work. If you have anymore questions post them and I or someone on here will try to answer them.
Bernie |
#202 |
Re: 52 Project
Prostreet, Too bad you had to sell it but i understand. I guess the Corvair turned in to the other 58
![]() www.moondustmotorsports.com Bernie |
#203 | |
Re: 52 Project
@pgf545
#204 |
Re: 52 Project
I would definetly go with the small block LT/LS1 motors and just give a 100/150 shot dope to her and get that instant hp rather than go with a big block the weight factor for one in the front along with it driving like a heavy car because of the weight up front heavy sway bars up front to handle the roll u gonna have because of the weight up front. You also going to need to beef the frame up to handle to horsepower and yes it is going to be very tight in there also with cutting back the innner skirts ur not going to be able to get the motor low enough for the stock clearence on the tunnel for the transmission a whole new firewall. The back end of these trucks are light to begin with the truck would be more evenlly balanced with a small block. Just my opinion bud
#205 |
Re: 52 Project
Wigadore, I just looked back through my thread and saw that I had talked to John at PRC. I am sure that we would remember building that radiator because I talked to him several times. I don't know what you are looking for but I just called him and told what we were building and they hooked me up. I did give him the measurements for the hose sizes but that is all I remember giving him. They must have the dimensions for that thing. If you want I can give you more specific pictures if you will tell me exactly what you are looking for. I included a couple of pictures that may have a better look for you.
Update: We had the frame blasted and dad painted it last weekend but had some issues with the paint, so he was going to try to reshoot it this weekend. Once that is done we are going to install the front end pieces and put the motor in for the final time. So all the running gear will be in at least and then on to the body work. Hopefully if all goes well then maybe later this year we will get to take a ride...lol. Bernie |
#206 |
Re: 52 Project
Wow Bernie, thats one sweet radiator! Were did you get it?
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
#207 |
Re: 52 Project
Cal, We got it from Prc Hotrods in Illinois. Very nice piece and great people to work with. I am going to order one for the Camaro pretty soon but it probably won't be all shinny...lol.
Bernie |
#208 |
Re: 52 Project
Is it custom made or are they distributors of them?
#209 |
Re: 52 Project
Cal, They are the manufacture of them. They make models for several applications, but the one that I had built for the truck is a semi custom unit. I think they had the basic measurements but I had it built for the big block and had them move the fan and made sure the hose barbs were the right size. The workmanship is outstanding and the price was comparable to other units.
Bernie |
#210 |
Re: 52 Project
Ok I finally got some picture worthy work done on the truck. We got the frame blasted and painted along with all the front suspension parts. Dad and I got the A-Arms, Springs and spindles installed and then went to put on the rotors and ran into some trouble. It seems that the new rotors that we got are about 1/4 inch shifted farther to the out side than the originals. He is going to make some calls this week to see what we can do to fix this. Here are a few pictures that I took yesterday.
Bernie |
#211 |
Re: 52 Project
Just a quick question. What did you do inside the frame that was boxed? Did you clean it up and put some rust preventer down or do you not see any problems with that down the road?
Thanks, Cole |
#212 |
Re: 52 Project
Cole, What I did was to wire brush the heck out of the inside of the frame and then paint Rust-o-leum on the inside of it and the boxing plates. Also in the area where I was going to welding I painted it with weld through primer. The frame had been sand blasted years ago so it was pretty clean. We also tried to get as much paint on the inside as we could while painting the frame. I am thinking that will be enough because we don't plan on driving it in the rain and bad weather. This is my dads toy so I don't think we will get it out unless the weather is good.
Bernie |
#213 |
Re: 52 Project
Chassis looks great, I am about to start painting the '51 frame.
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
#214 |
Re: 52 Project
Looking good enough to eat off of!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe ![]() |
#215 |
Re: 52 Project
Looking really good Bernie!
#216 |
Re: 52 Project
Hey Thanks guys, the frame turned out really nice, although not show quality it is what we were looking for. This is going to be a driven truck and not a show truck...lol. Hopefully in the next few weeks we are going to put the motor in it and then start the body work. More pictures to follow.
Bernie |
#217 |
Re: 52 Project
Here are a few pictures of some stuff that I got done last weekend. My dad and brother finished installing the front end stuff and got it set down on the ground with a set of mockup wheels. Also we bolted up the tranny to the motor and set it in place. I also got all the March drive belt stuff installed. Now that most of the chassis is done it is time to start the body work.
Bernie |
#218 |
Re: 52 Project
WOW!!! That looks super sick! I love the motor with its March drive belt! Your Dad truck is going to be really nice based on the work already done.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 Last edited by CAL 58 GMC; 04-30-2008 at 05:50 PM. |
#219 |
Re: 52 Project
hey there Bernie,
maybe i missed it i just looked back thru your posts, but whats up with the rear shackles for the rear leafs? on the 50 GMC im working on i used the front shackles on the rear they are 1" shorter, but yours look even shorter! thats means more drop, do tell please. thanks, Yaril |
#220 |
Re: 52 Project
Yaril,
That is an after market spring kit that I think we got from CPP. It comes with the new springs, front and rear hangers and new pads for the rear end. It is supposed to lower it some but I don't know how much. The shackles are only about 3-4 inches long. Also the springs have less arch than the originals. Dad didn't want to bag it so everything we have done so far is with springs. If you need anything else let me know. Bernie |
#221 |
Re: 52 Project
cool thanks Bernie, ill see if i can buy just the hangers with hardware.
#222 |
Re: 52 Project
Bernie,
Whats next on the list. WHat are your palns for a fuel tank?
#223 |
Re: 52 Project
found the web site, they seem to have everything one would need, but they also seem to not sell those hangers and hardware separately.
#224 | |
Re: 52 Project
I got the tank to work. Next thing is doing the body work and get it painted. Will probably do things like run the lines for the brakes and fuel while the body work is going on. Still need to figure out the steering column and shaft setup. Hopefully the body work won't be too bad cause the old body isn't in that bad shape...(keeping fingers crossed)...lol. I think most of the running gear is ready but dad did mention the other day that he was thinking about a 700R4 so that is still up in the air but I can deal with that later if he wants to do that. Then it is all the other time consuming projects like wiring and interior that will come last. Thanks Bernie |
#225 |
To The Levy
Re: 52 Project
always nice when the kids wanna help, keeps em out of trouble... cool
