05-07-2011, 10:46 AM | #201 |
PROJECT 7DEUCE
Re: Project 7deuce
Been busy with this thing finally got lots of parts just need to finish the odds and ends and get the new parts installed.. 1st on the list is to finish the half ass a.d.d. projects that I started on it but never finished...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-08-2011, 12:42 AM | #202 |
Re: Project 7deuce
hey there mr french do u have any pics of the hinges for the hood i wanna do a reverse with mine but havent seen any pics of them yet?
05-08-2011, 09:57 AM | #203 |
PROJECT 7DEUCE
Re: Project 7deuce
05-20-2011, 06:30 PM | #204 |
PROJECT 7DEUCE
Re: Project 7deuce
Been workin on loose ends..... Welded up cab seam..
05-23-2011, 12:28 AM | #205 |
Re: Project 7deuce
it will be nice to see it all welded and then grinded dwon for that one peice lookk. keep it up frenchblue72
05-23-2011, 12:47 AM | #206 |
Re: Project 7deuce
Keep makin' forward progress!!
Eric 1967 C10 SWB 383 Stroker/TH400 Brother's One Piece Power Windows Shaved Doors, Markers, and Bumpers 4/6 Early Classic Drop Rear Fuel Tank (49-52 Chevy Car Tank) Surf Blue Paint Bella Vista, AR (Arkansas for those that get the 'A' states mixed up) My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869 |
05-23-2011, 10:12 AM | #207 |
low n' slo
Re: Project 7deuce
maybe i missed it but where did you mount your rear bags?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
06-08-2011, 12:12 PM | #208 |
Re: Project 7deuce
Great build, nice lookin truck, subscribed!!!!!!
CHEVY/GMC VIN DECODERS |
06-23-2011, 10:57 PM | #209 |
Re: Project 7deuce
Nice looking truck, I like that hood trick. Used to have one of those Le Sabre's but sent it to the yard after the engine blew, wish I would have saved the hinges after seeing your truck
I know how the burned out thing goes, starting to come out of it slowly myself. Keep up the great work |
06-23-2011, 11:05 PM | #210 |
Still Learning
Re: Project 7deuce
Cab looks good. That takes some serious time to lay down all those beads.
06-24-2011, 03:48 PM | #211 |
PROJECT 7DEUCE
Re: Project 7deuce
Thanks guys I keep buyin parts and finishing other house hold projects .. Hope to get back to her soon..
06-25-2011, 12:10 AM | #212 |
Re: Project 7deuce
Yeah it's a bummer when you have to keep up everything. Like I said in my post 1 day then another they all add up to a completed build, keep plugging away.....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
07-10-2011, 05:58 PM | #213 |
PROJECT 7DEUCE
Re: Project 7deuce
Guess what I'm back on her with a vengeance pics tonight...
07-10-2011, 06:02 PM | #214 |
VA72C10
Re: Project 7deuce
Cool!
Looking for a 67-72 swb or blazer project in or around VA. |
07-10-2011, 06:38 PM | #215 |
Re: Project 7deuce
Hope you get more done than me, I pushed mine out into the driveway after church, looked at it for about ten minutes then pushed it back in. It's 104 here today. I thought I left Arizona
07-10-2011, 10:26 PM | #216 |
PROJECT 7DEUCE
Re: Project 7deuce
Eric (es67chevy)thanks for the poppers they seem like the will work with a little effort on my part... I did have to modify the mounting plates for them and I am thinking a little softer spring will help them work to there potential.. I also broke out the avs door releases,I have not installed these yet but they sure seem pretty nice kit comes complete with all cables and hardware..You can see where I had to take my dremel tool and grind down the welds on the backside of the poppers to make them fit flush.. My stainless screw store was closed today so I used some craptacular scews from the junk bin.. The poppers came with screws but they were weak sauce..
07-10-2011, 10:36 PM | #217 |
PROJECT 7DEUCE
Re: Project 7deuce
Finished welding up my new rockers finally.. These have been stuck on the truck for close to a year and now they are finally welded one and some rage applied to smooth out the cab corner to rocker joint.Here you can see the spacer I used to shorten up the door poppers... Welded up a large crack /tear in the passenger side door.. At some point before we got the truck someone had some rockin spark-o-matic 6x9's in the doors so I finally put on another coat of rage to smooth them back out...
07-10-2011, 11:55 PM | #218 |
Re: Project 7deuce
Sick..
1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
07-11-2011, 07:41 AM | #219 |
PROJECT 7DEUCE
Re: Project 7deuce
No pictures uploaded??? Here we go agian with some pics.... Thanks sam hope your truck is keeping you motivated to get it finished unlike mine which goes in short bursts..
07-11-2011, 07:48 AM | #220 |
PROJECT 7DEUCE
Re: Project 7deuce
Finally managed to locate some new caps off e bay for my wheels 52 bucks and they still dont look all that great... Also started sanding the cab roof seam,this took most of the day and just need to transition the corners to make them smooth..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 07-11-2011 at 09:14 PM. |
07-11-2011, 09:44 AM | #221 |
Re: Project 7deuce
Roof looking good, keep at it.....Jim
07-11-2011, 10:00 AM | #222 |
Re: Project 7deuce
Are you getting rid of all the seems and rough edges? Going completely smooth?
Posted via Mobile Device |
07-11-2011, 10:17 AM | #223 |
Re: Project 7deuce
I wish man. I've lost complete motivation. All I've done is pulled it to work in hopes of making it a runner..
07-11-2011, 12:19 PM | #224 |
67cheby
Re: Project 7deuce
tuned in ....lets see more !!
07-11-2011, 12:58 PM | #225 |
VA72C10
Re: Project 7deuce
Looking good! Hope you stay motivated for a bit so we can follow progress
