05-22-2011, 09:47 PM | #201 |
Re: My long term 57 project
Very nice '55 I like the color
55 2nd series Chevy Pickup 2019 Chevy Equinox(Daily driver) 2011 Chevy Malibu (Wife's car) MSRA Member I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose. -George Carlin |
05-23-2011, 12:14 AM | #202 |
Nice looking 55.
Kim |
05-24-2011, 09:27 PM | #203 | |
A320 Pilot/USAF Retired
The exhaust is all stainless, except the 40 series flowmasters. And it's LOUD! The cam is to much for my taste, already thinking of swapping it out, and probably changing the Flows to 50's. Already put 100+ miles on it this past weekend and it ran perfectly!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
07-09-2011, 12:55 PM | #204 |
Its crazy how many of us have the sedan and the truck, just like the chips you cant just have one...
Nice looking pair. |
07-09-2011, 07:17 PM | #205 |
Thanks Rod! I'm loving the '55. Driving it a couple a times a week, always puts a big smile on my face!
07-14-2011, 12:44 AM | #206 |
Great jobyou have done on your 57!!
It has been 34 years since I had a 57 but it was the orginal "custom delux" you sure put the "CUSTOM" back into your Chevy. You will LOVE that ZZ-4 and AOD, it is the perfect combination for these trucks. Looks like you have enough rubber on the ground. What gear do you have in the rear, I may have missed that. Tell me how the mono spring does under acceleration with that size rear tire? I am thinking I need something wider than a 255.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
07-14-2011, 07:12 AM | #207 |
Nice 55 like the color too.
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair 99 S10 http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 |
07-14-2011, 09:07 AM | #208 |
Certified Car Nut
I see you finally join the club and got that truck a sibling.lol It looks great and it as belaire trim is it a true belaire post? Because they did have belaire sedans. Any congrats to you I sure your smiling ear to ear.
07-16-2011, 01:03 PM | #209 |
Yo Chuck! I just finished up looking at your build and all I can say is very nice! You did stuff right, kept it clean and didn't rush anything! You've made lots of cool comments on my build but after seeing yours, I have to tip my hat to you! Very, very nice!
It's all about the stance, baby! http://67-72chevytrucks.com/vboard/s...d.php?t=320546 |
07-16-2011, 03:54 PM | #210 |
Nice 55 ,you have the perfect set now!!!
07-21-2011, 01:34 AM | #211 | |
I THINK I found a kit to do what you did with your rearend: http://www.jamcosuspension.com/produ...productID/1045 Obviously this is for a car (you didn't use it, did you?) but I thought I'd post it here since I just happened upon it last night. |
07-21-2011, 01:10 PM | #212 |
Dan, No this is not what I used for my truck. Like you said its designed for the car frame, not our trucks but with some creative engineering it might work?!
08-07-2011, 11:27 AM | #213 |
08-07-2011, 11:30 AM | #214 | |
The rear tires are 285/60x16. It now criuses great at 70 mph pulling only 2100 rpm!
08-07-2011, 11:32 AM | #215 | |
08-07-2011, 11:33 AM | #216 |
Thanks, may have to paint the truck Blue someday!
09-06-2011, 04:28 PM | #217 |
okay I did basically the same front frame mod as you, except I used a G body frame, and mine is 2" lower than yours. I would like to raise mine up a bit. Did you use big block front springs or small block springs?
09-06-2011, 09:41 PM | #218 | |
Did you cut your springs? Thanks!
09-06-2011, 10:39 PM | #219 |
I did not cut the springs. I ordered a subframe from Kimbridge, and bought new springs for a 86 Buick Regal with a olds 305..... The truck settles down about 4 inches, and I would like it to go 2 inches. I have 5 1/2 inches total suspension travel. I know it would look better up just a little. Alignment would be a little better as well.
Adjustments, adjustments, adjustments. My plan at this point is to install a different engine (1989 corvette) that has a lightened flywheel, 10 inch clutch, aluminum bell housing, aluminum heads, and aluminum water pump, mini starter, with an aluminum radiator. That should take about 140 pounds off the nose. Since I have the engine and everything that goes with it, I will try that first. I am using the corvette 4+3 stick overdrive trans and my original long bed driveshaft fits perfectly as the engine is at the original height, but forward 3 inches. It currently has a '78 4 bolt 350 with the 92 firebird cast iron heads and firebird cast iron water pump. I'm using a 92 firebird serpentine setup. I will finish these mods before I start messing with the springs. The last resort is to install 3 inch lift S-10 spindles. Last edited by Coupeguy2001; 09-06-2011 at 11:06 PM. |
09-09-2011, 10:23 PM | #220 |
Dan, these pics might help show how I installed the tank.
09-09-2011, 11:34 PM | #221 |
Looks great, what did you use for mufflers? trying to decide what to get, anyone use cherry bombs?
09-10-2011, 08:45 AM | #222 |
Howdy Rod, they are Flowmaster Super 40's. They have a nice sound to them. They have a drone to them around 2800 RPM, but now that I have the overdrive trans they are much more quiet at highways speeds.
09-11-2011, 07:41 PM | #223 |
I'm super impressed with how great the camaro clip looks.. Can you tell me what year camaro the clip came off of? I wonder if there is a tutorial showing how this was installed to look so factory... awesome truck! Thanks - Shane
09-12-2011, 09:18 PM | #224 |
It's from a 77 Camaro and I had it done for me. I think No-Limit Engineering has a video showing how they do it. Some have said it has helped them. There is also a very long thread on the HAMB that details it also. Best of luck with your project!
12-09-2011, 12:01 PM | #225 |
Chuck guess I never noticed at first but why did you put stand-offs on the engine mounts?
2006 Chevy Silverado 3500(Duaramax/Allison) - DD 1997 Honda Civic - Work Beater 1981 Chevy Malibu - Race Car 1959 Chevy Truck - Project http://67-72chevytrucks.com/vboard/s...d.php?t=481442 2006 Honda Accord - Wife's ride |
