Old 02-28-2010, 11:31 AM   #201
ghettoluxury
ghettoluxury's Avatar
Re: How about some pics of 47-59
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-28-2010, 12:48 PM   #202
BigSix302
BigSix302's Avatar
Here a couple from my stable. The 52 Old Blue is my parts chaser and run around truck. The Burb is a current WIP. I have others also as WIP but on the back burner for now. I went ahead and added my 49 WIP as it is currently.
AD's Rule!! 53 GMC Suburban--48 GMC 1/2 Ton project--49 Chevy Pick-up--52 Chevy Pick-up (my driver)
BigSix302 is offline   Reply With Quote
Old 02-28-2010, 01:51 PM   #203
tmackg
tmackg's Avatar
Originally Posted by PDW HOTRODS View Post
Tmackg, that is awsome. I love the mods. Looks like exelent workmanship also. Would like to see more.
Thanks! That is its current state it's pretty much ready for paint but, I can't decide on a color it was going to be silver when I started the build 3 1/2 years ago but to many of these trucks have been done in silver recently.
tmackg is offline   Reply With Quote
Old 02-28-2010, 02:03 PM   #204
solidaxel
solidaxel's Avatar
Tim,
Welcome to the A D section from dry heat So. Az.!
Very nice build you have, can you tell me more about the hood peak and a finished (to date) pic of the hood. It looks like you filled in the cowl vent right?
How did you keep from heat warping the hood panels?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-28-2010, 04:58 PM   #205
tmackg
tmackg's Avatar
Originally Posted by solidaxel View Post
Tim,
The last pic is of the finished to date hood. The cowl vent is filled I bought a fill panel from *****in products to do that, because it was cheap ($20 if I remeber correctly)and had bevel edges to make it easy to finish. I controlled the heat by tig welding it with wet towels next to the weld and only welding small areas at a time and moving around to not get heat concentrated in one area, I still had to do some hammer and dollying bit not much. Here's a couple more pics from different angles;
Old 02-28-2010, 05:02 PM   #206
tmackg
tmackg's Avatar
Apparently the server software doesn't like cuss words but the name of the co. that makes the cowl vent fill panel is B i t c h i n Products
Old 03-01-2010, 03:08 PM   #207
nebdrummer
nebdrummer's Avatar
that is awesome work you do there... from one tim to another... im jealous!.
i plan on going back through mine here in a year or two, once i get my suspension all set up, and enough money saved up to tear into it. love what you did with that front bed rail. did you buy that or make it?
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit!
http://67-72chevytrucks.com/vboard/s...d.php?t=380212
nebdrummer is offline   Reply With Quote
Old 03-01-2010, 07:46 PM   #208
tmackg
tmackg's Avatar
Thanks! I made it. I bent a piece of tubing to follow the contour of the back of the cab to create the upper section of the front bulkhead of the bed, that gave me a starting point to work to with the bed sides ... etc. It was a ton of work but I'm really pleased with the way it looks.
Old 03-02-2010, 12:01 AM   #209
1sik52
Here is a pic of my 52. I will post some pics of my 51 that I just purchased as soon as I get some pics of it.
1sik52 is offline   Reply With Quote
Old 03-05-2010, 06:54 PM   #210
NONHOG
NONHOG's Avatar
BigSix302 tell us more on those caps on your burb ? They look cool !
Oh heres mine..............(as found)
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 03-06-2010, 03:07 PM   #211
southbounddee
southbounddee's Avatar
'52 gmc kustom/S-10 swap in progress...
southbounddee is offline   Reply With Quote
Old 03-07-2010, 08:11 PM   #212
omarsphatt
omarsphatt's Avatar
Here's my '49 - Chevy 350, Muncie M20, Dana 60 w/ 3.54's, Front subframe & steering column from a '78 Caddy Seville...
'41 Chevy Special Deluxe Coupe
'49 Chevy 3100 Flatbed
'52 Chevy Styleline 2dr Sedan
'61 Corvair Loadside
'63 Pontiac Catalina Safari 9 passenger
'65 Mustang Coupe
'72 Chevy K10
omarsphatt is offline   Reply With Quote
Old 03-07-2010, 11:16 PM   #213
BigSix302
BigSix302's Avatar
Those are the stock half ton GMC hubs caps, mounted to later model GM 4 x 4 Rally styled wheels. I made some adapters so I could snap them in place. I'll make a link here and you can take a closer look. I need to make some final photos. I thought I had them but can not locate them. I will try to get them done this week sometime and add a follow up note. Oh and thanks for the kind words!! Nice Panel! Wish I had one of them too!!
http://community.webshots.com/user/b...host=community
Old 03-10-2010, 01:35 PM   #214
Daniel U
Daniel U's Avatar
I thought I had posted my '54 on here already, but didn't see it while browsing through these pics. Very cool truck builds on here. Make me want to finish mine and get a Task Force pick up!
Here's ashot of the rear after I mounted the bumper.
Here's the front passenger side with a white wall just for fun.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 03-10-2010, 07:31 PM   #215
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Daniel U, I like how you have a roll pan and the bumper. It looks clean, and it's suppose to be like that. Nice work.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 03-10-2010, 10:23 PM   #216
Daniel U
Daniel U's Avatar
It covers the gas tank and cleans up the rear view. When I get a chance to start working on it, I'll update my build thread. Thanks for the positive feedback!
Old 03-11-2010, 02:27 PM   #217
OrrieG
OrrieG's Avatar
I shot this yesterday in Boise, Idaho. Sorry for the crappy pic but it was from a stop light with cell phone, couldn't stop for better because of appointment. Cool Wrecker.
OrrieG is offline   Reply With Quote
Old 03-12-2010, 05:49 PM   #218
875DVL
47
875DVL is offline   Reply With Quote
Old 03-12-2010, 07:09 PM   #219
dewey777
dewey777's Avatar
New to the site today, here is a pic of mine when I first brought it home and one after the new cab corners went in
1959 Chev Apache 3100 Short Fleet Big Window
dewey777 is offline   Reply With Quote
Old 03-14-2010, 07:07 PM   #220
daxloves
daxloves's Avatar
My 56 flatbed.
daxloves is offline   Reply With Quote
Old 03-16-2010, 11:25 PM   #221
1955 Eddie
1955 Eddie's Avatar
1955 Eddie is offline   Reply With Quote
Old 03-17-2010, 12:03 AM   #222
Flames97
Flames97's Avatar
1955Eddie Wow, that is a good looking truck. More info and Pics please. That stance is awsome.
-Aaron
'15.5 Chevy Duramax LTZ/Z71, LML, CC/SB
'77 Chevy K10, 4" lift, 33-12.50, 350/350
'55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD)
My 55.2 Chevy 3100 Build
Flames97 is offline   Reply With Quote
Old 03-17-2010, 12:36 AM   #223
1955 Eddie
1955 Eddie's Avatar
Thanks FLAMES97
its a 1955. camaro clip in the front s10 rear. disc brakes front and rear. air bag suspension. 1 piece glass. power windows and seats. sway bars in front and rear. shaved handles and front turn signals. smoothed dash,cowl, firewall bed sides, and tailgate. 350/350 engine tranny. 18x8 front wheels and 20x10 rear.the list goes on but its a true father and son project that was completed in a 2 car garage. Everything was done by us including paint/mods/exhaust/wiring/glass/suspension. The only thing that has seen a shop are the 2 front seats.
Old 03-17-2010, 12:57 AM   #224
Flames97
Flames97's Avatar
That is the exact stance I want on mine when aired out. Do you have any pics of the rear suspension and frame area.
Again, My jaw drops everytime I see your truck. Nice work.
-Aaron
Old 03-17-2010, 12:01 PM   #225
Kabwe
Certified Car Nut
Kabwe's Avatar
Hey 1955 Eddie,
This is mkabwe from cardomain. I'm glad you found us over here. Eddie also has a sweet 55 car.
Kabwe is offline   Reply With Quote
