Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 09-04-2013, 12:33 AM   #201
likaroc13
Rollin' Old Skool
Re: Power Brake Booster Adapter Bracket
Originally Posted by Captainfab View Post
Thanks for the pics Phillip
Thank you!
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 09-16-2013, 09:54 PM   #202
Cordless
Captainfab this looks perfect. How do I get one?
Cordless is offline   Reply With Quote
Old 09-16-2013, 10:58 PM   #203
Captainfab
60-66 Nut
I'll send you a PM with ordering and payment details.
Old 09-21-2013, 11:41 PM   #204
Cordless
Arrived quickly and fits like a glove. Great business, great product!
Old 09-22-2013, 01:33 AM   #205
Captainfab
60-66 Nut
Thanks for the purchase and the compliments
Old 11-04-2013, 12:06 AM   #206
Bart Savage
Bart Savage's Avatar
There are a few listed in post #1, but here is a little list.
'67-'70 pickups, Suburbans, Blazers
'70-'74 Impala, Caprice
'80's G body Vans (full sized)
Early Astro/Safari vans with the vacuum booster
'82-'02 S10/S15 pickups and Blazers
'88-'98 full sized pickups
'92-'98 Suburbans, Blazers
There may be some other applications, and/or years, but these are the ones I have been able to verify.
Captainfab...can any of the above be used with drum/drum? im getting ready to work on a 63 panel/230 for my wife and need power first...then i will convert to disk at a later date if this is possible.
thanks.
Bart Savage is offline   Reply With Quote
Old 11-04-2013, 01:27 AM   #207
Captainfab
60-66 Nut
Most any of those boosters can be used with a drum/drum braking system. You just need the correct master cylinder. Since you are planning on upgrading to discs at a later time, I would suggest any of the listed boosters except the '67-'70 pickup, Suburban and Blazer booster. Then for a master cylinder you will want the '70 Buick Estate wagon master cylinder. The A1 Cardone number is 10-1363. Double check to be sure the one they give you have the shallow bore. It is basically just a dimple in the back of the piston which will be compatable with any of those boosters listed.
thanks.
Old 11-06-2013, 03:27 PM   #208
perrotta62
How can a guy go about getting the brake booster bracket for 60-62 that i seen on here that you build. How to ship it Grande Prairie Alberta Canada. What cost and payment. Cheers.
perrotta62 is offline   Reply With Quote
Old 11-07-2013, 12:10 AM   #209
Captainfab
60-66 Nut
I sent you a PM with details.
Old 11-16-2013, 10:07 AM   #210
ambros
Can you send me details i am looking for black powder coat bracket
ambros is offline   Reply With Quote
Old 11-16-2013, 11:03 AM   #211
perrotta62
Im not the guy that makes them, I was looking for info on them as well. capttianfab on here is the one that makes them.
Old 11-16-2013, 11:06 AM   #212
perrotta62
sorry its captainfab
Old 11-17-2013, 01:20 AM   #213
Captainfab
60-66 Nut
PM sent
Old 11-18-2013, 08:55 PM   #214
Mike1984
Captain, it's Mike in Colorado. I received the power steering bracket today as you said. Will check it out tomorrow. Thanks, Mike
Mike1984 is offline   Reply With Quote
Old 11-19-2013, 07:41 PM   #215
Mike1984
Captain, I'm sending u a pm. I have questions. Thanks, Mike
Old 01-08-2014, 07:22 AM   #216
Flthead
I'm going to be ordering a booster bracket for '64 1/2 ton with discs up front. Read thru post , anyone have info or links on making / proper adjustment on making rods work ?
Flthead is offline   Reply With Quote
Old 01-09-2014, 02:02 AM   #217
Captainfab
60-66 Nut
Are you needing to know how to lengthen the booster pushrod? Or is your question about the intermediate pushrod?
Old 01-09-2014, 04:58 AM   #218
Flthead
Just wondering on how to tell correct length an how to adjust. Have no problem making it longer or shorter
Old 01-10-2014, 12:39 AM   #219
Captainfab
60-66 Nut
The recommended adjustment for the booster to pedal pushrod is around 1/4" to the bumpstop, but it is also a matter of personal preference. I like mine a little tighter than that. But you have to be careful that you don't preload the master cylinder. If that does happen, everytime you push the pedal, the brakes will begin 'pumping up' until the brakes are totally locked.
Old 01-12-2014, 09:45 PM   #220
PGSigns
PGSigns's Avatar
I need to order another booster bracket for the 66 I just got. I am going to leave it drum drum for a now but need to split the brakes and go to a duel master cylinder. Whats the best combo of booster and master? Was looking at just putting the complete 67 setup on it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-13-2014, 12:55 AM   #221
Captainfab
60-66 Nut
Since you are staying drum/drum, yes you will want to use a '67-'70 booster and master cylinder, or any of the compatable boosters along with the '70 Buick Estate wagon master cylinder. Have you seen Sharps40 thread on his power brake upgrade? I'll send you a PM with payment info.
Jimmy
Old 01-13-2014, 07:38 AM   #222
PGSigns
PGSigns's Avatar
Thanks for the info and payment made on the bracket. If I go this route and decide to go with front disc would a master cylinder and proportioning valve swap be all that needed? I have a bad habit of not leaving well enough alone.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 01-14-2014, 12:24 AM   #223
Captainfab
60-66 Nut
If you think you may go with discs later, I would go with any one of the compatable boosters and the '70 Buick Estate wagon master cylinder (A1 Cardone #10-1363), rather than the '67-'70 booster and master. The reason being is that the '67-'70 booster has the long intermediate pushrod for a deep bore master cylinder. The majority of the disc brake master cylinders have the shallow bore. The Buick master is for drum/drum brakes but is a shallow bore master.
Jimmy
Old 01-14-2014, 07:40 AM   #224
PGSigns
PGSigns's Avatar
Thanks for the info. That is what I will do.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 01-31-2014, 06:18 PM   #225
BSB1965
Here are some installed pics.
Hi, I'm a new member to the forum. I have a 1965 chevy truck that is mostly stock but I would like to make some upgrades. I have seen your Power Brake Booster Adapter Bracket and would be interested in purchasing one. How would I go about buying one and what booster master cylinder combination would you recommend? Thanks!
BSB1965 is offline   Reply With Quote
