Old 01-20-2010, 08:31 AM   #201
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: 1969 Short Wide
SHOWOFF! Looks good.....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 01-20-2010, 08:42 AM   #202
0331grunt
Now what??
0331grunt's Avatar
Re: 1969 Short Wide
Looks great! now that you know how, you wanna come do mine
69 Long Fleet - Project
06 Ram 1ton Cummins 4x4-DD
01 Tahoe- wifes
"The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi
"A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell
my, um, build
USMC OIF Veteran SEMPER FI!
0331grunt is offline   Reply With Quote
Old 01-20-2010, 09:05 AM   #203
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Heath. I tried to do it 2 other times with 22 gauge and it's just way too thin. It didn't turn out as good as I would have liked but I think I can tweek it here and there and it will be fine.
I'll pass on that right now, maybe after a few weeks..... months....after I forget how frustrating it was.
mcbassin is offline   Reply With Quote
Old 01-20-2010, 09:13 AM   #204
0331grunt
Now what??
0331grunt's Avatar
Re: 1969 Short Wide
Maybe by the time I get ready for it, you'll have forgotten
01 Tahoe- wifes
my, um, build
Old 01-20-2010, 09:42 AM   #205
JohnC
JohnC's Avatar
Re: 1969 Short Wide
Looks good Mike. Great job!
JohnC is offline   Reply With Quote
Old 01-20-2010, 10:30 AM   #206
VA72C10
VA72C10
VA72C10's Avatar
Re: 1969 Short Wide
Looks great man!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-20-2010, 01:08 PM   #207
highperf4x4
Re: 1969 Short Wide
Dang, that is alot of work. How did you manage to keep it all even?
highperf4x4 is offline   Reply With Quote
Old 01-20-2010, 03:50 PM   #208
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks!
Originally Posted by VA72C10 View Post
Looks great man!!!
Thanks!
Yep, it is a lot of work. As far as keep it even, I set my angle protractor like this one here at 45deg. and scribed a line all the way around the edge then held it in place and tacked it. then used vise grips to force it to the
line. It was slow going. BTW, it isn't close to perfect, but I have it close enough a skim coat of filler will smooth it nice.
Old 01-20-2010, 07:49 PM   #209
highperf4x4
Re: 1969 Short Wide
I'm impressed. Not that I doubted your skills anyway.
Old 01-20-2010, 08:55 PM   #210
scotts62
One day...
scotts62's Avatar
Re: 1969 Short Wide
Cool! looks good!, i did the ole 90 degree angle on mine
Scott
93 crew cab build
Project 62
Old 01-20-2010, 09:09 PM   #211
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Yep, I came this -><- to just doing the 90 degree on this one too. But, I figured heck, it's only metal and this will be a driver not a show truck.
Old 01-20-2010, 09:09 PM   #212
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Travis!
Old 01-30-2010, 09:33 PM   #213
ripdog28
ripdog28's Avatar
Re: 1969 Short Wide
Welds turned out great on the firewall. I wish i would have spent more time on mine. Looking good man.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 01-30-2010, 10:42 PM   #214
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks! I hope to get back on it pretty soon. We are covered up with snow and ice right now and I don't have heat in the shop. I was looking at the cab the other day and found a little rust spot on the lower part of the driver side cab corner. I wasn't planning on doing anything to them except knocking out a few dents. Now it looks like I may be cutting and welding. I wish I could have sand blasted the whole thing to find all the thin areas. Maybe I will on the next build.
Old 01-31-2010, 12:31 PM   #215
0331grunt
Now what??
0331grunt's Avatar
Re: 1969 Short Wide
At least I have a small heater... not much, but it does allow me to get out in this weather. We have about 6" of snow. I really need to get my cab inside soon to start working on it, now that my frame is almost done. I am still nervous about the welding... practice makes perfect, right? (or is it practice makes work for someone else ) Keep it up! Maybe you will be driving it to the Spring meet?
01 Tahoe- wifes
my, um, build
Old 01-31-2010, 01:50 PM   #216
rob32472
Re: 1969 Short Wide
looks great keep up the good work!
rob32472 is offline   Reply With Quote
Old 01-31-2010, 06:29 PM   #217
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks! don't sweat the welding you will get the hang of it I'm sure. It will take some major work and some $$ to get it done by spring.
Thanks!
Old 01-31-2010, 06:58 PM   #218
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: 1969 Short Wide
Nice work Mike, the firewall looks good!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-03-2010, 05:58 PM   #219
68 TT
Still plays with trucks
68 TT's Avatar
Re: 1969 Short Wide
Nice progress. It gives me some motivation to work on my basket case 67 C-10.
Keep up the good work.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 02-03-2010, 09:08 PM   #220
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Nate!
Thanks! now if I could stay motivated to get the next phase started. Gonna have to do something this week it's been a few weeks since I touched it.
Old 02-03-2010, 11:31 PM   #221
scotts62
One day...
scotts62's Avatar
Re: 1969 Short Wide
I know the feeling its hard though if its cold, i dont get too motivated when its cold
Scott
93 crew cab build
Project 62
Old 02-03-2010, 11:38 PM   #222
mcbassin
Still Learning
mcbassin's Avatar
Unhappy Re: 1969 Short Wide
Had plans to work on it tonight...life gets in the way some times. and your right on it has been cold for what 3 weeks now? Sucks
Old 02-03-2010, 11:41 PM   #223
scotts62
One day...
scotts62's Avatar
Re: 1969 Short Wide
Yeah i hear ya about life ha ha but the priorities come first i guess.. i painted a Harley tonight, pics in the crew cab build, priorities came first
Scott
93 crew cab build
Project 62
Old 02-04-2010, 01:18 AM   #224
highperf4x4
Re: 1969 Short Wide
priorities suck..............
I'm just sayin...............
Old 02-04-2010, 08:38 AM   #225
scotts62
One day...
scotts62's Avatar
Re: 1969 Short Wide
Scott
93 crew cab build
Project 62
