Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 05-10-2012, 06:05 PM   #201
park72truck
Re: Camaro Caliper Brackets
i would like to get a set of these made if there arint any allredey if you stell makeing them
park72truck is offline   Reply With Quote
Old 05-11-2012, 12:22 AM   #202
Captainfab
60-66 Nut
I don't have any ready to ship right this moment, but I have the parts for them. I'll send you a PM with payment info.
Old 07-21-2012, 12:30 AM   #203
Tucknuts
can I tuck tractor wheels?
Tucknuts's Avatar
any of these ready for sale?
My build page.... http://67-72chevytrucks.com/vboard/s...d.php?t=347666
Tucknuts is offline   Reply With Quote
Old 07-21-2012, 12:39 AM   #204
Captainfab
60-66 Nut
I'll have to take a look tomorrow to see how many I have at the shop. If I don't have enough, I can just order some more parts laser cut. Are you wanting bare steel or powder coated?
Old 08-21-2012, 06:31 PM   #205
dan468
dan468's Avatar
what size is the bolt that holds on the brake hose?
thanks
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Old 08-21-2012, 09:48 PM   #206
Captainfab
60-66 Nut
The banjo bolt should be 10mm.
thanks
Old 08-21-2012, 10:15 PM   #207
dan468
dan468's Avatar
10x?
68 C-10
Build thread
Old 12-01-2012, 06:11 PM   #208
raws67
raws67's Avatar
Request PM sent
raws67 is offline   Reply With Quote
Old 12-02-2012, 12:32 AM   #209
Captainfab
60-66 Nut
PM replied to
Old 12-10-2012, 12:19 AM   #210
leddzepp
Moderator
leddzepp's Avatar
That is correct. The rear calipers from '94-'97 F-body and the rear rotors from a '93-'96 Impala/Caprice. I'm working on a parts list for this installation.
I am confused. I went to the boneyard today to source/price all the parts to use with these brackets. I did not find any 94-97 Camaros with rear disc brakes....all of them were drum?? Were rear discs an option on these years? I did run across a 99 Camaro that had rear disc brakes, but did not pull the trigger because of the years you specified here.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 12-10-2012, 12:53 AM   #211
Captainfab
60-66 Nut
Rear disc brakes were not standard equipment on the '93-'97 F-bodies. I believe they were typically found on the Z28's. The '99 Camaro has a different caliper and rotor than the '93-'97's.
Old 12-18-2012, 04:28 PM   #212
68 TT
Still plays with trucks
68 TT's Avatar
Originally Posted by rocknss View Post
Would the 93-97 Camaro Master work in my 69 Chevy Suburban?
The 93-97 Camaro used very small single piston front calipers. I wouldn't use it. The fluid volume is probably too little to work properly with a larger D52 front caliper in a 4-wheel disc application. Look at the 98-2002 Camaro master cylinder instead. They used dual piston calipers up front with much more piston area so the fluid volume would be more appropriate.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-18-2012, 04:32 PM   #213
68 TT
68 TT's Avatar
The 93-97 was Z/28, Trans Am & Formula specific with it as an option on V-6 cars.
The 98-up stuff was on all the cars V-6 or V-8. Same for the front brakes. The rear on them uses an internal drum brake inside the brake rotor for the parking brake so the calipers are different with no provision for a mechanical parking brake in them. The rotor thickness is different too so they would need spacers to work on the thinner rotors the kit is designed around.
Old 12-19-2012, 12:52 AM   #214
Captainfab
60-66 Nut
Good info 68 TT
Thanks for posting
Old 12-29-2012, 01:17 PM   #215
raws67
raws67's Avatar
Received my brackets for the 93-97 Camaro brakes and they look great! Question about proportioning valve. I am replacing my M/C and Proportioning valve due to prior leakage. I bought a new M/C for 78 corvette and wonder if I should buy the proportioning valve for the same, go with stock proportioning valve or I did find one on ebay that says it will work for 67-87 trucks disk disk although they refused to answer my question when I asked if it would work for this application. If anyone else has done this swap with sucess input would be appreciated. Thanks
Old 12-29-2012, 11:33 PM   #216
Captainfab
60-66 Nut
You can try the Vette prop valve, but you may or may not be happy with the brake bias. Anymore I recommend the Wilwood #260-11179. It already has an adjustable valve in the rear circuit, so you can adjust the rear brakes to how you like them.
Old 01-01-2013, 04:21 PM   #217
king-918
king-918's Avatar
I need a set and P.M. sent
king-918 is offline   Reply With Quote
Old 01-01-2013, 11:15 PM   #218
Captainfab
60-66 Nut
PM replied to
Old 08-31-2013, 10:44 PM   #219
425HP409
425hp409
425HP409's Avatar
By 'factory cables' are you referring to the factory truck cables or the factory Camaro cables? I don't think either one will be a simple connect and work situation. I would think a combination of the two, since the Camaro cables will fit the bracket on the calipers. Then you will likely need to connect/splice those into your original truck cables. Alternately, you may be better off with made custom cables once you figure out the required lengths. If you don't have someone local that can make up the cables for you, I believe a couple of the suppliers that specialize in brake line tubes, can make them up.
I installed the kit from Captainfab, and it works great. I resolved two issues with the installation, Combination Valve and Parking Brake Cables
1. Combination valve - I used the factory 68 brake light switch, no proportioning valve and no metering valve. No metering valve needed with 4 wheel disc, and so far works great with no proportioning valve. I installed a master cylinder for 4 wheel disc so as not to have a residual check valve in the outlet of the master cylinder, which is only used on drum brakes. My truck started out as a 4 wheel drum and I had previously installed 72 disc brakes.
2. Parking Brake - My truck is a short bed, however the long and short bed trucks use the same rear cables, so my method should work for all trucks. I was able to use the Camaro factory rear parking brake cables and the factory Chevy intermediate cable. I moved the intermediate cable from the trailing arms to the inside of the frame, connecting to the Camaro cables. I fabricated new brackets for the front of the rear cables and made links to take the slack out of the intermediate cable. The photos show how I did it.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 08-31-2013, 10:48 PM   #220
425HP409
425hp409
425HP409's Avatar
Originally Posted by 425HP409 View Post
I installed the kit from Captainfab, and it works great. I resolved two issues with the installation, Combination Valve and Parking Brake Cables. My truck started out as a four wheel drum, and I had previously installed 72 front discs.
1. Combination valve - I used the factory 68 brake light switch, no proportioning valve and no metering valve. No metering valve needed with 4 wheel disc, and so far works great with no proportioning valve. I installed a master cylinder for 4 wheel disc.
Page two of photos
Charles
90 ZR1 Corvette
Old 09-01-2013, 12:04 AM   #221
Captainfab
60-66 Nut
Thank you Charles for posting this info along with those well detailed pics.
Old 09-08-2013, 07:01 PM   #222
ryserstine
ryserstine's Avatar
Iv'e read all 9 pgs. Of this post,and it looks like you don't make a set of these for a 14 bolt rearend 77 c-10. Please advise thanks
ryserstine is offline   Reply With Quote
Old 09-08-2013, 11:12 PM   #223
Captainfab
60-66 Nut
That is correct. I do not make any rear disc brackets for either of the 14 bolts. That 14 bolt is not original to your '77 C10. A '77 C20 would have a 10.5" FF 14 bolt, but a '77 C10 would have a 12 bolt.
Old 09-12-2013, 01:04 PM   #224
ryserstine
ryserstine's Avatar
thanks did not know that I think i'll be looking for a 12 bolt rearend first thankyou
Old 09-19-2013, 08:35 PM   #225
Dads79GMC
Dads79GMC's Avatar
Captainfab, I'll take a set. I will send you a PM is a minute. Thanks Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
