Old 06-27-2011, 02:30 AM   #201
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
Re: Finally starting the 68swb fleet
plugging away, stripped, honed, and painted the block, set the pistons in the wash tank over night and removed the rings No need to machine as I see it, compression was great pre dismantle, and I am planning on a 383 short block after I'm on the road and if all plays out as planned, possibly a twin turbo setup for fun bearings all looked decent, crank looks good, and all standard bore and bearings, I'm pleased to say the least too bad the block has been welded, not in a water jacket but I'm thinking someone forgot that one last bellhousing bolt, heard from a friend of course because I've never done it before myself Lots of pics, we all know I'm a total picture whore
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 06-27-2011, 02:31 AM   #202
67chevy1series
67chevy1series's Avatar
wow dirty! good thing its in good hands! keep up the work!
67chevy1series is offline   Reply With Quote
Old 06-27-2011, 02:33 AM   #203
tantrumpipeline
yeah it was surprising to find the bearing and everything actually half decent, replacing them anyway but the whole sitting in a field for 15 years in the harsh environment northern Canada gives, I half expected it
20 Duramax tow pig
52 short project
Old 06-27-2011, 02:53 AM   #204
67chevy1series
well your alittle lucky then huh?
Old 06-27-2011, 02:55 AM   #205
tantrumpipeline
hopefully, should know next week, if all the parts arrive and we can fire it up finally
20 Duramax tow pig
52 short project
Old 06-27-2011, 02:58 AM   #206
67chevy1series
its a great feeling! i thought it would never happen but then the day ariived and i started it it was one of the best things i ever seen!
Old 07-01-2011, 02:53 AM   #207
tantrumpipeline
axle, hood hinges, engine perches and latch back from blasters, prepped and painted, repaired axle seats with 1/4 inch steel machined u bolt holes to match, and painted with por 15, removed axle seals and bearings and discovered my supplier forgot my bearings so I may be somewhat on hold for the weekend, canada day everybody shuts down so it could be until tuesday until I'm rolling which really axes my big weekend plans as the forecast is no good for outdoor bodywork and my garage is slammed with parts and a non rolling frame, we'll see maybe the motor will be back on the list
20 Duramax tow pig
52 short project
Old 07-01-2011, 04:00 PM   #208
67chevy1series
lookin good! the axle looks really good the way the rust looked.... well you know it looked bad but now with primer it looks good!, i see the cab stipped in the back ground that from what i can see looks good! and the hinges and misc. parts look good to nice work tyler keep it up!
Old 07-01-2011, 04:22 PM   #209
tantrumpipeline
thanks, it's slow going, but it's going, lots of time off but always something to get in the way, was planning on having the cab fully repaired and in [rimer on the frame with the body mocked on it but that'll have to wait, need to be able to get everything in the garage to do bodywork, any luck the axle bearing will be in stock tomorrow
20 Duramax tow pig
52 short project
Old 07-01-2011, 07:22 PM   #210
67chevy1series
tell me about it, my 67 was supposed to be running (well it does run it just wont drive lol) by july hmmmm today is july 1st and m truck wont shift into drive and go!lol
Old 07-01-2011, 07:33 PM   #211
tantrumpipeline
the joys of old trucks I have to remind myself this is a hobby and a toy a lot of the time or my temper takes the fun out of it and it gets put in the penalty box as it did last spring haha
20 Duramax tow pig
52 short project
Old 07-01-2011, 07:52 PM   #212
67chevy1series
haha yeah the way i look at it, is that the truck not being done is my fault, therefore i cant get mad at the good ole bow tie because im the one wasting his time! lol
Old 07-04-2011, 12:53 AM   #213
tantrumpipeline
pretty well sums it up, got it rolling, the bearing/seal combo is 1piece SKF from napa, this is as far as it sits in, checked it and the bearing is in square and sticking out consistent all the way and napa says this isn't uncommon and will not cause problems, we'll see one day Installed the new main bearings and crank and prepped everything for assembly should be done tomorrow and in the frame with the mock tranny, then onto bodywork
20 Duramax tow pig
52 short project
Old 07-04-2011, 02:56 AM   #214
Slammed66
Needs a Big Block
Slammed66's Avatar
Dude!!!!! the roller looks killer!!!! keep it up !!!!
Ive came back to the dark side, heres my new parts hauler!!
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 07-04-2011, 03:03 AM   #215
tantrumpipeline
thanks, dark side? looks pretty nice in your 67 small window fleet, damn I'm jealous! After this one is done I am finding one like yours, long way to go but will feel like I'm really getting somewhere once the motor is in
20 Duramax tow pig
52 short project
Old 07-04-2011, 03:07 AM   #216
Slammed66
Needs a Big Block
Slammed66's Avatar
I usually hang out in the 60-66 crowd, im goin full bore on a 64 short step,
Project Tall Grass . But ive got a soft spot for 67-68 shortys.
what color is that thang gonna be????
1964 Short box
1972 K10
Old 07-04-2011, 03:11 AM   #217
tantrumpipeline
Gotcha, I love that style now from this site, I always appreciated them, but had never really gotten into them until recently, I have a soft spot for the AD series 5 windows, one day hahaha I'm thinking hot rod flatz blue metallic still but the idea of a flat champagne metallic is on the backburner
20 Duramax tow pig
52 short project
Old 07-04-2011, 06:32 PM   #218
67chevy1series
really nice roller!!! once the engine goes in you should get taller from all the weight that will be lifed off your houlders
Old 07-05-2011, 01:46 AM   #219
tantrumpipeline
hahaha I'm too tall already, hit a snag today installed the pistons and now I can't turn it over to torque the rod caps, hoping it's something minor like the main caps are over torqued, went 80 and after checking my haynes it's 65, the rings are all in as outlined and slide in fairly easy, so this is all I can think, if not it'll get torn apart and re installed tomorrow, the cam is in, and cab got flipped onto its back to prep and por 15 the underside, we'll see tomorrow not getting too fired up about it, the 15lbs over torqued is most likely the issue, installed the perches and it's just aching for the motor and mock tranny
20 Duramax tow pig
52 short project
Old 07-06-2011, 10:34 PM   #220
tantrumpipeline
well the engine gurus on the site helped me with the motor by the looks of it, will update tomorrow, but I have the whole even side of the motors pistons in backwards rookie move, gotta add red bull or monster to those late night tinkerings when I'm working, hopefully so updates tomorrow for you
20 Duramax tow pig
52 short project
Old 07-06-2011, 10:47 PM   #221
67chevy1series
this might sound weird tyler but mtn.dew, pepsi and coca cola mixed taste good and gives a kick so you can try that if you want lol
Old 07-07-2011, 01:11 AM   #222
tantrumpipeline
hahaha I may just do that, chances are if I laid off the beer with the guys I'd do a lot better and it'd save on the re check in the morning on everything
20 Duramax tow pig
52 short project
Old 07-07-2011, 02:06 AM   #223
67chevy1series
ok let me know how it goes! i cant have to much fun tonight i have home work todo for independent studies for summer school.
Old 07-07-2011, 02:15 AM   #224
tantrumpipeline
I turned one around and it will move a bit don't want to push my luck an score everything up, but 90% sure the problem is solved, hoping to get it half together tomorrow
20 Duramax tow pig
52 short project
Old 07-07-2011, 02:18 AM   #225
67chevy1series
hopefully more pics tommorow like me
