Old 11-30-2010, 01:20 AM   #201
mcbassin
Still Learning
mcbassin's Avatar
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
Man! that was some sweet sheet metal. Hard to find one that clean anywhere except in the desert states. Nice work on the shortening job. thanks for the detailed explaination.
I have always hated ginding mig welds too. It seems like the mig wire makes welds so much harder (like brinell hardness) than tig or stick welds. Only prob with tig it gets the metal so hot you may have more warpage to deal with. Stick is too porous like flux core. Keep the pics coming!
BTW, that gate looks prestine too, where did you find all this clean metal?
mcbassin is offline   Reply With Quote
Old 11-30-2010, 10:25 AM   #202
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
Originally Posted by Dieselwrencher View Post
One question I have just because I'm curious, that's all. What is your plan to get the body line straight on the rear section where it doesn't line up? I'm guessing cut and weld? Post #183, last 2 pics.
Slice and dice if I need to.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 11-30-2010, 10:31 AM   #203
drewskiren
drewskiren's Avatar
The bed was lucky sight unseen, but sold by an honest old man who couldn't use the truck any more. He told me it was straight and I believed him, flew to California and drove it back to Memphis. The tailgate is one that Chuck here on the board had, he got it from somebody who got it from Arizona, but it has a tiny overall bow so he didn't want it. I have a way to fix the bow, I'll probably knock that out this weekend.
Drew
Old 11-30-2010, 11:26 AM   #204
67cheby
67cheby
67cheby's Avatar
Beautiful, work and parts as usual nice job !!
67cheby is offline   Reply With Quote
Old 11-30-2010, 01:55 PM   #205
68 TT
Still plays with trucks
68 TT's Avatar
Great work on the bed.
What are you planning on doing to flatten out the bow in the tail gate? I have a slight bow in the one I just picked up for my 69 and was thinking of ways to fix that.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 11-30-2010, 02:03 PM   #206
drewskiren
drewskiren's Avatar
I'll post my efforts here. Basically a hydraulic ram and wood to spread out the force.
Drew
Old 11-30-2010, 02:19 PM   #207
68 TT
68 TT's Avatar
I was considering the same idea but with a long piece of heavy wall rectangular tubing I have.
A wood 4x4 like you are thinking would be better as it would flex more and allow you to compensate for the spring back the metal of the tail gate will have when you release the hydraulic pressure.
I also thought about an eyelet welded to the center of the tail gate bottom edge so it was pointing up when the tail gate was open. This way I could use the engine hoist to pull it back into shape.
I like the jack and 4x4 method better as is won't involve welding anything to the tail gate and is probably safer with less chance of damage.
Old 11-30-2010, 08:43 PM   #208
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Awesome work, keep the pics coming!
ChuckDriver is offline   Reply With Quote
Old 11-30-2010, 11:11 PM   #209
drewskiren
drewskiren's Avatar
My method for this is so simple you will laugh. It probably will only work for a small bow, so it won't be a cure all for every tailgate.
Drew
Old 11-30-2010, 11:39 PM   #210
67chevy1series
67chevy1series's Avatar
what did you do
67chevy1series is offline   Reply With Quote
Old 12-01-2010, 06:03 PM   #211
drewskiren
drewskiren's Avatar
Originally Posted by 67chevy1series View Post
what did you do
Haven't yet, Will take pics in process this weekend.
Drew
Old 12-03-2010, 10:05 PM   #212
drewskiren
drewskiren's Avatar
Started the next phase of the operation today. Pics soon to come.
Also will unbend my tailgate tomorrow with pics.
Drew
Old 12-04-2010, 12:37 AM   #213
hotrodchevy1999
Hotrodchevy
hotrodchevy1999's Avatar
nice build and good work
2017 1500 CREW CAB GMC
1997 C1500 Chevy
1971 CHEVY CHEVELLE SS 402BB :
1971 CHEVY C10 Stepside Project 71 cluncker http://67-72chevytrucks.com/vboard/s...ferrerid=89816
My Build Second Chance Suburban (SCS)http://67-72chevytrucks.com/vboard/s...d.php?t=424650
hotrodchevy1999 is offline   Reply With Quote
Old 12-05-2010, 01:55 AM   #214
drewskiren
drewskiren's Avatar
Tailgate bow fixed pictures as promised.
Drew
Old 12-05-2010, 02:06 AM   #215
classicchev
classicchev's Avatar
hope you did not push your garage wall off it foundation.
Darren
67- 72 Parts collecter
classicchev is offline   Reply With Quote
Old 12-05-2010, 02:08 AM   #216
drewskiren
drewskiren's Avatar
Here is the process:
I happen to have a concrete wall about 6 feet away from my garage wall to keep water in my neighbors yard and off of my walkway. I also have a 10 ton porta power kit that can be very handy at times. If you look closely in the pictures you can see I have 2 bows in the upper edge of my gate, one going in and one going out. I blocked the gate out from the short concrete wall with a 4 by 4 and some 2 by 4s to give me space to flex the gate past straight because the metal will want to spring back some. I hooked up the porta power, and pushed with a soft? 2 by 4 block to spread the force. The 10 ton wouldn't touch it. Resort to plan B which involves a 20 ton bottle jack (shown in pics). Now we are talking! I laid the 2 by 4 sideways to concentrate the force just on the lip of the gate. Worked like a charm on both bent places and took all of 25 minutes start to finish. There was no new damage to the gate, although I will still be working this area because the original blow did leave a dent.
Drew
Old 12-05-2010, 02:13 AM   #217
drewskiren
drewskiren's Avatar
Some after pictures to try and show the results. It's really hard to get a clear shot at it, but in person it looks perfect.
Drew
Old 12-05-2010, 02:31 AM   #218
drewskiren
drewskiren's Avatar
Just a shot of where I am now.
Drew
Old 12-05-2010, 02:32 AM   #219
drewskiren
drewskiren's Avatar
New shots of where I am headed. (The hard part begins)
Drew
Old 12-05-2010, 02:34 AM   #220
Stubbs67
Stubbs67's Avatar
that is a nice gate, not to mention, super straight, well now it is, good work
I still remember kicking the crap out of my 68's bent tail gate to close it. if I or someone stepped on it, it would bow, then when I would close it, it wouldn't latch, unless you showed it what-for
67 Short Step Project -My other wife, ya know... (she takes all my time and money and I don't even realize it)
88 Subaru wagon 4wd -Daily driver and workhorse
98 Subaru Forester S - Wife and baby wheels
My Build Thread!
http://67-72chevytrucks.com/vboard/s...d.php?t=433751
Need step tail gate and bed front, driver door, both front fenders (both are bondo'd nightmares). can trade fleetside bed parts real straight (except sides) or pay some cash (i am pretty broke)
Stubbs67 is offline   Reply With Quote
Old 12-05-2010, 11:08 AM   #221
mcbassin
Still Learning
mcbassin's Avatar
Nice fix for the bow in the gate! Thanks for sharing the pics with us.
Old 12-05-2010, 12:38 PM   #222
kyull67
kyull67's Avatar
Nice work! Can't wait to see more progress!
kyull67 is offline   Reply With Quote
Old 12-05-2010, 05:59 PM   #223
VA72C10
VA72C10
VA72C10's Avatar
Nice job on the gate!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 12-05-2010, 06:30 PM   #224
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Great build! Good work!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-05-2010, 09:56 PM   #225
drewskiren
drewskiren's Avatar
Nice work! Keep at it. When I used to work in a body shop, my old boss always had us grind down the welds with a cut off wheel because it heats up the panel less and you have more control on top of the welds. It did seem to work better after I tried it.
I do like the grinder with the cut off wheel better. I can slice the head of the weld off instead of having to grind through the whole thing.
Originally Posted by brn agn View Post
Here is an idea for you (if you have not tried it yet). I have found that grinding the welds down with a thin cutting disc on the angle grinder will prevent the metal from getting overheated. After I get the welds close to level, I finish them off with a flap disc. It may be worth a try to see if you like it better. Either way, you end up digging black stuff out of your nose and ears for the next few days!
Moving onto the flap disk now, I love that thing!
Drew
