Old 01-20-2011, 05:48 PM   #201
Dirty Doug
Dirty Doug's Avatar
Re: Extreme Powder Coating '65 C-10 Shop Truck
Looks like the one guy is really busting a$$ .
Dirty Doug is offline   Reply With Quote
Old 01-20-2011, 06:36 PM   #202
kart34
The re-pop fenders kinda suck ???? the originals were real ruff and rusty. We have a process with powdercoat to simulate the patina. Stay Tuned
kart34 is offline   Reply With Quote
Old 01-20-2011, 06:51 PM   #203
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Can't wait to see the PC process for simulating patina. Are you going to have a step by step process, or is it top secret?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-20-2011, 10:22 PM   #204
kart34
we will show the process stay tuned
Old 01-20-2011, 11:59 PM   #205
Mechanic77
Do you mind me asking....where did you get your fenders? They look like they fit pretty well
Pro Touring 1964 C10-Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=441627
Project '65 Short Step Daily Driver http://67-72chevytrucks.com/vboard/s...d.php?t=661948
Mechanic77 is offline   Reply With Quote
Old 01-21-2011, 12:46 AM   #206
Dinos63
chevy only
Dinos63's Avatar
nice work duudes!!!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 01-21-2011, 01:30 AM   #207
Delmo
Delmo's Avatar
Man I can't wait to see those wheels stuffed under there.
Delmo is offline   Reply With Quote
Old 01-21-2011, 08:10 AM   #208
kart34
77, I purchased the fenders on E-Bay the fenders fit fairly well but they do not fit the grille / header panel at all. We may have to cut these up and us the front half of the stock GM fenders.
Old 01-21-2011, 09:06 AM   #209
Dirty Doug
Dirty Doug's Avatar
Cutting the fenders in half and using the Gennie fronts will be cool! Matching the powder to patina will be a great trick. You can't let that secret totally out. The Technology challenged shops that bad mouth you and try to copy you may get a clue!!!
Just sayin...
Old 01-21-2011, 09:13 AM   #210
glos55
glos55's Avatar
Great Build Guys!!!!!! Also waiting for the new-old patina.
glos55 is offline   Reply With Quote
Old 01-21-2011, 10:12 AM   #211
Mechanic77
That's what I was afraid of....my fenders aren't too bad, but the main rust on them is on the fronts of them
Old 01-21-2011, 12:08 PM   #212
kieth
kieth's Avatar
Hey guys I need some help. We are ready to start rebuilding the stock 65 12 bolt open rear end. Were do I purchase 5x5 axles / brake drums / seals /etc?
I used the stock 6 hole axle and had a machine shop drill the 5X5 bolt pattern($75.00) turn the stem of the axle down so a 71 brake drum would fit it. Went to NAPA and bought a set of repair bearings for the outer axle bearing cost $40.00 . drilled out the back of the stock backing plate to allow brake adjustment from the backing plate instead of the drum and was ready to go the old school way.
cost 75.00 machine work, 40.00 repair bearings , 25.00 studs, 80.00 brake drums total $220.00
kieth is offline   Reply With Quote
Old 01-21-2011, 12:39 PM   #213
kart34
Kieth, I also had a local tool and die shop turn them down and re drill $100.00 Paul Teig Machine
Old 01-21-2011, 01:20 PM   #214
kart34
Welding. Putting some final touches on today.
Old 01-24-2011, 09:33 AM   #215
Dirty Doug
Dirty Doug's Avatar
Old 01-24-2011, 09:54 AM   #216
67chevy1series
67chevy1series's Avatar
it lookin good! i cant wait to see this thing drivin!
67chevy1series is offline   Reply With Quote
Old 01-24-2011, 06:48 PM   #217
kart34
Modified the front bumper mounts..... Jesse took out a 1 inch section of the frame. Just got home from Dan Pate RTE 56 Rod Shop
the grille insert is almost done and tailgate panel is finished looks way kool ... will post pics. Tuesday stay tuned !!!
Old 01-24-2011, 07:30 PM   #218
Mechanic77
I really like that I might have to do the same on my project
Old 01-24-2011, 08:20 PM   #219
64shortc10
64shortc10's Avatar
KART,
This project is SICK! How much did you cut out for the bumper?
Tony from Norcal
64shortc10 is offline   Reply With Quote
Old 01-24-2011, 09:20 PM   #220
kart34
sectioned out 1 inch
Old 01-24-2011, 10:56 PM   #221
Dinos63
chevy only
Dinos63's Avatar
Soooo cooool!!! Killer work duudes!!
Old 01-25-2011, 09:53 AM   #222
Mechanic77
Am I correct in assuming that you didn't modify the bumper it self, just shortened the front part of the frame?
Old 01-25-2011, 10:37 AM   #223
kart34
yes Jesse sectioned out a 1" piece from the frame
Old 01-25-2011, 10:55 AM   #224
kart34
Old 01-25-2011, 12:02 PM   #225
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Looking good.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
'65, c-10, carter hickman designs, extreme powder coating
