Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 07-02-2011, 08:22 PM   #201
Wildstreak
"something witty here"
Wildstreak's Avatar
Re: 72 Suburban Build
I hear ya, thats why I asked, every accuair system I had seen so far had used the e-level. How much was the accuair kit if you dont mind saying?
Looks great on the floor, love the way the accuair rises and lowers.
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 07-02-2011, 08:28 PM   #202
bruin_d
bruin_d's Avatar
I don't remember to be honest. I have the switchspeed with a 5 gallon tank and single compressor. I got it from Nate at Porterbuilt. I'll see if I can find what I paid for it.
bruin_d is offline   Reply With Quote
Old 07-02-2011, 08:41 PM   #203
project 67 sub
project 67 sub's Avatar
looking good bruin d
project 67 sub is offline   Reply With Quote
Old 07-02-2011, 10:40 PM   #204
mosesburb
I had a V-8
mosesburb's Avatar
Very cool!!
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 07-02-2011, 11:50 PM   #205
jmedero
jmedero's Avatar
Nice man. You figured out gas filler neck yet?
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 07-02-2011, 11:58 PM   #206
67cheby
67cheby
67cheby's Avatar
Awesome
67cheby is offline   Reply With Quote
Old 07-03-2011, 12:22 AM   #207
jmedero
jmedero's Avatar
I hear you on the no room on the budget for the elevel set up. I did the Accuair manifold and wired it into a new AVS 7 switch box I had. It took some research to get the male end of the harness... found out its a Molex brand plug. The rest I just had to figure out.
That controller looks slick though. I will do the Accuair rocker set up when the budget allows.
Juan
Old 07-04-2011, 08:27 PM   #208
bruin_d
bruin_d's Avatar
The Accuair rocker is pretty sweet. I was playing with it today and found all kinds of different stuff it does.
Old 07-04-2011, 08:38 PM   #209
bruceman1968
bruceman1968's Avatar
Awesome build, looks great!!!! subscribed.
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 07-04-2011, 09:02 PM   #210
bruin_d
bruin_d's Avatar
Originally Posted by bruceman1968 View Post
awesome build, looks great!!!! Subscribed.
thanks!!!!
Old 07-06-2011, 09:25 PM   #211
bruin_d
bruin_d's Avatar
Well I got a good start on mounting the brake setup today. I started by trimming the factory bracing out of the way so i have a flat surface to mount to. Next I trimmed up a piece of 1/4" steel to weld in there. This gives me a good base to weld to and strengthens the firewall. Finally, I tacked the assembly up there to see where I was at. I have been having a tough time trying to find out how far it needs to be from the firewall to clear everything so i figured, what the hell, just tack it up there and see and go from there. It looks like I need to move it out about 5/8" to be able to get the booster in there. Tomorrow I'll re-measure everything, make some mounting brackets so it can bolt in and then finish welding it all up. If any of you guys have opinions, PLEASE SHARE THEM!! I won't be offended. This is the first time I've done anything like this so its all uncharted territory.
Old 07-06-2011, 09:46 PM   #212
Scottshotrods
looking good
justin
Scottshotrods is offline   Reply With Quote
Old 07-06-2011, 10:08 PM   #213
bruin_d
bruin_d's Avatar
Originally Posted by Scottshotrods View Post
looking good
justin
Thanks. That's how I interpreted your description of how to do it.
Old 07-06-2011, 10:25 PM   #214
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks like she fits in there pretty good.. Did you get the remote fill also?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-06-2011, 10:32 PM   #215
bruin_d
bruin_d's Avatar
Yes I did.
Old 07-06-2011, 11:42 PM   #216
jmedero
jmedero's Avatar
Nice. I was wondering how it all fits in there. So when you weld the plate in, the bracket gets bolted to that? How does it bolt to it? Wouldnt the pedal placment dictate were it needs to be mounted?
Juan
Old 07-07-2011, 06:16 AM   #217
bruin_d
bruin_d's Avatar
Juan
I'm going to cut up two pieces of metal,'drill some hole in it, and weld them to that plate that I put in there. If you look at one of my previous pictures that I just copied and pasted off of Scott's Hotrods website you can see where the bolt holes are in the pedal assembly.
Pedal position does dictate where it needs to be a little bit but you kind of need to find a happy medium between having room for the steering column, having room for the booster, clearing the gas pedal, clearing the ignition switch, etc.
Old 07-07-2011, 03:56 PM   #218
bruin_d
bruin_d's Avatar
I finished the mount, got it tacked up, and bolted everything else on to make sure I brought out enough but not too far for clearance. It came out perfect! Now I just need to finish welding it up. I'm very happy with how it has come out so far.
Old 07-07-2011, 07:13 PM   #219
BlackTopMotors
Looks Cool! Any tips on adding brake fluid?
BlackTopMotors is offline   Reply With Quote
Old 07-07-2011, 07:36 PM   #220
bruin_d
bruin_d's Avatar
I have a cool billet remote reservoir for it. Ill post some pics of it after i finish polishing it. I'm still trying to decide where to mount it. I'm considering mounting in under the cowl right now. We'll see though.
Old 07-07-2011, 07:39 PM   #221
bruin_d
bruin_d's Avatar
Here is a pic from Scott's Hotrods website of what I got.
Old 07-07-2011, 11:02 PM   #222
kev2809
low n' slo
kev2809's Avatar
cool setup man...are you shaving your firewall right now too?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 07-07-2011, 11:18 PM   #223
bruin_d
bruin_d's Avatar
Yes. I'm probably about 90% done with smoothing it out. I just need to plug the speedo cable hole and the e-brake cable hole and its smooth. Then probably about an hour more of sanding and its done.
Old 07-08-2011, 05:23 PM   #224
bruin_d
bruin_d's Avatar
I finished up the brake assembly today. I had the modify the stock dash/steering column support. Everything is all painted and ready to go. My new Lokar shifter is here too. After looking at my nasty steering column and trying to figure out how to make it look good, I ended up saying screw it, called up Justin at Scotts Hotrods, and ordered a new Ididit tilt column with the billet firewall mount.
Tomorrow I'm going to work on brake lines and putting the dash back together.
Old 07-09-2011, 12:46 AM   #225
instgatr
instgatr's Avatar
Honestly I can't tell you why we panic at the sight of differentg colored wire.
instgatr is offline   Reply With Quote
