Old 01-11-2012, 04:11 PM   #201
bollybib
bollybib's Avatar
Re: Jim's 1969 Custom/20
LEAKS (7 of 7)
Lookin' a whole lot better underneath now....
Name:  100_6310 45pct.jpg
the damage .....
Radiator hose……………..……$..23.69
Engine paint………………....…….…6.46
Timing cover seal……………..….14.00
Oil pan gasket set…………………29.10
Damper repair sleeve……….……11.90
Lock washers……………………..….0.97
Hose clamps………………………..…3.76
Hardware………………………....……0.65
Fuel pump………………….…...……24.77
AT filter kit……………………….....15.08
Trans fluid………………………....…26.90
Total………………………....…….$.157.28
Peace and have a nice day...Go Drive Your Truck !
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 01-11-2012, 04:22 PM   #202
litew8
litew8's Avatar
Jim has been busy! Nice details applied and everything looks A+
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 01-11-2012, 05:26 PM   #203
treveiger
treveiger's Avatar
Looks great man!
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 01-11-2012, 11:48 PM   #204
oldman3
oldman3's Avatar
Well, I see the new year hasn't changed you any. Just as precise as always. Everything looks great......Jim
oldman3 is offline   Reply With Quote
Old 01-12-2012, 12:37 PM   #205
bollybib
bollybib's Avatar
Thanks. I'll be able to see my timing marks easily now and I'm glad to be rid of all that oily mess.
Originally Posted by treveiger View Post
Looks great man!
Howdy Trev. Lots cleaner now, that's for sure !
Hi Jim, Not much change here, I guess 2012 will be more of the same ! Hope you are well and thanks for your comment. Happy New Year !
- Jim -
Old 01-12-2012, 01:23 PM   #206
Stricklinator
Stricklinator's Avatar
Great job and write-up Jim; informative and detailed as always. Let me know if you run out of projects and I'll drop off my truck at your place
Paul
1969 C/20, 307, 4-speed, rusty with manual steering and brakes!
Stricklinator is offline   Reply With Quote
Old 01-13-2012, 10:18 PM   #207
bollybib
bollybib's Avatar
Paul
Hi Paul, Damn,.,.I thought I had 'em all plugged (those pesky leaks, that is). Looks like I've still got a few drips over in the power steering department. Seems like all I do these days is work on my truck (not that I'm complaining). You can drop yours off here but I won't guarantee a return date .
- Jim -
Old 01-13-2012, 10:41 PM   #208
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Jim, doing the exact same thing (reasealing motor) did you do the rear main etc too?
GREAT writeup thanks
John
1999 Toyota Tacoma 4x4
Old 01-14-2012, 01:15 AM   #209
bollybib
bollybib's Avatar
Rear main area looked clean and dry, so I left it alone.
I'm glad you found something useful in the writeup. & BTW,your truck looks good with its new altitude.
- Jim -
Old 01-14-2012, 08:40 PM   #210
Stricklinator
You are doing great. My back surgery/pain is really slowing me down. I've had the rear brakes apart since late August and they are still not back together
Paul
Old 01-24-2012, 05:42 PM   #211
bollybib
bollybib's Avatar
BENCH SEAT (1 OF 8)
The following narrative describes the work I did on my bench seat from November 5, 2011 to January 22, 2012 ( a mere 78 days but who’s counting . . . ? )
My seat was in dire need of an overhaul. The original vinyl and cloth cover was gone on the driver side and in tatters on the passenger side. The foam where the driver sits had been worn away so I was sitting in a big pit when I drove.
Name:  100_5851 20pct.jpg
I didn’t want covers with cloth inserts like my original Custom trim level. Although the cloth may breathe better than vinyl, the stitching tends to break loose at the joint with the vinyl after a while. I really like the CST all vinyl style with the embossed scrollwork, so I went with that in the 1969 design. I obtained a few swatches for color comparision, all of which were not an accurate match with my original saddle covers. However, the color fit in adequately with my interior so I decided that was OK since I didn’t really want to spend forever searching for an exact match. I ordered the new covers from the Truck Shop. They were having a promotion at the time and I got a 10% discount. The covers are manufactured by PUI Interiors. Other than the color issue, I found them to be of good quality.
Name:  100_5830 20pct.jpg
Size:  42.5 KB............Name:  100_5833 20pct.jpg
Name:  100_5980 20pct.jpg
Repro pseudo-saddle on left, original saddle on right
My original thought was to buy new seat foam. I looked at a lot of vendor price lists and found that most all of them were in the $400 range, with a few less than that. I also looked at a lot of threads on bench seat rehab. The feeling I got was that most people who have installed reproduction foam were reasonably satisfied but several complained about the increase in ride height. I looked at a lot of pics of seats with repro foam and began to notice that they looked puffy. The original seat foam has a much flatter look to it when compared with repro foam. After thinking about this for a while, I decided that I would disassemble the seats and inspect the foam before committing four hundred bucks or so for completely new foam.
I took the seat out of the truck and removed the old covers and foam. Then I put the bare seat frame back in the truck and with a bit of ingenuity and padding, I was able to drive it like that for the duration of my seat project.
I didn’t know much about foam when I started this project. I found a local upholstery supplier and picked up a piece of 24 x 24 x 2 that felt like it would work if I decided to patch the old foam. I set it on the bare springs in the truck in different positions to see how it felt when I sat on it. When compared with the original foam, it felt much firmer.
Then I spent some time reading about foam. I found that there are two basic characteristics to look for: density (D, lb/cu ft), and firmness (F, lb/50 cu in @ 25% deflection). I did some testing on the original foam to determine its characteristics using info I found here - - - - - > http://www.pfa.org/jifsg/jifsgs4.html and here - - - - - >http://www.diyupholsterysupply.com/c...am-square.html
I decided to order several sample pieces so I could do a hands-on comparison. I ordered six 12 x 12 x 3 pieces from diyupholsterysupply.com in different densities and firmnesses.
D=1.9, F=25, 33, 40
D=2.4, F=25, 33, 40
Name:  100_5915 20pct.jpg
I found that the D=2.4, F=33 came closest to the original foam. By this time I felt that I could make the necessary repairs to the foam so I began to figure out what I needed material-wise.
- Jim -
Old 01-24-2012, 05:49 PM   #212
bollybib
bollybib's Avatar
BENCH SEAT (2 OF 8)
The next thing I did was to figure out how much foam I needed and how much and where I needed to cut out damaged areas of the original foam. I inspected the foam closely, took a lot of measurements, and made a graph of the results. I did this for both the back and the bottom.
Name:  100_5884 20pct.jpg
Size:  98.1 KB.....Name:  100_5886 20pct.jpg
Name:  100_5888 20pct.jpg
Size:  106.9 KB.....Name:  100_6125 45pct.jpg
Name:  100_6354 45pct.jpg
I calculated that I would need only three pieces to make the repairs to the back and bottom so I ordered the material as follows.
Back…….……….24 x 24 x 3, D=2.4, F=33
Bottom…………..24 x 24 x 1, D=2.4, F=33
Botttom…………16 x 10 x 6, D=2.4, F=33
Bottom…………..Burlap, 40 x 36, 10 oz
- Jim -
Old 01-24-2012, 05:52 PM   #213
bollybib
bollybib's Avatar
BENCH SEAT (3 OF 8)
While waiting for the material to arrive, I experimented with ways to cut and shape the foam. I made a saw with some wood and an old fine-toothed band saw blade so I could make long cuts through the foam. My girlfriend bought me an electric knife that she found in a thrift store (she’s awesome !). I found that a 50 grit disc on my angle grinder worked reasonably well for shaping the foam (it makes a mess, be sure to wear eye protection and a face mask when doing this). It was a bit grabby but I learned to use a light touch to avoid that.
Name:  100_6061 45pct.jpg
Size:  91.0 KB.....Name:  100_6063 45pct.jpg
Name:  100_6101 45pct.jpg
- Jim -
Old 01-24-2012, 05:55 PM   #214
bollybib
bollybib's Avatar
BENCH SEAT (4 OF 8)
When the new foam blocks arrived I went to work on the back. I first removed the large damaged area at the driver side with the saw and the electric knife. Then I glued in the new 24 x 24 x 3 foam block. I took the electric knife to rough out the shape, and worked it to final contour with the grinder. After I got it to shape, I installed the back cover.
Name:  100_6069 45pct.jpg
Size:  84.3 KB.....Name:  100_6073 45pct.jpg
Name:  100_6097 45pct.jpg
Size:  89.6 KB.....Name:  100_6103 45pct.jpg
Adhesive that I used - - - - - > http://solutions.3m.com/wps/portal/3...er-77/Super77/
Then I did the same for the bottom. However, I ran into a few problems here.
1. My arrangement of new blocks that I glued in wasn’t good. It was hard to glue up and left gaps.
2. I didn’t cut deeply enough into the damaged area on the surface.
3. I didn’t have decent templates to follow for shaping. I mickeymoused one out of cardboard but it was too crude.
4. The firmness of the new foam felt softer than the original. I set the new cover over the foam and sat on it and I could feel the difference in firmness (but, the back felt OK so I left it alone).
Name:  100_6135 45pct.jpg
I decided to order foam at the next highest firmness level (F=40) and redo the bottom. The first foam piece that I got from the local supplier looked to be the right choice now, so I decided to use it. I ordered one new piece of foam
17 x 12 x 6, D=2.4, F=40
- Jim -
Old 01-24-2012, 05:59 PM   #215
bollybib
bollybib's Avatar
BENCH SEAT (5 OF 8)
While waiting for my order to arrive, I made a few repairs to the bottom seat frame.
The long driver side bolster spring was broken and the short one was missing. I couldn’t find anyone that sold the long one, and I had no luck in the Parts Board, either. I ended up splicing the broken pieces together with some steel tubing and brazing them together. Hopefully that will hold it. I found that LMC sold the short piece so I ordered it from them.
Name:  100_5992 20pct.jpg
Size:  84.7 KB.....Name:  100_6339 45pct.jpg
One of the hog ring attaching brackets had broken loose from its weld. Since I don’t have welding capability, I used a small u-bolt to clamp it in its original position.
Name:  100_6157 45pct.jpg
Size:  86.7 KB.....Name:  100_6158 45pct.jpg
I also cleaned and lubricated the seat tracks and adjusted the wire linkage so that the seat moves forward and back and locks in place easily like it should.
- Jim -
Old 01-24-2012, 06:02 PM   #216
bollybib
bollybib's Avatar
BENCH SEAT (6 OF 8)
The new foam took a while to arrive (Christmas holiday shutdown at the foam factory). After I fixed the seat frame I made accurate templates to help me shape the bottom. I made one horizontal and one vertical template using illustration board. I took many measurements to get accurate shapes.
Name:  100_6312 45pct.jpg
Size:  94.0 KB.....Name:  100_6313 45pct.jpg
Name:  100_6318 45pct.jpg
Size:  83.3 KB.....Name:  100_6356 45pct.jpg
- Jim -
Old 01-24-2012, 06:05 PM   #217
bollybib
bollybib's Avatar
BENCH SEAT (7 OF 8)
Finally the foam arrived and I went to work on the bottom once again. I cut out the first repair and glued in the two new blocks.
Name:  100_6328 45pct.jpg
After the rough shaping was done, I set the foam on the frame and I found that helped a lot. Once I had the bolster channels cut in, the shaping moved along nicely. The templates made a big difference, guiding me in the right direction while shaping.
Name:  100_6335 45pct.jpg
After the shaping was done, I glued in a section of burlap on the seat bottom where it meets the springs similar to the original construction.
Name:  100_6337 45pct.jpg
Finally the bottom was ready and I installed the cover over it after letting it sit out in the sun to soften up.
Here is the pile of scrap left over from this project ( no, not the Vette under the cover, the stuff on the hood ! ).
Name:  100_6349 45pct.jpg
- Jim -
Old 01-24-2012, 06:09 PM   #218
bollybib
bollybib's Avatar
BENCH SEAT (8 OF 8)
And here is the finished product.
Name:  100_6355 45pct.jpg
Size:  93.5 KB...Name:  100_6356_00 45pct.jpg
The inaccurate color reproduction is apparent in these pics. Maybe someday someone will get it right. The cover isn’t all that hard to change out, it’s the foam that took all the work. Still, it’s a damnsight better than before !
I think I got an excellent return on the dollar for this project, even when I include the cost of the foam samples and discarded first bottom repair.
Seat foam from local supplier….…....19.05
Seat foam samples from diy.com.…..41.10
Seat foam……………….…………............54.68
Seat foam (firmer)………………........….28.55
Subtotal: seat foam……………………..........………$.143.38
( way cheaper than all new foam @ $400 ! )
Seat covers………………….……………................……239.08
Spray adhesive, silicone……………………............……18.69
Brazing wire and flux…………………….….…...............16.16
Bolster spring………………..……….................……………4.59
Hardware for seat frame repair………………..........…..1.89
Hog ring pliers…………………………………...................12.93
Total………………………………..……..................……$.436.72
Peace.
- Jim -
Old 01-24-2012, 06:51 PM   #219
oldman3
oldman3's Avatar
Damn Jim, that was an excellent write up, and you seat turned out beautiful. I've always wondered which foam made the best support and this sure helped. I may have missed it in the write up, but what brand spray adhesive did you use, and were you happy with how it work? Again great job....Jim
Old 01-24-2012, 10:20 PM   #220
jaydelriotx
jaydelriotx's Avatar
Great topic!
jaydelriotx is offline   Reply With Quote
Old 01-24-2012, 10:25 PM   #221
bollybib
bollybib's Avatar
Hi Jim & Happy New Year ! I used 3M Super 77 http://solutions.3m.com/wps/portal/3...er-77/Super77/ . It's readily available at home improvement and hardware stores. Besides, foam, it works great for fabric. Can't say from personal experience how long it will hold up but I can tell you that it is stronger than the foam or fabric itself. It's some sticky sh*t.
Nice to see Jimbo's truck go ttt recently. Good job !
- Jim -
Old 01-24-2012, 11:59 PM   #222
oldman3
oldman3's Avatar
Thanks for the info Jim. I've heard good things about the Super 77 stuff, will have to try it on some small jobs. Thanks again about Jimbo's truck....Jim
Old 01-25-2012, 05:42 PM   #223
bollybib
bollybib's Avatar
Originally Posted by jaydelriotx View Post
Great topic!
Glad you enjoyed it.
- Jim -
Old 01-25-2012, 05:49 PM   #224
bollybib
bollybib's Avatar
I made a few test glue-ups before I committed to the Super 77. I found that the joint remains flexible and is not easily detected by feel. If you try to tear the joint apart, the foam will tear somewhere other than the glue joint.
- Jim -
Old 01-27-2012, 01:03 AM   #225
treveiger
treveiger's Avatar
Like always great write up!
