Old 03-22-2013, 06:18 PM   #201
Xeen
Xeen's Avatar
Re: 1968 Chevrolet SWB Stepside Restomod
Originally Posted by 67cheby View Post
WOW, that is some top quality bodywork on the rear fender !
Haha yeah that guy was a winner!
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 03-22-2013, 07:24 PM   #202
Xeen
Xeen's Avatar
Here is a picture of the CPP Transmission Crossmember and Poly mount.
I'm itching to do the install.
Old 03-23-2013, 05:33 PM   #203
gdavis
gdavis's Avatar
I see a weather change in the near future for you guys. Here today it was in the upper 70's. I know you don't want to hear that. But I do want you to have a nice build week end. so you can play catch up with me.
gdavis is offline   Reply With Quote
Old 03-24-2013, 11:54 AM   #204
Bomp
Bomp's Avatar
Like the crossmember
Bomp is offline   Reply With Quote
Old 03-24-2013, 12:25 PM   #205
disturbinglykool
disturbinglykool's Avatar
Gonna be sweet!
disturbinglykool is offline   Reply With Quote
Old 03-25-2013, 07:58 AM   #206
Xeen
Xeen's Avatar
I ordered a pair of 14" long, 2.5" in/out Stainless Steel Resonators so I can run straight pipes without the annoying "rifling" or "droning" sound that usually accompanies running no mufflers.
I also ordered a Billet dress up kit for my GM tilt column, it comes with the tilt arm, hazard knob, and shift arm knob.
Old 03-26-2013, 05:25 PM   #207
gdavis
gdavis's Avatar
Keep it up and classicparts of Kananas City want have any parts left. Your ride is going to be great.
Old 03-27-2013, 07:14 PM   #208
Xeen
Xeen's Avatar
These will take the sass out of that Gen III 5.3L Vortec and leave nothing but the attitude!
Stainless steel resonators, 14" long, 2.5" in/out, with 3" body.
Old 03-28-2013, 11:40 PM   #209
Xeen
Xeen's Avatar
It was a really nice day today, a fair 62 degrees.
I started out with ambitious intentions having no shortage of work to be done, but unfortunately the go juice was lacking.
All I got done today was inspecting the rear axle for possible repairs.
I pulled the Differential Cover off and inspected it for damage, it is wrecked and will need replaced.
I also removed the vent tube fitting because I had a feeling it was clogged and I was right, so I went down and got a new brass one with more thread, I will need to Tap the hole because from the factory they arent threaded, unfortunately I don't have a Tap that size so I will have to go get one before I can button it up.
For some odd reason I can't find a plain jane zinc coated differential cover, everything is either Chrome or Aluminum, if anyone knows where I can buy one please link me.
The Polished Aluminum cover is $75 which is a decent price but a bit much for something that won't ever be seen, by anyone but me.
I don't want a Chrome cover because on a daily driver that is a really bad place to have something Chrome, it won't get cleaned as often as it needs to stay in good shape so it will rust realtively quickly.
Old 03-29-2013, 06:12 PM   #210
Xeen
Xeen's Avatar
Hey all;
I got up late today then I went to help a friend put the serpentine belt on his Ford Escort so by the time I got home at 3pm there wasn't a lot of daylight left, so I cleaned and painted the Steering Column external firewall bracket and clamp assembly.
Old 03-29-2013, 07:24 PM   #211
Xeen
Xeen's Avatar
Hi again;
Here is a picture of the CPP bent style Trac-Bar installed, plus you can also see the CPP lower shock relocation brackets installed.
Old 03-29-2013, 07:50 PM   #212
Bomp
Bomp's Avatar
I got a cover out of the wrecking yard for $15 a few yrs back.
Cleaned it, painted good as new.
Lookin good.
Old 03-29-2013, 08:14 PM   #213
gdavis
gdavis's Avatar
looks good there mon. I see that the snow has melted and now you can start doing some serious work.
Old 03-31-2013, 06:28 PM   #214
Xeen
Xeen's Avatar
Today I assembled and Installed the Engine perch and mount assembly.
Right hand side.
Left hand side.
Center.
Old 04-01-2013, 10:57 PM   #215
Xeen
Xeen's Avatar
Hey all;
No work today, the weather wasn't cooperating.
Old 04-02-2013, 12:54 PM   #216
Xeen
Xeen's Avatar
Hey all;
I ordered a Lokar ACA-1800 shift linkage kit today.
Old 04-02-2013, 07:49 PM   #217
Xeen
Xeen's Avatar
Hey all;
The previous owner cut the fuel lines when he pulled the engine so taking Vics advice I made repairs to the fuel lines today using compression fittings.
Old 04-02-2013, 07:54 PM   #218
gdavis
gdavis's Avatar
Originally Posted by Xeen View Post
Hey all;
I am glad to see you doing some work on the old girl. How many fuel line do you need for a rear tank?
Old 04-02-2013, 08:05 PM   #219
Xeen
Xeen's Avatar
From the factory it has three lines.
Old 04-02-2013, 08:26 PM   #220
gdavis
gdavis's Avatar
Right hand side.
Left hand side.
Center.
Hey, you are not going to paint the frame before you install everything. Just asking.
Old 04-02-2013, 08:45 PM   #221
Xeen
Xeen's Avatar
I didn't remove the rust off of the inside of the frame rails only the outside and I did paint them originally but over the last year sitting outside the paint job hasnt faired very well and it will need touched up here and there.
Old 04-04-2013, 03:26 PM   #222
Xeen
Xeen's Avatar
Hey all;
The Lokar Linkage Kit arrived today.
Old 04-04-2013, 05:08 PM   #223
Xeen
Xeen's Avatar
Hey all;
I ordered a 03-07 Vortec DBW Standalone Wiring Harness from Performance Systems Intergration today, now I need to send the ECU off to be tuned.
Old 04-05-2013, 07:02 PM   #224
Xeen
Xeen's Avatar
Hey all;
I bled my brakes today, ya kinda need those.
Old 04-05-2013, 07:21 PM   #225
Bomp
Bomp's Avatar
True that!!!
1968, chevrolet, restomod, stepside, swb
