Old 06-12-2013, 10:37 PM   #201
6BT 56
6BT 56's Avatar
Re: My 56 6bt 4X4 build.
Super . Thanks . I will have to take a peek when I have some time . His thread is getting huge now . A really cool build for sure .
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 06-19-2013, 06:57 PM   #202
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
The truck really looks good! Yeah, you these things move a lot of water in the cooling system for sure! Are you wanting to put a filter straight on the turbo, or do you need a pipe to get it away from the turbo and have the filter away from the engine?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 06-19-2013, 07:20 PM   #203
6BT 56
6BT 56's Avatar
Hey thanks . Yours is comming along nicely as well. Its nice once they start to look like trucks again ! I had a afe on order from summitt but it seems its on back order . going to call tonite and swich to a spectra that they say they have in stock. Maby order a fan at same time . cooling well now , even with a ratty old rad but i know once i find some traffic it will get hot eventually. hows the Excursion coming ? Thats my dream kiddie hauler as well.
Old 06-19-2013, 10:29 PM   #204
Dieselwrencher
Excursion is coming along. Ran into some issues trying to get the rear end set up. It is also missing some a/c wiring harness, and that has been a real PITA to locate. I'm trying to get the a/c lines figured out, got the trans shift cable figured out. Just have to get more time.
Ryan
Old 06-19-2013, 10:52 PM   #205
6BT 56
6BT 56's Avatar
My 1 st prob so far. Clutch linkage started to bend where it pushes in the dodge master for the clutch. Once it tweaked a few deg the push was not straight this bent the rod where it goes into the master . I guess i know what Im up to tomorrow nite !
Old 06-20-2013, 12:32 AM   #206
OrrieG
OrrieG's Avatar
Originally Posted by 1985-GMC View Post
I think Orrie did something with his in his thread.
Mine is a factory electric motor from a 58 GMC, I think they came standard with electric motors. linkage to the wiper transmissions is the same, it bolts up the same. Make sure you get the switch assembly too, it is a cable deal that actuates a slide electrical contactor on the motor.
Before I found that I used the motor out of a 62 pickup and fabricated the mount so it would work. Also had to modify the length of the arms to the transmissions. Think I used the switch assy out of the truck too.
There are threads on adapting rear door wiper motors. Not difficult once you figure out the geometry.
OrrieG is offline   Reply With Quote
Old 06-20-2013, 12:35 AM   #207
OrrieG
OrrieG's Avatar
It tends to get off topic at times and I like to give lots of detail. I have the pics and other information on my computer organized by sub systems so I can find them.
Old 06-20-2013, 06:50 PM   #208
6BT 56
6BT 56's Avatar
I did not know there were factory electric ones. I will have to look into that .
Thanks again .
Hows your truck coming along ? havent checked in i a while
Old 06-21-2013, 01:36 AM   #209
OrrieG
OrrieG's Avatar
back at it, honey-dos and a wedding got in the way.
Old 06-23-2013, 11:03 PM   #210
6BT 56
6BT 56's Avatar
Had a very good wknd. I had a fabed bumber from bak in the day on the shop floor .
It was off a fleetside truck so some tweaking was required . got that done and installed. nothing trick but the truck needed a bumper and this one looks period correct. Did something else under the bak of the truck , going to post some pics and see who picks up on it . I think youll be on it it abt a second ryan ... Lol. Going to the exh shop on the wknd. Coming along nicely .
Old 06-24-2013, 08:47 PM   #211
Dieselwrencher
What, no pics yet?
Ryan
Old 06-24-2013, 10:41 PM   #212
6BT 56
6BT 56's Avatar
Nope no pics yet . you will like this tho . My box was here from summit tonite .
I took the spectra filter out and the inner cone was broke loose in the outer cone . Imagine if i didnt notice and my turbo fount it !! Good news was the guy from summitt was super . They are sending me a AFE now . Other than that i just installed my shift boots and puttered a bit . Going to post pics asap so I can see if you have been paying attention Ryan . Lol
Old 06-25-2013, 04:27 PM   #213
Dieselwrencher
Waiting. My wife says I don't so we shall see.
Ryan
Old 06-26-2013, 12:02 AM   #214
RockTonka
RockTonka's Avatar
Originally Posted by Dieselwrencher View Post
What, no pics yet?
This ^^^^
Waiting.
And this ^^^^
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 06-26-2013, 04:31 PM   #215
Luther Grimace
Luther Grimace's Avatar
I'm ready to see those caps mounted! Where did you get those shocks? We met some folks from Canada on our Honeymoon. One was from Montreal and one was from Vancouver. I can say the Vancouver one wasn't as friendly as you have been!
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540
1992 Chevy K1500 Silverado ECSB
1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered
Luther Grimace is offline   Reply With Quote
Old 07-01-2013, 10:47 AM   #216
6BT 56
6BT 56's Avatar
So i have been joking around telling everyone I wanted to see who was on the ball and could spot the change I made to the rear of the truck after one member , oh hell ryan spotted sumtin I did wrong . So here are the pics .
This is my new rear bumper I got at Bills truck parts . Not perfect but it works well with the old work truck theme I had in mind when I started building this old girl. And i have a hitch now.
Old 07-01-2013, 10:52 AM   #217
6BT 56
6BT 56's Avatar
No another cool note we went to a buddys place for the long wknd and a friend brought up his toy. Real Cool . We were rippen around in the mid 80's. This thing is loose ! I have gone just under twice as fast as this thing goes . But this deffinately qualified as the loosest ride Ive been on , Period !
Old 07-01-2013, 10:53 AM   #218
6BT 56
6BT 56's Avatar
Oops for got the pic .
Old 07-01-2013, 03:28 PM   #219
Dieselwrencher
Heck yes that Jet boat is sweet!!!! Your bumber looks great, and good job on the shocks. Looks mucho better!
Ryan
Old 07-01-2013, 04:45 PM   #220
6BT 56
6BT 56's Avatar
I knew it wouldent take you long to spot the shocks ! Your truck is looken sweet . That boat wasent a jet ! 30% over drive 1 gear ! no rev . Revin abt 6200 with the jackshaft between the idiots , I mean passangers and the trans rite at your feet !!!
It was a killer ride . One that I dont know if I need to do again , if you know what I mean !!!
Old 07-01-2013, 09:01 PM   #221
Dieselwrencher
Yeah, it sounds like a trip for sure!!
Ryan
Old 07-02-2013, 10:38 AM   #222
brimc
brimc's Avatar
I have been wondering about driving down to Bills Truck Shop to check it out.
What is your opinion? Is it as good as it sounds?
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 07-22-2013, 11:48 PM   #223
6BT 56
6BT 56's Avatar
Bill and Rob are real cool guys to deal with . You need to keep in mind he moved in to a industrial building so there isn't much of a yard to poke around in . I think the business was at his house before . Older pics on his website show all kinds of cool stuff in the yard .
Still worth the trip if you need something tho. If you just looking to walk around I'd wate till I had a shopping list.
Old 07-31-2013, 02:49 PM   #224
Luther Grimace
I bet that boat is a blast to drive! What kind of engine is that? Looks like a backwards big block Chevy?
Old 07-31-2013, 06:29 PM   #225
6BT 56
6BT 56's Avatar
Yep its a blast ! My ears are still ringing ! Ever sat infront of a bbc at 6000rpm with open dry headers ! Yikes . On the flip side it's funny the thing will do 55 all day at abt 3200 and just hum along . Even 55 is fast by everyday boat standards.
Hows your truck doing? Im going to p u my speedo extension from napa tomorrow . Will see how that works . I did a diy fe allignment the other day . Not perfect , I think I toed it in a bit too much , but it drives a lot better now .
You ever thought abt movin your thread over to the diesel conversion section ? Seems there is a lot more for me or us over there . Not too sure how you do or if you can do that .
4x4, cummins, napco
