02-22-2022, 02:51 PM | #201 |
Re: NEW: 3/4T-1T Brake Booster System-Only Here! Finally!
Hi Frank,
Paypal sent. Thanks, Kicka |
04-17-2022, 03:35 PM | #202 |
Active Member
Ok Frank
I have to breakdown and get a booster system for my 1968 4 wheel drum truck, I want to stay as original as possible so I want a black unit, did you say I can use my original distributing/proportioning valve with your new units? Please pm me for payment Last edited by burb71; 04-17-2022 at 03:42 PM. |
04-17-2022, 05:18 PM | #203 |
Hey Frank
I have a '71 C30 with a 2002 Slivorado 14 bolt disc axle in back and Western Chassis new disc planned for the front. Is your set up with proportioning valve good for a disc/disc combo?
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
04-18-2022, 03:13 PM | #204 | |
"Trucks with Class"
***Please note the '2022 price increases. All parts and shipping costs for us have gone up about 30%. We did not raise our prices that much, but of course we did have to recoup some. Thanks, Frank Last edited by PICKMUP; 04-18-2022 at 04:43 PM. Reason: new info |
04-18-2022, 04:58 PM | #205 |
"Trucks with Class"
'2022 price: $470 shipped
04-20-2022, 10:06 PM | #206 |
Active Member
04-22-2022, 11:08 AM | #207 |
"Trucks with Class"
I got the PP. This system will come with a new compact adj dist block that mounts neatly under the MC. You may want to use clean new upper lines either
to this block or to your old one. Frank |
05-08-2022, 06:40 PM | #208 |
Looking for a booster for my 71 jimmy with 33" tires should I go with this booster master cylinder or the 1/2 ton? It has the stock front disc brakes and rear drum.
05-09-2022, 11:13 AM | #209 | |
"Trucks with Class"
Go with the 1/2T+ System listed in link. It is 30% more powerful than the OEM 1/2T and not as harsh as the big 1T. Thanks, Frank |
07-15-2022, 02:09 PM | #210 |
Looking for a booster for my 1971 K20. I am running Metric 33 inch tires and the truck is nearly daily driven. Should I order this one or the 1/2 ton version?
07-16-2022, 03:00 PM | #211 | |
"Trucks with Class"
Thanks, Frank |
08-20-2022, 08:36 PM | #212 |
Frank, Need a system for my 69 C-30 4x4 conversion with BB402, disc/drum, will need pedal end & bolt. Thanks Gary
71 C-10 SWB 1969 C-30 Custom Camper Motorhome Restoration in progress. 2020 Chevy 2500 Crew 4x4 LTZ Diesel 2015 Chevy Tahoe LTZ 4X4 2015 Diamond C 22' HD car hauler Bowie, Texas 76230 |
08-22-2022, 09:12 AM | #213 |
newly minted old timer
needing a booster set up too. 72 c20 longhorn, disc front drum year as you would guess.
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
08-22-2022, 11:31 AM | #214 |
"Trucks with Class"
TXGARY & mtdave2
I have all of the new components in stock. I will assemble and ship your systems in two weeks or less. Thanks, Frank PMs sent. |
08-22-2022, 01:12 PM | #215 |
Frank, payment sent Thanks Gary
09-13-2022, 04:10 PM | #216 |
Frank, received my brake system today, top notch service and looks great. Thanks again Gary
11-25-2022, 07:15 PM | #217 |
"Trucks with Class"
TTT for mikeEboy.
11-25-2022, 07:46 PM | #218 |
Junior Member
Thanks Frank. I would like to purchase. Let me know lead time, payment info, etc.
11-25-2022, 08:20 PM | #219 |
Junior Member
Frank, just to confirm, Disk front, drum rear. I would like black. Does your price include the custom SS lines to correct the reverse configuration, or is that additional? Does this include brackets? I need brackets.
11-25-2022, 11:07 PM | #220 |
Junior Member
Payment sent. Thank you.
12-03-2022, 05:00 PM | #221 |
I have some questions on this. I have this installed on my 72 K5. Is the master supposed to set level with the ground? Mine does not and leans down at the front. Is there anything to know about bleeding? It’s been bench bled but I still get a pedal almost to the floor when running. I may still have air, but I’ve used a motive bleeder a few times and pumped the pedal. Still the same issue with it nearly going to floor. All lines and brakes are new. It does not go to the floor unless it has vacuum when running. I don’t have the pressure sensor tool you include. Is this necessary to bleed?
Kirk 72 Blazer CST 4wd highlander 66 Nova |
12-03-2022, 05:28 PM | #222 |
I found the below so it appears the lean is normal. Any help with bleeding is appreciated. Stock drum rear and disc front. Also what is the bolt in the front with the rubber cover for?
https://partspro.com/blog/leed-brake...10-k10-trucks/
12-05-2022, 01:18 PM | #223 | |
"Trucks with Class"
12/7/22 SENT INSTRUCTIONS----------------------- Last edited by PICKMUP; 12-07-2022 at 04:02 PM. |
12-05-2022, 02:05 PM | #224 |
i will buy one.
i have a 72 1/2 ton front disc rear drum if that helps thx dave
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
12-05-2022, 02:15 PM | #225 | |
thx dave
