Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 10-02-2014, 01:21 PM   #201
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Attempting my first build 72 K5
Originally Posted by 72K5CSTDarkOlive View Post
I do. When the truck did run, the coolant was always a brown color. Can these things be completely cleaned and refurbished?
If so, I rather go that route.
Absolutely. Check with a reputable local radiator repair shop. You may save enough over the aluminum setup to fund the purchase of an OEM Am/Fm radio Some radiators may not be repairable though - I went through two before finding a third that was usable. On a related note, do you have the fan shroud and its lower mounting clips?
Old 10-02-2014, 01:33 PM   #202
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
Yes I do. I'm going to need to save money anywhere I can now. I'm making a big change of plans to my build.
Hint - I will have my own garage.. I'll wait to post pics before I fill everyone in.
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 10-03-2014, 09:34 AM   #203
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
If the clutch fan is good, you wont notice any real power loss. Make sure you use a good factory shroud.
Tom Vogel is offline   Reply With Quote
Old 10-03-2014, 08:32 PM   #204
72K5CSTDarkOlive
Is there way to tell if the clutch fan is good while it's off?
I still have the factory shroud.. one of the clips is missing, most likely when I removed it must of fallen off and got kicked around somewhere
Old 10-14-2014, 02:14 PM   #205
Xeen
Xeen's Avatar
Nice Blazer!
The quality of your work is top notch and you will have one of the nicest Blazers anywhere when you are done.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 10-27-2014, 06:51 PM   #206
72K5CSTDarkOlive
Originally Posted by Xeen View Post
Nice Blazer!
Thanks, Brian! That means a lot to me.
I've decided I'm going to strip the K5 down completely and have it painted. Going all out with full restore.
Old 10-27-2014, 07:01 PM   #207
72K5CSTDarkOlive
I've been busy and haven't posted in a while. I have quick update and will have more this upcoming weekend.
I moved into my new place that has it's own garage. First thing I'm doing is making it shop ready to fit the rolling chassis in while the body is at the body shop.
I built this pulley system to hold the top above the garage door. I can walk underneath it without hitting my head. Gives me plenty of clearance
Old 11-10-2014, 12:57 AM   #208
72K5CSTDarkOlive
I've made the decision to go all out. The body and panels will be stripped and painted Dark Olive, like the original.
I've made some progress in the disassembly process.
Old 11-10-2014, 01:00 AM   #209
72K5CSTDarkOlive
more pics
Old 11-10-2014, 01:24 AM   #210
Gillnetter
Gillnetter's Avatar
Your blazer looks really solid.
Keep up the good work.
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash
1972 SWB C-10 Highlander Blue/White
1972 Canadian 2wd Jimmy light olive
1970 SWB 4x4 4 speed 307
Gillnetter is offline   Reply With Quote
Old 11-10-2014, 03:51 AM   #211
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Looks solid! Don't let the neighborhood assoc give you grief
As for the door strikers, were these bolted into threads/nutserts that are somehow affixed to the pillar? On pickups there is a backing plate which will drop into the cab when the striker bolts are removed but not sure if K5's are the same. I have a fresh set of parkerized strikers I want to swap in but am afraid to drop the backing attachment (whatever it is) if loose then have to remove the rear panels etc. to retrieve them.
Old 11-10-2014, 08:10 AM   #212
notsolo
notsolo's Avatar
Looking good, The body looks good already, she is going to be a stunner The hard top has an unusual metal receiver for top of window? .... also ( the radiator in the photo, looks like a replacement to me, not Original.)
notsolo is offline   Reply With Quote
Old 11-10-2014, 10:36 AM   #213
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Man that is a really nice tub. This is a very worthy candidate.
Old 11-10-2014, 01:21 PM   #214
72K5CSTDarkOlive
Unusual metal receiver - I'm not quite sure I understand what your referencing. I'm an amateur so sometimes I need things explained or even better pictures with arrows pointing the part.
What's the best way to tell if it's the original radiator? Is there serial number or something I could reference. If it's not the original, I might as well order a new one of those brass/metal ones that ClassicHeartbeat instead of spending just as much money restoring an aftermarket one
Old 11-10-2014, 01:26 PM   #215
72K5CSTDarkOlive
It's about 3 weeks away from being completely out of the driveway so the neighbors will be relieved.. haha The body and all the panels will be at the shop and I'll move the rolling chassis into my slim garage
I'll have to go home and check on the door strikers and get back to you on that.
Old 11-10-2014, 01:29 PM   #216
72K5CSTDarkOlive
@Tom @notsolo @Gillnetter and Pete
Thanks a lot for the compliments. I have my ups and downs with this, but I love working on it and I just keep telling myself, when this is all done, I will have one sweet looking K5 that will last a lifetime.
Old 11-10-2014, 02:30 PM   #217
72K5CSTDarkOlive
Updating with some more pics
Rims powder coated rally silver
Cleaned up the hubs caps and rings
Had the hub cap bolts Zinc plated Clear
Name:  hub cap bolts 2.jpg
Went with the white letters facing outward
Name:  rim tire 1.jpg
Old 11-10-2014, 02:32 PM   #218
72K5CSTDarkOlive
Rear Axle powder coated (60% gloss black)
Name:  rear diff 2.jpg
Had the Bolts Zinc plated Clear
Name:  diff bolts.jpg
Old 11-10-2014, 05:03 PM   #219
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Wow that looks great. I'm really digging the zinc coating.
Old 11-11-2014, 06:47 AM   #220
notsolo
notsolo's Avatar
Looks like metal channel's on the hard top where the top of the window would fit. ( With window cranked up) never seen this before, maybe this is single wall top specific.
Old 11-11-2014, 11:08 AM   #221
IronCanine
I'm trying....
IronCanine's Avatar
Been following you since the start. I think it's awesome that you're going all the way....but those axle shots...Wow...they definitely deserve an attaboy!
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 11-12-2014, 03:37 PM   #222
72K5CSTDarkOlive
I checked out LMC to see if this is a part they sell and they have them for both the single and double wall tops.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=13
Old 11-12-2014, 03:43 PM   #223
72K5CSTDarkOlive
Thanks! The frame is going to get the same powder coating done, too (60% gloss black)
I really like the 60% gloss black.. It's not to glossy and not too plain either. right in the middle.
I read through your build. The body work you're having to deal with is impressive. I don't think I could take something like that on.
Question - do the doors on our trucks separate or was this cut?
Old 11-12-2014, 03:48 PM   #224
72K5CSTDarkOlive
I've noticed a lot of guys use these support bars between the door jams.
What does this do? Is this something I need to have since I have the doors off and all the other panels.. I'm close to removing the body from the frame
Old 11-12-2014, 06:52 PM   #225
notsolo
notsolo's Avatar
The Tub is like a floppy noodle, the reinforcement bar holds the door opening strait as possible while repairs are done. Any welding that is needed will not interfere with the door closing correctly. Usually the bar is set when the top is on to insure correct alignment...... I think the pieces from LMC are rubber..I am about to glue the rubber door pieces to my hard top, same as the ones #15 in LMC cat- , I can get you a photo of them tomorrow.
