Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 06-13-2016, 11:21 AM   #201
First c10
First c10's Avatar
Re: Project "Hulk Jr"
Thanks Brett.
My son didn't want shiny so I let him pick the wheels. No bad. It is definitely a truck to use.
I do hope he get the trans fixed. As I am a little worried but he is going to take care of it.
I still noticed a little miss in the truck yesterday when my son and I took it for a ride. Today the front end gets aligned before I drop off at the trans shop.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 06-13-2016, 02:57 PM   #202
First c10
First c10's Avatar
Just a quick picture before I dropped the truck off at the alignment shop.
GO GO!!!
Old 06-21-2016, 03:25 PM   #203
First c10
First c10's Avatar
Well guys got "Jr" back home yesterday. It was a bad torque converter. I did find 2 bolts that are not the ones I installed. So I will change them to make sure they are correct and same. A few scratches on the crossmember and driveline. I will also need to adjust the shift linkage but other than that not to bad for him doing the work for no charge. Some would have said bring back the defective one and I will give you a replacement.
Now it's back to getting the bumpers and inner fenders on and working on the door mechanisms and Windows regulators.
Oh and I am going to raise the bed 1/4" because the body lines are off after installing the body/cab bushing mounts. On and a passenger mirror glass cut.
GO GO!!!
Old 06-21-2016, 04:17 PM   #204
lowrodderchev
lowrodderchev's Avatar
awesome glad they got it figured out. shes looking pretty sweet
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 06-22-2016, 02:02 AM   #205
swamp rat
swamp rat's Avatar
Awesome!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 06-22-2016, 10:35 AM   #206
7dee2
7dee2's Avatar
Sahweet, smooth sailing and no weirdness from here!
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 06-28-2016, 12:30 PM   #207
First c10
First c10's Avatar
Right Brett... I hope so....
I am going to order a fan shroud. Just so I can get this straight the stock fan shroud dimensions are
LMC number and descriptions
32-2820 SBC V8 W/O AC 5-7/8"
32-2825 SBC V8 AC 5"
32-2826 SBC 4x4 8-7/8"
GO GO!!!
Old 06-28-2016, 10:59 PM   #208
First c10
First c10's Avatar
Ok so since I moved the motor forward 2-1/4" and added a 2-1/4" fan spacer. The back edge of the fan blade to the radiator is 3-7/8. So if I remove the fan spacer it should be 3-7/8" + 2-1/4" = 6-1/8". A factory non AC c10 fan shroud is 5-7/8". An AC shroud is 5". I think the non AC shroud at 5-7/8" will work best. What do you think? As I want to order is asap.
GO GO!!!
Old 06-29-2016, 11:24 AM   #209
7dee2
7dee2's Avatar
More food for thought? The BB shroud on the K30 measures 4-1/2" and is running the larger 4-core 3-3/4" mounts with a 1-3/4" fan spacer on the short water pump. Blue runs the same 4 core arrangement with a 5" shroud hope that helps Scott.
Brett
Old 06-29-2016, 05:21 PM   #210
First c10
First c10's Avatar
Thanks Brett,
I ordered the HD cooling non AC shroud. The difference is just the flat flange. If I need to make it less than 5-7/8" I can trim the flange around the fan. I am going to remove the spacer I installed to put it back to a stock serpentine system.
GO GO!!!
Old 07-01-2016, 12:15 PM   #211
First c10
First c10's Avatar
Ok so I was trying to figure out what is wrong with the my tach. I have the correct wires connected. bit noticed that i do not have anything connected to the center post which I think is a ground.
Can anyone confirm that the post should have a ground wire on it?
GO GO!!!
Old 07-08-2016, 11:19 AM   #212
First c10
First c10's Avatar
Ok so I took a video of the truck sound after the carb and timing was adjusted. Starts great and sounds good. After I shot the video. I fixed the tach. I had it wired backwards. All good now.
sound of the trucks exhaust
My son and I took it for a drive yesterday about 30 miles. Got up to highway speeds. Ran great.
I just have to get the fan shroud installed. I ordered it from LMC. plus a few other odds and end. I received a large box with only the little stuff no fan shroud. So I called them and they said "it should be in there" and asked me to "make sure I check the bottom". ?????????
(I am not going to say anything more!!!!!)They did say "they would ship it out" so hopefully I will see it next week.
Rock on guys!!!
GO GO!!!
Old 07-09-2016, 12:42 AM   #213
swamp rat
swamp rat's Avatar
Sounds great! It struck me as "The Resonator" when i first heard the sound clip.
Well i hope you get the shroud deal worked out, maybe send customer service a picture of the box??
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 07-09-2016, 09:34 AM   #214
7dee2
7dee2's Avatar
The mean green machine sounds great!
I grounded my tach center post because it was not mounted to the tins/dash which should supply your ground. It wouldn't hurt to run a temp wire to see if it helps. It appeared that it was working very little. Perhaps it is getting too much signal and may require a filter? Mine in my build thread is an original and is hooked to an HEI w/o a filter but it is slow to respond and I'm wondering if the performance could be better with less signal?
It is an 8cyl tach right?
Brett
Old 07-10-2016, 11:47 AM   #215
First c10
First c10's Avatar
Hey guys,
I took and switched the wires and the tach works now. I guess I just switched the wires when I built the harness. I am also running a HEI with no filter and seems to be fine.
I did get a suprise yesterday from fedex.
But I think I am going to finish the few odds and ends before I start the EFI swap.
Happy Sunday
GO GO!!!
Old 07-10-2016, 12:02 PM   #216
Birdman72
Awesome, keep us posted on the install of the efi. I hope you have better luck with the FCC than me. I am sending it back for the 2nd time to c if they can fix vent problem.
Birdman72 is offline   Reply With Quote
Old 07-10-2016, 12:37 PM   #217
First c10
First c10's Avatar
Sorry to hear you are still having problems. Let me know what they find. I did put a return to the tank but I want to make sure it's working before I hook it up to the tank as I don't want it to just overflow to the tank the whole time.
GO GO!!!
Old 07-10-2016, 01:56 PM   #218
Birdman72
Ya I'm hesitant on hooking up vent to tank . I'm afraid it will just fill with gas and not vent properly. The guys at fitech say the vent is going to put gas out due to the FCC being hot or fuel sloshing around. I haven't seen any post by Coopdog I wonder how is setup is still working?
Old 07-11-2016, 10:20 AM   #219
7dee2
7dee2's Avatar
Tach is working, fuel injection showed up, life is good!
Brett
Old 07-11-2016, 12:44 PM   #220
First c10
First c10's Avatar
Yep just waiting on the fan shroud.
Thanks for the comments guys.
I will keep you posted.
GO GO!!!
Old 07-16-2016, 02:59 PM   #221
First c10
First c10's Avatar
Finally got the fan shroud and installed it yesterday. I had to change the fan as the one I had was a 19.5" 5 blade. I needed a 18"
GO GO!!!
Old 07-16-2016, 03:04 PM   #222
First c10
First c10's Avatar
Driver side. Now I can cut down the top radiator hose to fit since it won't hit the fan.
Does any one know what the span of a stock temperature gauge is? Like 150-250 degrees.
GO GO!!!
Old 07-19-2016, 01:32 AM   #223
First c10
First c10's Avatar
Drove the truck around this weekend. Well my son did as he got his license. The temp gauge pegs to H sometimes, then back to the middle. So I checked the top of the radiator from the intake 147 degrees.
GO GO!!!
Old 07-19-2016, 01:36 AM   #224
First c10
First c10's Avatar
Bottem of the radiator 95 degrees. It was also about 80 outside. But seems to be cooling fine. Just need to check temp gauge. Or replace with the original one that was on the truck before I put the tach gauge in.
GO GO!!!
Old 07-19-2016, 09:15 AM   #225
7dee2
7dee2's Avatar
Your shroud setup looks great, did you buy a new sending unit? I ask because I did and the new one reads +30 degrees hotter when tested. If not your probably right it's the gauge and I think your temp guess is pretty close on the stock gauge readings.
Brett
