Old 11-16-2019, 07:27 PM   #201
Gregski
Post Whore
Gregski's Avatar
Re: HP Tuners Tutorials - Chapter 1 - Logging
Key On - Vehicle Not Running - Systems Check
So first we look at the Engine Coolant Temp ok it's 57* F, so here are our thoughts:
  • the Channel is working / the Sensor is working
  • later we will know what should be happening at this temp, for now this is an unkown to us, but that's ok we are learning one bit at a time
looking below this Channel, at the next one Fuel System #1 Status says OL - Not Ready, our thoughts:
  • We got some sort of result in here, so at least the channel is working, that's good
  • OL must stand for Open Loop, ok we guess it's not in Closed Loop yet, we'll see what happens to this value later as the vehicle warms up and the temperature increases
Gregski is offline   Reply With Quote
Old 11-16-2019, 07:36 PM   #202
Gregski
Post Whore
Gregski's Avatar
looking at our next Channel, Barometric Pressure, our thought are
  • we have a value so we picked the right PID (Parameter ID) and the sensor is working
  • comparing the value to our iPhone Weather app, they match so it's working properly
for now, the channel below Manifold Vacuum we just want to make sure it has a value, and it is as close to zero as possible
Old 11-16-2019, 07:51 PM   #203
Gregski
Post Whore
Gregski's Avatar
now you may notice that the Barometric Pressure Channel reports in PSI instead of inHg (Inches of Mercury) hey that's Physics for you (seven different ways to say the same thing), and yes this is one of the things that you will do battle with in HP Tuners quite often, making sure you are comparing Apples to Apples and not Apples to Oranges type of thing, so simply right click that Channel select Units and choose the format you desire
Old 11-16-2019, 08:02 PM   #204
Gregski
Post Whore
Gregski's Avatar
the Intake Air Temp channel is next, and this one can get skewed like in my case cause my truck has been parked in the shade all day so it shows a temp a few degrees below my iPhone Weather app
So you knowing this, maybe use a local indoor outdoor thermometer barometer temp gauge thingie to get a better reading of the local air temp, or park your truck in a different spot, you get the idea
Old 11-16-2019, 08:05 PM   #205
Gregski
Post Whore
Gregski's Avatar
Mass Airflow Sensor shows a perfect ready to go Key On engine not running reading of 0 hertz
Old 11-16-2019, 08:14 PM   #206
Gregski
Post Whore
Gregski's Avatar
for the Engine RPM we just expect to see a value of 0 to prove the tach signal is coming through
Old 11-16-2019, 08:20 PM   #207
Gregski
Post Whore
Gregski's Avatar
same goes for the Timing Advance channel we don't expect to see anything above 0 with just the key on and the engine not running, but seeing a zero is a good sign means we picked the right PID (Parameter ID) and there is a signal on the line
Old 11-16-2019, 08:23 PM   #208
Gregski
Post Whore
Gregski's Avatar
and both O2 Voltage sensors are perfectly in the middle of .100 and .900 volts with the key on, and the vehicle not running
Old 11-16-2019, 08:27 PM   #209
Gregski
Post Whore
Gregski's Avatar
now I would be lying if I told you I wasn't genuinely concerned about the low Control Module Voltage even if this is key on engine not running, something may be draining my battery here and low battery voltage can brick your PCM when you are flashing it
Old 11-16-2019, 08:38 PM   #210
Gregski
Post Whore
Gregski's Avatar
OK, let's use our Basic Channel config to evaluate the second of the three vehicle conditions:
1. Key on - vehicle not running
2. Vehicle Running - Open Loop
3. Vehicle Running - Closed Loop
Old 11-16-2019, 08:41 PM   #211
Gregski
Post Whore
Gregski's Avatar
Vehicle Running Open Loop - Systems Check
So now that the truck is running we see the presence of Manifold Vacuum, we observe that our value is now well above 0
We see a similar result for the Mass Airflow Sensor
Obviously Engine RPM has climbed as well, though we don't know if it's where it should be yet, but that's ok for now, we are learning
likewise we have a Timing Advance that is greater than zero
Old 11-16-2019, 08:53 PM   #212
Gregski
Post Whore
Gregski's Avatar
now we see an interesting condition regarding our two O2 Sensors Voltage, it appears it went from middle of the road around .450 with the key on to above .900 with the truck running and warming up, later we will learn that this reflects a rich condition, but since the rig is warming up this is acceptable (think choke on)
Old 11-16-2019, 08:56 PM   #213
Gregski
Post Whore
Gregski's Avatar
and finally the Control Module Voltage looks much better, with the engine running, it is above 14 volts
Old 11-16-2019, 08:59 PM   #214
Gregski
Post Whore
Gregski's Avatar
Lastly, let's use our Basic Channel config to point out the channel value differences in the final of the three vehicle conditions:
Old 11-17-2019, 01:52 PM   #215
Gregski
Post Whore
Gregski's Avatar
I hope you stuck it out this far, as things began to get interesting. I pointed out earlier the importance of the Engine Coolant Temp and here is the first example of its cause and effect.
When the temperature reaches 131*F notice what happens in the Fuel System #1 Status channel below it?
The status changes from OL - Not Ready to CL - Normal CL meaning Closed Loop now.
Old 11-17-2019, 02:02 PM   #216
Gregski
Post Whore
Gregski's Avatar
lets take a deeper dive and see what exactly caused that switch from Open Loop to Closed Loop
We know all of our configuration settings come from the VCM Editor so we fire it up and go to Engine \ Fuel \ Oxygen Sensors and look under the Closed Loop Enable heading where we find the ECT vs. IAT table (highlighted in pink for easier spotability that's all)
We put our mouse over it, and glance at the bottom of the screen where we find the Context Clues, which read: This table sets the coolant temperature required to enable Closed Loop in relation to inlet air temperature (IAT).
We open up that little guy, and it's not really a table as it is a list, but so be it. We quickly and easily see that once the ECT (Engine Coolant Temp) hits 131 (the big green bar) and our Intake Air Temp is above at least 50* we will turn on Closed Loop. Cool beans, so things are working as they should and now we know why.
Don't take this for granted, someday you may be troubleshooting an issue caused by your PCM never entering Closed Loop mode, so just keep that in mind please.
Old 11-17-2019, 02:17 PM   #217
Gregski
Post Whore
Gregski's Avatar
further down the list allow me to point out another cause and effect of you guessed it the Engine Coolant Temp
The engine is a little warmer now, it has reached 154* F, it's time to cause another thing to happen...
Note the drop in Engine RPM to approximately 550
Old 11-17-2019, 02:24 PM   #218
Gregski
Post Whore
Gregski's Avatar
once again lets take a deeper dive and see what exactly caused the RPM to settle in at 550
so back to the VCM Editor we go (you will find this is the common Tango you will be performing whilst dueling HP Tuners ie. going to and fro from VCM Scanner to VCM Editor and back)
Engine \ Idle \ RPM is where we find the Base Setpoint heading and the Base table lurks under it
with our mouse hovering over it, we glance below to see: This table controls the desired idle RPM vs. Engine Coolant Temperature.
This being an actual table and not a simple list, allow me to explain how I read it.
There are four conditions:
  • In Gear AC off (as in stopped at a stop sign or a red light)
  • In Gear AC on (as in stopped at a stop sign or a red light)
  • P/N AC off (in Park or in Neutral AC off)
  • P/N AC on (in Park or in Neutral AC on)
So in our case in Park with the Air Conditioning off (deleted actually) and with the Engine Coolant Temp at 154* F we should be idling at 550, and we are. High fives all the way around!
Old 11-17-2019, 02:44 PM   #219
Gregski
Post Whore
Gregski's Avatar
This concludes Chapter 1 - Logging
I hope I whetted your appetite for doing some tuning on your own or at least exploring the VCM Scanner.
If you have some channels you like to use to do your initial system checks that I have omitted please let us know, we're all here to learn.
Old 11-18-2019, 08:11 AM   #220
PGSigns
PGSigns's Avatar
I have been following along the entire time and have learned a lot. Thanks again for doing this.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-24-2019, 02:07 PM   #221
Gregski
Post Whore
Gregski's Avatar
Re: HP Tuners Tutorials - Long Term Fuel Trims Short Term Fuel Trims
Long Term Fuel Trims and Short Term Fuel Trims, yeah we all heard the terms or the four letter acronyms LTFTs and STFTs, but what are they really?
A long time ago a teacher I had would tell us to substitute a word for a term we did not know instead of defining it for us, and it worked, so let's try this, any time you see the word Trims substitute it with the word "Changes"
So Long Term Fuel Trims become Long Term Fuel Changes and Short Term Fuel Trims become Short Term Fuel Changes
You could also use the word Adjustments or modifications, or what ever you come up with that works for you.
Now some may find the following analogy or example silly, but I think it works as we all can relate to it, plus everyone enjoys a good short story.
So it's the first day of Winter and you have to get dressed for school. So you put on the usual a T shirt and some jeans (socks, shoes and underwear is assumed) so in other words your VE outfit your Volumetric Efficiency or standard outfit.
On Monday you step outside and start walking to school, soon you find it's colder than you expected but you press on.
Tuesday same thing you throw on a different T shirt but still just a T shirt and a pair of jeans and you head out, freezing your butt off all the way there.
On Wednesday you step outside in your T shirt and a pair of jeans and you say screw this I am making an adjustment and you grab a jacket and put it on and zip it up to the top (there you just made a Long Term Fuel Trim) from here on out you will bring a jacket until the weather will get too hot again. You walk to school wearing that jacket but once you get to class you are sweating, you think nothing of it.
Thursday you head outside in a T shirt, jeans, and jacket of course, but half way there you think I'm getting hot, I should unzip my jacket (A Short Term Fuel Trim change) you get to school and you are no longer sweaty like the day before, you think I think I got this
Friday morning you put on your T shirt, jeans, and a jacket but you don't zip it up today, nope the Short Term Fuel Trim has now become part of the Long Term Fuel Trim baseline if you will
now if you start walking to school and it gets too cold, starts raining or snowing, by all means you have the freedom to zip up your jacket again, making yet another Short Term Fuel Trim adjustment/change
Old 12-07-2019, 01:46 PM   #222
Gregski
Post Whore
Gregski's Avatar
Just wanted to clarify something that had me tripped up for a while and may help you. The objective is to get us thinking, in a non biased way as realists.
Do you need a Wideband Oxygen Sensor AFR Gauge to tune?
The short answer is no. The better answer is, it depends.
I bring this up for two reasons:
1. We need to understand what is controlling what as the vehicle goes through it's operational phases in order to determine for ourselves which tuning method to use and why.
2. There are many articles written on how to tune and especially many YouTube videos out there as well that do not clearly state in their title / subject which method they are using, and a beginner can spend a lot of time pulling their hair out trying to figure out why the methods differ.
Let me preface what I am about to say and tell you that I am not anti Wideband gauges I use them I run them in my vehicles, however there are Pros and Cons to using both methods.
Tuning Using the Stock Narrow Band Oxygen Sensors
PROS
  • no additional costs, you already own these sensors
  • in the end the PCM relies on and uses these sensors to operate, not the Wideband (think about that for a minute) this argument gets lost quite often in the debate
CONS
  • can't tune Open Loop state with them such as WOT
  • can't see actual ratio values in quantitative terms, ie 12.5 AFR or 15.9 AFR
You can tune 90% of your naturally aspirated engine using the narrow band method. The only thing you can't tune using the Narrow Band O2s is Wide Open Throttle aka WOT. Why did I say 90% because when it comes to street cars, our daily drivers think about it, how much time do you spend flooring it? Be honest with yourself, you probably rarely gun it with the pedal to the floor, right?
Think of the engine operation as an Oreo Cookie, the black parts being something called Open Loop and the white middle being Closed Loop. When you first start your car it is running in Open Loop, then once it warms up it enters Closed Loop (idle & cruise), then when you floor the gas pedal aka WOT you are once again in Open Loop (the other side of the cookie). In Open Loop the PCM is not relying on the stock narrow band O2 sensors, it is simply not listening to them. That is why you can not tune WOT with narrow band oxygen sensors.
Tuning Using Wideband Oxygen Sensor(s) AFR Gauge
PROS
  • able to tune entire operation spectrum (idle, cruising, WOT, etc.)
  • read actual ratio values in quantitative terms, ie 12.5 AFR or 15.9 AFR
CONS
  • additional costs (parts and installation, bung welding, etc.)
  • vehicle does not operate using Wideband sensors for input, calibration differences could impact final results
  • often times Wideband is a temporary install and not permanent
  • Wideband placement during tuning
  • technically you are always tuning in Open Loop
It is no secret that the placement of the oxygen sensor can yeild different readings. Put it too close to the collector you get one value, put it too far past the collector you may get a different value, hewk just shove it in the tailpipe you can get yet a different reading. A lot of tuners will remove a narrow band sensor and screw in a wideband in it's place, the problem with that is, it is temporary and only tells you what you got while you are on the dyno during that hour session.
I used to play Water Polo, and our team was pretty darn good. Most of our time was spent in the pool playing [ahem] Water Polo. Folks would often times wonder what made our team so good or what was the secret that our coach had, and it was that we did not do drills, we did not lift weights, we did not run laps or stairs, we just played Water Polo. We played a lot of gosh darn Water Polo, ha ha.
I like to street tune my vehicles, because I drive them on the street and not on the dyno, ha ha. When I log my data I like to log it while driving to work or log it while driving back from work, more than taking the vehicle for a random test run down roads I will seldom or never take. In other words tune for the conditions you will face not well you get the idea...
Don't get me wrong there are good dyno tuners out there, but I hope I am getting the concept through. Getting your vehicle tuned for two hours on a sunny day on Saturday morning in a guys shop with a huge fan blowing on the front grill to keep it cool with a Wideband AFR gauge shoved into the tailpipe on a two foot long stick may not exactly precisely represent the driving conditions you face on a daily basis (cold mornings, scorching hot afternoons, rain/humidity), are there any hill climbs, how about descents, etc. How about bumper to bumper rush hour traffic?
... and please don't get me started on Mail Order PCM tunes!!! hee hee
RECOMMENDATION: In the end I like to use both methods, aka the belt and suspenders solution, that way you can cross check your results and perhaps account for any discrepencies.
Old 12-07-2019, 04:36 PM   #223
DWilbur
I just received my HP tuner equipment in the mail last night. I will go back review the thread & make wire harness to power up my ECM so I can work on it on the bench while it’s raining. Until I get my engine harness reworked and my truck is ready.
DWilbur is offline   Reply With Quote
Old 12-07-2019, 05:50 PM   #224
Gregski
Post Whore
Gregski's Avatar
Is this for "Snow White" yer '71 4x4 2004 5.3L?
Old 12-07-2019, 06:17 PM   #225
DWilbur
Yes it is
