04-14-2023, 12:54 PM | #201 |
Re: 1953 3100 "Honey-do"
yeah, I'm looking forward to reducing the factory harness on my frame swap. no rear doors, no power midgate, no power sliding roof section, no power rear hatch door, and on and on. gonna be fun....ok, well not THAT much fun. haha
keep pn posting stuff, it's cool to see how you go about stuff. |
04-14-2023, 04:02 PM | #202 | |
04-14-2023, 05:58 PM | #203 |
I'm using an 04 GMC Envoy XUV. 4.2L inline 6, auto O/D with 4x4. 3.73 axle ratio.
04-14-2023, 06:17 PM | #204 |
Sorry I don't have that. I think paying $100 or so is worth it to have a complete wiring diagram in a searchable PDF for what you are about to do. I was lucky and found a 2008, 2010 and 2013 complete wiring diagrams for the CK series Truck and Cadillac SUV platform. In the early production years, the wiring diagrams are missing a few things and then they mature with the subsequent years. Nice thing about paying for the service at places like Alldata or Automotive they should be up to date.
thanks Renard |
04-15-2023, 09:39 AM | #205 |
one of the parts stores here has all data and can print off circuit diagrams. I have also thought of buying the all data program when I getthat far along to need it.
05-08-2023, 07:24 PM | #206 |
A quick update so I don't fall too far behind on progress.
Still working on the inside of the cab. Need to get the radio mounted. I was going to put a double din radio in the transition from the console to the dash and have the HVAC controls in the location of the stock unit. This was also assuming that the door locks and window controls were mounted on the doors. But, a while back I decided to move the controls to the center console and mount the radio in the stock location. I wanted something that fit the curvature of the dash and the size of a single din opening. I decided to use a wooden buck to form the profile I wanted and didn't look too out of place. Welded it to the dash after some fitting and cut the opening. |
05-08-2023, 07:27 PM | #207 |
Finished putting in the lower air dam and drilled the holes for the transmission cooler. Put the new grill on briefly to show the boss that there is still a bright spot down the road despite the fact that I'm talking too much time.
05-08-2023, 07:35 PM | #208 |
Finished body working the dash and started looking at the underside of the dash for the vents and the cover for the steering column. Instead of re-inventing the wheel, I'm going to use the under-dash vents from vintage air.
I cut the vent housing into two parts. The second part that would normally be for the center of the dash will be relocated to the driver's side. I will body work these to fit the dash a bit better and close of the ends and the holes that I don't need. Eventually, they will be painted to match the dash. Last edited by rnrdthefox; 05-09-2023 at 09:07 AM. |
05-08-2023, 07:46 PM | #209 |
I've been kicking the steering column cover down the road for a bit because I don't have a lot of experience metal forming from scratch. It takes me a while to get going. Finally got some ideas after playing around with some cardboard. I wanted it to only be low enough to hide things and remove the possibility of hitting it with your knee. Here is what I came up with.
The "ring" of metal or lip at the transition point of the dash will be used to attach a black leather boot to allow the column to tilt up and down. The cover over the column will be covered with the same material. Right now, the two screws are there until I confirm with the upholsterer that my plan will work ok. Then I will cut the two parts and weld them together and then to the column. Last edited by rnrdthefox; 05-08-2023 at 08:31 PM. |
05-08-2023, 07:57 PM | #210 |
Jumped around on a few small items to take them off the list.
I wanted to add an additional vent to the fuel tank since the tank came with a 3/8 fitting for a return system. I need to make a 3/8 to 5/8 attachment and ended up silver soldering the two together. I was pleased with this as I haven't done that before. Hopefully, this will eliminate the slow fueling issues with some tanks as they get full. The fuel system is now complete. Also, I painted the brake pedal and steering column while they were out. This weekend I plan to bodywork the door jambs and the beltline of the cab. The cowl area I'm still waiting on the HVAC bulkhead fitting and to figure out where the electrical harness will come into the cab. Last edited by rnrdthefox; 05-08-2023 at 08:35 PM. |
05-08-2023, 08:06 PM | #211 |
Since I'm moving the window controls, door lock controls, HVAC controller, and the heated seat modules to the center console, I need a way to attach them to the bottom of the transition in a way that is both secure and they can be removed. The master door lock and window control for the driver was the easiest and just needed metal offsets to get the height and then weld them to the bottom of the transition plate.
The only thing I could think of for the others was to duplicate the plastic mounting scheme in metal. All of this starts out in pieces that are hand filed to fit and then welded together to make an assembly for each controller. This is tedious work and I do it off and on when I have the time and energy. I still have one more holder to make for the passenger side heated seat controller. Once I have that done, I will use the template that I'm working from now and use it to mark the holes in the console transition plate. I don't want to have to fab that again too! That's all for now. Thanks for looking! Last edited by rnrdthefox; 05-09-2023 at 03:26 PM. |
05-08-2023, 11:39 PM | #212 |
fancy!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
05-09-2023, 07:46 AM | #213 |
That's a lot of work!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
05-09-2023, 08:55 AM | #214 |
nice work and thinking outside the box. it takes time to do a quality build.
05-09-2023, 09:59 AM | #215 |
Nice work you are doing!
