Old 04-04-2010, 07:57 AM   #2426
Old School Kid
Rottenwood Garage Member..Yes!
Old School Kid's Avatar
Re: Project Vitamin C-10
Very Nice!
When interests become diversified, not all can be Barrett Jackson. Budgets and Accountants get in the way.
My 65 (SOLD)
http://67-72chevytrucks.com/vboard/s...d.php?t=317013
My 51 (SOLD)
http://67-72chevytrucks.com/vboard/s...80#post3551880
Racetruck III (SOLD)
http://67-72chevytrucks.com/vboard/s...72#post4254972
Rottenwood Garage and Speed Shop.....where everything must be racy!
Gone to dark side for a while...1966 F100 in the stable
Old School Kid is offline   Reply With Quote
Old 04-04-2010, 08:16 AM   #2427
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Originally Posted by joe231 View Post
Nice work Alan!
Glad to see you are still chipping away at it
Step-by-Step
Originally Posted by Strodder View Post
Your far from being a beginner Allan. Your doing an awesone job. metal:
I might be an experienced bodyman, butI'm fairly new to stuff like making the shroud.
Originally Posted by sdailey View Post
Looking good Alan.metal:
Thanks neighbor
Originally Posted by 4dranch View Post
Dang that looks good Alan.....super work.
Appreciate that!
Originally Posted by ruffrida2005 View Post
Looks really good Alan. go ahead and bend me on up too, just to see if you can do it again. I bet you cant. Haha.
I might try another in time just to see.
Originally Posted by 65Custom View Post
Keep practicing I got to get up there for that dash extension and by the way that fan shroud looks awesome.
Thanks Kevin.
Originally Posted by Old School Kid View Post
Very Nice!
Thanks Taylor
Shannon came over and helped me get a little more done. Worked on getting the bottom cap fabbed up and fan mounted.
Here's the deminsions of the bottom cap
Done and installed
I lined up the fan assy and traced the outside of it then used this big compass to scribe a line 3/4" to the inside.
Cut opening for the fan and drilled the mount holes.
This is far as we got last night. Discovered that the upper radiator hold downs interfer with the front shields that bolt between the radiator support and the headlight mount panel.
Alan's Classic is offline   Reply With Quote
Old 04-04-2010, 11:57 AM   #2428
structures
structures's Avatar
Originally Posted by Alan's Classic View Post
Did you check yet?
Yeah I checked this morning. Surprisingly they were different and even more shocking I did have them in correctly. Which normally if something can be reversed I usually get them reversed. So I had the reverse threads (LH thread) on the Right brake and the conventional (RH thread) on the Left brake.
Back a couple of months ago when I put the brakes together I may have been paying attention but when I read your post it caught my attention b/c I just didn't remember them being threaded differently. Never hurts to double check.
Oh by the way your build thread is awesome and helpful. I've back read up to page 40 or so... like the videos.
Robert
1965 Chevy C10
http://67-72chevytrucks.com/vboard/s...d.php?t=374373
1997 Chevy K2500 6.5 diesel
structures is offline   Reply With Quote
Old 04-04-2010, 11:11 PM   #2429
Strodder
Daring to be Different
Strodder's Avatar
Came out nice Allan.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 04-04-2010, 11:54 PM   #2430
198plus
198plus's Avatar
Very nice work Alan !!!!!!!!!!!!!
198plus is offline   Reply With Quote
Old 04-05-2010, 07:25 AM   #2431
my67chevytruck
Under Construction
my67chevytruck's Avatar
nice work Alan....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 04-05-2010, 06:30 PM   #2432
64Fugly
64Fugly's Avatar
Excellent work as usual Alan.
65' C10 (working on cab currently)
06' Silverado
64Fugly is offline   Reply With Quote
Old 04-08-2010, 12:02 AM   #2433
Alan's Classic
Now you have some piece of mind. Thanks for the comments.
Came out nice Allan. metal:
Originally Posted by my67chevytruck View Post
nice work Alan....
Thanks guys, I appreciate it.
I riveted the lower supports in place.
Secured the wire
Top cap bent and installed.
The upper clamps are off center because I'm trying to decide which way to install them. I like the one on the right because it mounts more to the end of the radiator, but will have to modify the shield. The one on the left will be easy to do, but it seams like it is too close to the middle. I'm leaning to the one on the Left.
Any suggestions for the lower radiator hose? The cooler lines are out of place because they aren't hooked up.
Got the filler neck welded. It looks like it is really close to the floor, but there is room to accomendate the hose and clamp.
Started laying out a pattern for the panel inside the bed arounf the filler neck.
Oops, I messed up
I've got more pics coming next
Old 04-08-2010, 12:04 AM   #2434
Alan's Classic
Redesigned the pattern, I did not provide measurements because every install might be a little different.
More better
2.0
Old 04-08-2010, 10:38 AM   #2435
Strodder
Strodder's Avatar
Hey Allan, Your getting pretty good with cardboard. How are you at cutting out paper dolls..
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-08-2010, 10:48 AM   #2436
daverod
SSN 706
daverod's Avatar
He's like a origami master of card board.:
daverod is offline   Reply With Quote
Old 04-08-2010, 09:07 PM   #2437
tiggamonsta
tiggamonsta's Avatar
...I like the one on the right because it mounts more to the end of the radiator, but will have to modify the shield. The one on the left will be easy to do, but it seams like it is too close to the middle. I'm leaning to the one on the Left....
I say the one on the right. Assume you spent 5 yrs restoring the truck and keep it for 15 years after that. If you need to spend 8 hrs modifiying things to make it work, that is 0.45% of your time was spent making it the way you feel looks better.
tiggamonsta is offline   Reply With Quote
Old 04-08-2010, 10:29 PM   #2438
Alan's Classic
Now if I can make the metal do that good.
Originally Posted by daverod View Post
He like a origami master of card board.:
You and Dennis crack me up.
How true.
Here is another fuel neck out of a late model ford super duty. It has a round door just haven't cut the door out of the bed yet. The tube is a lot longer than the one I had.
Old 04-08-2010, 10:40 PM   #2439
TR65
TR65's Avatar
Hey Alan,
That fan shroud is so nice it makes me want to do mine over, keep the inspiration coming.
I had a tough lower radiator hose situation on my LS swap. I used a stainless tubing 90 degree elbow and two silicone adapters. It looks like you could use one elbow and two straight adapters. Just something to think about.
http://www.mandrel-bends.com/catalog/
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 04-08-2010, 11:46 PM   #2440
198plus
198plus's Avatar
This might work for your lower hose.........ID164
http://www.autobuilderschoice.biz/se...hid=016AA48096
Old 04-08-2010, 11:46 PM   #2441
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
hey alan i used the left one to mount my radiator
it seemed to work fine
but i bet the other would look cleaner and more professional
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 04-12-2010, 02:05 PM   #2442
Alan's Classic
Thanks Ronnie, that looks like it might work.
I think you are right. I was thinking about taking the easy road, but now leaning to the hard road. Why change the way I do things now.
Old 04-12-2010, 10:17 PM   #2443
Alan's Classic
It wasn't beginners luck. I was able to make another one exactly the same. My confidence has increased.
Old 04-12-2010, 10:53 PM   #2444
tommys66
[QUOTE=Alan's Classic;3916652]It wasn't beginners luck. I was able to make another one exactly the same. My confidence increased.
So does that mean some of these will be 4sale? I could really use that setup for my build.
I love the smell of lead paint!
tommys66 is offline   Reply With Quote
Old 04-12-2010, 11:13 PM   #2445
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Hey Alan remember I dared you to do it. I'll PM you my addy.
And you better not take the easy way out on the mounts. You will regret it later down the road.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 04-12-2010, 11:30 PM   #2446
Alan's Classic
I'll have to check the forum rules to see if I have to be a vendor to sell a few of these.
I remember the dare.
I moved the mounts to the outer position which brought up another issue I haven't mentioned. The radiator is offset to one side to clear the battery box.
With it being offset caused the fan to be offset. It really doesn't bother me because you have to look straight down on it to really notice. If the battery was relocated then the radiator could be centered. If not the fan could be centered on the engine with some thought.
Old 04-12-2010, 11:34 PM   #2447
ruffrida2005
I know it will bug the crap out of you Alan, but I dont think anyone would even look at it after everything else on your truck.
Once I get my Radiator I'll hit you up for getting a shroud.
Paul
Old 04-13-2010, 07:43 AM   #2448
my67chevytruck
Under Construction
Great work Alan!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 04-13-2010, 10:45 PM   #2449
tiggamonsta
You could relocated the battery behind the seat and then center the Radiator. This may also cause you to need to add a second battery behind the other seat for symmetry.
Truthfully I think it looks fine. I just want your build to go on until I can start mine. I really enjoy reading it, and seeing how you handle some of the challenges. At this rate I need you to stretch it at least 2 more years.
Old 04-14-2010, 11:50 PM   #2450
Alan's Classic
Originally Posted by TR65 View Post
Hey Alan,
TR
Thanks TR, sorry I missed your post earlier. I might have to do something like that. The water pump inlet is 1 3/4" and the radiator is 1 1/2". I will let y'all know.
By the time I get everything else done it won't be noticeable.
Great work Alan!
Stretching it 2 more years shouldn't be a problem. If I work like I worked tonight..............
Is there such a thing as writers block when it comes to working on these old trucks? I get it every no-and-then. I get out to the shop and just sit there and think. My mind gets so busy I can't focus on one thing.
So I took my welder/plasma cart apart to improve it.
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
