01-04-2021, 12:14 AM | #51 |
Re: Door Seal Opinions Please
I purchased the press on seals and they seem to be pretty nice. They need a little time to wear in.
Im in pre-fitting stage though but I have put them on and shut the door with the striker plate engaged. Tight but I think a little use and they will be ok
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
01-04-2021, 03:01 AM | #52 |
If you have watched the C/28 1967 Truck build on YouTube? you may have notice where they used seals from a 2000 Silverado with good luck. No mods. Anyone tried them? I happen to have a Silverado also and was going to pull the seal and give it a try.
01-04-2021, 01:21 PM | #53 |
I just purchased part # 17879061 from GMC Pauls and could not be happier. They are perfect. No slamming required. They indeed were redesigned to make them ultra pliable as to avoid slamming the door. Only $51 for the pair. I was about to try the Honda seals others recommend, glad i didn't. GMC Paul's service is outstanding and he is a forum member as well.
https://gmcpauls.com/Pickup.htm "67-72 NEW Push-On Door Opening Weatherstrip NEW WITH MITERED CORNERS Rated #1 Customer Favorite The 1st & #1 Supplier Of Premium Quality Push-On Doors Seals for the 1967-72 Chevy & GMC Truck Community Since 2002
Made in America by Americans |
03-01-2021, 06:16 PM | #54 |
Just got my push on seals from GMC Paul's. Went in easy and fit great. But now the door has to be slammed to close... Hoping they wear in quick.
1972 Cheyenne Super LWB, 350V8, AC, PS, PB, all original 46k survivor |
04-18-2021, 10:24 PM | #55 |
I just picked up a set of civic door seals at the pick n pull this morning. They replaced precision seals that have required door slamming for the last 3 years. The Honda seals fit perfectly without any cutting and my doors no longer require being slammed. I paid $12.00 for the pair.
Posted via Mobile Device |
04-19-2021, 09:07 AM | #56 |
This is a good video to watch on fitting your door seals so your doors close nice
. https://www.youtube.com/watch?v=Zvw5RhbhPVc C10 Show Truck Project: Test Fitting Door Seals BEFORE Painting with Altman Easy Latches Installed , Watch all the Stout Customs videos .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
01-19-2022, 06:52 AM | #57 |
im having the same issue and i have gmc pauls seals, its in my rocker area i think. thanx for the video
01-28-2022, 10:21 PM | #58 |
Anyone else use OER seals? I just bought a truck that came with them new in a bag.
