Old 04-18-2021, 02:24 AM   #1
Chevy1966
Active Member
LED Headlights - Help!
I just ordered GM factory replacement headlight and parking light assemblies for my 2002 Suburban - didn't want to mess with aftermarket units that might not fit. So now I need to figure out which LED lamp units will fit without too much hassle and won't melt my new plastic housings. So many choices out there. Any recommendations and feedback is much appreciated!
66 Custom Camper 327 AC PS PB
66 C20 292
76 C25 Sierra Classic
76 C25 Sierra Grande
76 Camper Special
77 Sierra Grande
02 Suburban - the DD
Chevy1966 is offline   Reply With Quote
Old 04-19-2021, 02:16 AM   #2
EVRLET
EVRLET's Avatar
Re: LED Headlights - Help!
9005 & 9006 from the many Amazon vendors. They’re all made in China and won’t melt housings. You’ll have the LED haters who say they are blinded but it is what it is.
Customization is what you want it to look like -- not what other people think it should look like
EVRLET is online now   Reply With Quote
Old 04-19-2021, 01:34 PM   #3
Chevy1966
Active Member
Thanks for the feedback!
66 C20 292
76 Camper Special
77 Sierra Grande
Old 04-19-2021, 03:51 PM   #4
hatzie
Moderator
hatzie's Avatar
The problem is the same as HID lamps.
The headlamp reflector in your truck is engineered for the light output and pattern of Halogen bulbs. When you change to LED without changing the reflector you give up the edges of the light pattern for a more focused beam that cuts down your side visibility and does indeed cause problems for other drivers.
The polycarbonate lens and reflective coatings in these polymer lamp housings do not age gracefully. When you sand an polish them you repair the damage on the outside of the lamp lens but not the damage on the inside of the lens and the degraded reflector.
Unlike the old GLASS sealed beam lamps you don't get all new lamps when you change the bulbs.
If you change the old reflector and lens assemblies for quality new pieces and install quality bulbs you'll be pleasantly surprised by the increase in light output from the 15-23 year old factory lamps. I occasionally get flashed with my lights on low beam with halogen bulbs and properly adjusted new lamps.
If you insist on getting LED bulbs to bandaid your old worn out lamps at least get something in the 3,000 Kelvin range. Blue spectrum light causes issues for other drivers.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-19-2021, 06:49 PM   #5
EVRLET
EVRLET's Avatar
Like I said, LED haters. I have LEDs in all my OBS trucks and this edging, light pattern, proper projectory jargon that gets tossed around is laughable. How many people do you know can get into a vehicle and say all these things about light specificity? Very few. Most people only know if the light is not aimed straight and not worried about beam edging, angle of pitch, Kelvin scale, etc.
It’s like speakers in the truck. Not many will say the frequency range is off or give some sort of acoustical analysis because they have a tuned ear.
Old 04-19-2021, 08:24 PM   #6
hatzie
Moderator
hatzie's Avatar
I don't hate LED lamps. I dislike just throwing together something that's brighter in the wrong spectrum to bandaid a failing worn out lamp.
LED bulbs work well in lamps that are designed for them. They are a poor compromise when installed in lamps designed for another light source. They cause issues for other drivers and still do not light up the road as well as a new lamp and bulb set.
If you've never had the pleasure of driving a vehicle with selective yellow forward lamps you should try it out. I've driven a Triumph Stag and an early 1970's Porsche 911 with OEM selective yellow headlamps. They're a heckuva lot easier on the eyes at night.
Old 04-24-2021, 09:55 AM   #7
kev2809
low n' slo
kev2809's Avatar
if ur set on LED bulbs I would suggest these. I swapped out all my bulbs to LED and really like the look. I went with Auxbeam 9005 and 9006 for my 02 avalanche. I did use different brand for the blinkers since the Auxbeam wouldn't function right even with resistors (signal bulbs).
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 04-24-2021, 04:30 PM   #8
71gmcC15
71gmcC15's Avatar
I have every bulb in my 07 classic led. Love them. For the headlights I am running auxbeam f16 9005 hi and lows. I have Denali headlights. I am also running 9005 led in my fog lights. I always find with leds you need to aim them down more then the old bulbs. I dont get flashed or anything. It's the people that dont aim them that blind people.
SOLD: 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie MS468 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 04-26-2021, 03:37 AM   #9
mikelom
I have Auxbeam LEDs but on my car, and I'm very pleased with them.
mikelom is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
