Old 04-19-2021, 12:11 PM   #1
Hart_Rod
Hart_Rod's Avatar
Door alignment question
My driver side door is out of alignment, (it hangs low at the rear of the door. The hinges are good and the striker is new). I need to loosen the lower hinge where it bolts to the cab so I can move the door to the rear. My main question is, can this be done without removing the fender or is that the only way? TIA
Hart_Rod is offline   Reply With Quote
Old 04-19-2021, 12:43 PM   #2
71gmcC15
71gmcC15's Avatar
Re: Door alignment question
Yes you can just take the door off.
SOLD: 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie MS468 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 04-19-2021, 01:48 PM   #3
Hart_Rod
Hart_Rod's Avatar
I was trying to avoid doing that, but looks like that is my only option.
Old 04-19-2021, 07:35 PM   #4
TKCR
TKCR's Avatar
You can do it with the door on, I did. I had taken my doors off to replace the hinge with new ones. Then of course the doors needed adjustments. I was adjusting just about everything. The hinge bolts to the fender, hinge bolts to the door and the striker bolt. I finally got it right. The doors close very nice now, and they the lines look good and flush.
Old 04-19-2021, 08:07 PM   #5
Hart_Rod
Hart_Rod's Avatar
I ended up shimming the bottom hinge about 1/16th of an inch and it worked perfect!
Old 04-19-2021, 09:00 PM   #6
TKCR
TKCR's Avatar
Old 04-20-2021, 09:25 AM   #7
72c20customcamper
72c20customcamper's Avatar
With these trucks these wrenches are invaluable. But in SAE
Mark
72 c20 custom camper Husky edition,66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 04-20-2021, 11:15 AM   #8
Hart_Rod
Hart_Rod's Avatar
Where do you purchase those?
Old 04-20-2021, 05:11 PM   #9
Amazon has them
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
1981 GMC High Sierra SWB Stepside
Board Vendors
It's scary when you start making the same noises as your coffee maker.
Old 04-20-2021, 07:56 PM   #10
TKCR
TKCR's Avatar
Wished I would have know about these. I made due, but this could have made the job a bit easier.
Old 04-21-2021, 09:05 AM   #11
Hart_Rod
Hart_Rod's Avatar
Thanks Bill!
100%
Old 04-21-2021, 10:03 AM   #12
72c20customcamper
I got them on Amazon but I also have a few box end wrenches I put a vise heated and bent them .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
