06-03-2021, 05:14 AM | #1 |
Seat Belt Restoration
Does any one know of a good seat belt restoration shop?
06-03-2021, 10:33 AM | #2 |
Re: Seat Belt Restoration
06-03-2021, 02:01 PM | #3 |
I want the webbing to be change. Parchment
06-03-2021, 07:51 PM | #4 |
The place below is supposed to be top quality but plan to pay a lot.
https://www.ssnake-oyl.com/mm5/merch...tegory_Code=RS
Kirk 72 Blazer CST 4wd highlander 66 Nova |
06-04-2021, 01:52 PM | #5 |
Thanks, All
06-25-2021, 05:37 PM | #6 |
Active Member
Try Seat Belt Planet..they do a lot of work for us at our shop
Scott My first post yea! |
06-25-2021, 07:18 PM | #7 |
06-27-2021, 07:16 PM | #8 |
2WD Jimmy
Mine are going to Snake Oyl
06-29-2021, 09:31 AM | #9 |
I thought a member on here does them maybe they’ll chime in
06-29-2021, 11:36 AM | #10 |
I just had a parchment set done by Snakeoyl. All I can say is wow.
06-29-2021, 01:43 PM | #11 |
I just sent my parchment seat belts to Ssnake Oyl. I am missing the 4 boot covers that goes behind the back seat. Any color any amount would be appreciated.
06-29-2021, 10:20 PM | #12 |
And it ws a good post
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
07-02-2021, 06:10 PM | #13 |
Active Member
Excellent! Steve (our rep)is a good guy and takes great care of us
07-03-2021, 06:17 PM | #14 |
I found pythonrestoration - they polish the buckle covers instead of paint them
I have used ssnakeoyl in the past & was unhappy with color match Will let all know how they turn out after a couple month turnaround Here's some examples Anyone know what the plastic boot is on the one seatbelt circled in yellow ? Only one of my belts has this & I do not know where I took it off at ! Last edited by 72ironmike; 07-03-2021 at 06:51 PM. |
07-03-2021, 07:43 PM | #15 | |
07-05-2021, 10:48 AM | #16 |
I had that on one of mine. Ask Ssnake- Oyl to install it on the other side. I thought it was to keep the belt from sliding down between the seat and the consul.
07-06-2021, 10:23 AM | #17 |
Harold, I lucked out and found my belt boots. If you do not find any you might look for some longer ones & cut them down. That is what pythonrestoration.com suggested I might do. I kinda like the look that they will actually cover the bolt head. Good luck. Thank goodness Blazer/Jimmies are worth so much because they are PITA !
07-06-2021, 08:30 PM | #18 |
Thanks, Mike I was thinking of doing that and found a original set.
07-07-2021, 07:14 AM | #19 | |
Here's a pic of my original cores "before" ! |
07-07-2021, 12:14 PM | #20 |
Thanks Mike for the pictures.
09-08-2021, 09:10 PM | #21 |
Here is the after !
09-09-2021, 10:41 AM | #22 |
Any chance you can share the price for the work?
09-09-2021, 01:53 PM | #23 |
^ same question (about cost of the work) as I will probably need to do the same with a set of parchment belts for my blazer project...
09-09-2021, 01:54 PM | #24 |
I used Python a couple years ago as well on my parchment belts. excellent job just took a while.
09-09-2021, 10:57 PM | #25 | |
Fronts are 105 each Rears 80 Date code tags 10 each if you want them That is with good core belts Last edited by 72ironmike; 09-10-2021 at 07:07 AM. |
