03-20-2023, 04:31 PM | #126 |
Re: Someone save this truck
Thanks guys.
With this at it's heart, there is no way I can put the two Swiss Cheese & Bondo'd front fenders back on there. Not a lick of rust, but enough bondo to mortar a retaining wall.
1971 GMC C15 Sierra Grande SWB 1972 Chevy C10 Custom Deluxe LWB 2018 GMC Yukon Denali Last edited by Thundarr; 03-20-2023 at 04:38 PM. Reason: reword |
03-20-2023, 09:07 PM | #127 | |
I just had my local transmission shop build and install a 700R4 to replace my TH350 - love the extra gear, and the 700R4 is smooth as butter. The shop owner and I discussed a GearVendors overdrive kit which he had experience with, but for roughly the same price he recommended a built 700R4. Note that I have a stock 350 engine, and not towing, hauling, or pushing through extra HP - although he claims it can handle up to 450HP with his build. I am pleased with the results.
Trio 1971 C20 350/700R4 |
03-21-2023, 11:03 AM | #128 | |
Thank you, Trio. Glad to hear it worked out for you.
1971 GMC C15 Sierra Grande SWB 1972 Chevy C10 Custom Deluxe LWB 2018 GMC Yukon Denali |
03-21-2023, 01:03 PM | #129 |
All about them K’s
You made the right choice, I’d take 100 gear vendors/th400 combos over any “built” 700r. They can’t be “built” to make me comfortable or happy when any real horsepower is involved.
The gear vendors kit is notoriously stout.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
03-21-2023, 05:53 PM | #130 |
Awesome. Thanks!
03-21-2023, 09:53 PM | #131 | |
With the foot switch control to shift it out of OD it is much easier driving around town than having to shift a 700R4 in and out of OD with the column shifter. I used a T350 with a lock up converter so it has all the same basic features as a 700R4. The only drawback I can think of is sometimes I would like to have that lower 1st gear ratio that comes in a 700R4
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-22-2023, 03:08 PM | #132 |
Well, I think I'm about to split the middle on this one.
The TH400 is getting the GearVendors for the Blue 72 Chevy and it looks like they found a 700r4 to replace my leaky Turbo 350 for the White 71 GMC. Cheaper/Easier to replace with a 700r4 than rebuild the 350 plus add GearVendors.
03-22-2023, 06:25 PM | #133 | |
If your transmission shop is as good as the one I used, you won't be disappointed in the 700R4. Be sure to report back once you have both of them done, would love to hear an update on both options.
03-23-2023, 10:47 AM | #134 | |
The Chevy is going to be a fresh build with a much more aggressive 383. So in line with 57taskforce's opinion, that TH400 is strong and will benefit from the fourth gear at highway speeds. So different applications, but I expect both are right for each situation. The bigger issue is that all this is decimating my build fund that was intended for the Chevy only. But oh well, you can't take it with you.
03-23-2023, 07:42 PM | #135 | |
I hear ya. I am spending a crap ton on mine, and it will not be worth what I put into it. But to your point, you can't take it with you, and I love the truck.
03-23-2023, 09:12 PM | #136 | |
