02-08-2023, 11:35 PM | #1 |
Quadrajet or Edelbrock Carb AVS2 ?
Quadrajet or Edelbrock Carb AVS2 #1906, 650 cfm?
On a '72 350, 441 cast heads 1.94 intakes, RV cam, Headers , 10:1 compression. In a K20 with 4:10 gears 35" tires Im running a leaky old tired stock quadrajet now . Was going to get a New built Stage 2 Quadrajet from Sean Murphy @ $639 Now started looking at the Edelbrock AVS2 #1906 @ $433. 650 cfm Busy with a new property on acreage, cutting overgrown trees and setting up my shop . just want to get a done carb. Maybe Ill go through my old carb later Thought id have fun with any opinions the Quadrajet or a Edelbrock Carb. Maybe someone is runnung that edelbrock evs2... Do you like it.
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
02-08-2023, 11:44 PM | #2 |
Re: Quadrajet or Edelbrock Carb AVS2 ?
In almost 50 years of driving and working on all types of vehicles, I haven't found a carburetor that runs better than a well-tuned Quadrajet. I like the small primaries for economy and the large secondaries for get up and go.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
02-09-2023, 01:39 AM | #3 |
I’d go quadrajet.
Depending on your intake you might need an adaptor for the avs. And maybe a fuel regulator. And possibly a heat spacer. And maybe linkage too. It all adds up. In the end both could be the same price. Quadrajet bolts on, avs doesn’t. |
02-09-2023, 06:44 AM | #4 |
Active Member
Another vote for a Quadrajet - they can take a pretty good off-road angle without flooding the engine. They used to be called the 'poor man's fuel injection"
02-11-2023, 12:20 PM | #5 |
I vote for Q-jet. I 0verhauld the one in my 72 Super & it starts & drives like it has fuel injection.
George |
02-11-2023, 03:15 PM | #6 |
Another vote for Quadrajet.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
02-13-2023, 11:57 AM | #7 |
I'm late to the vote, but also vote Q-jet. With a caveat, do NOT buy one from the company that claims to make new Q-jets off the old design. Rebuild yours or swap with a shop that will give you a good rebuild. Look at the ID number on your carb and try to get one with the same ID number.
https://www.motortrend.com/how-to/su...-part-numbers/ j
White K20 |
02-21-2023, 05:43 PM | #8 |
I love Q-jets and they sound awesome when you open up the secondary. Only caveat I would say if it sits a lot. The Edelbrocks seems to tolerate old gas and sitting better. In my opinion, Edelbrocks are also easier to rebuild.
02-22-2023, 12:35 AM | #9 |
Q Jet 100%
02-22-2023, 01:46 AM | #10 |
Another vote for the Quadrajet. I'm running a Carter AFB, but as a retired GM mechanic I'd rather have a Quadrajet.
02-22-2023, 09:34 PM | #11 |
I'm a vote for the Edelbrock. They are readily available for a reasonable price. They are easy to tune and adjust the AFR....and my Performer series has been a rock solid carb for many miles. However, I wouldnt try to adapt one to a spread bore intake.
