Old 05-18-2022, 06:47 PM   #1
C10matt
C10matt's Avatar
The Rotten Pumpkin
I've owned this truck for like 12 years now its always been the summer DD back then I never thought much about it. It was just fun and I didn't care if it got door dings. When I first got it she was a straight 6 three on the tree but the clutch went bad so the small block and 700r4 I had sitting around went in. Now days its a 350 with a little cam 221/221 on a 108, Q jet on a iron intake, some summit heads 72 cc chambers. Still got the 700r4 but the reared has been swapped to a '71 12 bolt with 3.08 gears (the slightly wider axle helped run the 8" rims out back). These days she mostly gets used for longer highway trips.
C10matt is offline   Reply With Quote
Old 05-18-2022, 07:04 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: The Rotten Pumpkin
Nice truck. Have any other plans for it?
Old 05-31-2022, 06:17 PM   #3
C10matt
C10matt's Avatar
Thanks. Not really I just use it, though at some point a front sway bar would be nice
Old 05-31-2022, 11:17 PM   #4
cwcarpenter98
cwcarpenter98's Avatar
I like it! A front sway bar is definitely a good modification. It improved the drivability of my truck a ton
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 06-05-2022, 06:19 PM   #5
C10matt
C10matt's Avatar
Thanks. Its definitely on the list of things to do
Old 06-11-2022, 06:03 PM   #6
C10matt
C10matt's Avatar
Took the pumpkin out to the Tin Butchers Scrap Drive today. Pretty good show considering the threat of rain
Old 06-27-2022, 07:28 PM   #7
C10matt
C10matt's Avatar
The pumpkin made the trip down state to the Street Machine Nationals. Tons of cool stuff great venue too.
