Old 07-23-2021, 04:08 PM   #1
colyank
Long Tail and Short Tail Question
Hi everyone I have a 1972 c10 Chevy pickup 2wd with a th350 short tail transmission that’s needs to be replaced. I was able to get my hands on a 350 tranny but it has a long tail. Am I able to switch over the end tails and put the original short tail onto this new tranny without much work? I have never really dealt or messed with transmissions before so if someone could help out that would be great thanks
colyank is offline   Reply With Quote
Old 07-23-2021, 04:30 PM   #2
Ziegelsteinfaust
Re: Long Tail and Short Tail Question
They have different shafts to accommodate the long or short shaft housing.
If you have the skill to swap shafts you can just as easily rebuild your trans too. Appartently it's not hard, but it's time consuming for the first time. My uncle used to work for GMC dealers in the 60's. He could do the whole job in 8 hours by himself. So for a average guy in the garage a 2 day job maybe more appropriate.
Also shortening a tail shaft is less then $200. Cheaper then rebuilding a trans.
Ziegelsteinfaust is offline   Reply With Quote
Old 07-23-2021, 07:57 PM   #3
BigBird05
To rebuild the clutch packs it takes special tools. Ones that you can't just rent from Auto Zone.
BigBird05 is offline   Reply With Quote
Old 07-24-2021, 01:28 AM   #4
Accelo
Accelo's Avatar
"He could do the whole job in 8 hours by himself"
Your first automatic rebuild will take days. Especially after damaging the lip seal while attempting to install them.
Don't ask how I know.
However, with some maintenance experience pulling the pump and getting down to the output shaft is doable. Sill will requires a special pliers to remove the snap ring in the recess. I believe I have the parts to make the change over to a short shaft. $35 + shipping.
Rick
Accelo is offline   Reply With Quote
