Old 08-20-2019, 09:28 PM   #176
IronCanine
I'm trying....
IronCanine's Avatar
Re: 1969 K10 CST Full Restoration
Indisputable Fact: These trucks have the best dash in the history of trucks. I feel like it's the type of thing that could bring us together as Americans. We went to the moon, we beat back the Nazis, we cured polio, we invented the corn dog AND THIS DASH. Solid resume. Let's have a beer, look at some trucks and hug it out.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 08-20-2019, 10:02 PM   #177
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I agree, I love their looks
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 08-20-2019, 10:12 PM   #178
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Love it! X2!
Old 08-20-2019, 10:17 PM   #179
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here's a pic of what we used next to OE. You're right, there is an OD difference. The OE line has a larger outside diameter. I haven't noticed that it's a problem on the firewall...but I do have to order a new 3 hole grommet as I don't seem to have a new one in our ever dwindling cache of parts.
Great follow up thanks. Better smaller OD than larger OD - I was bumbling and had what I recall was larger OD replacements that were tough to wedge through the grommets before cleaning and using the OEM stuff. Oy, why not straightforward.
Old 08-20-2019, 10:34 PM   #180
IronCanine
I'm trying....
IronCanine's Avatar
Another note on the vacuum and washer hose (and other rubber stuff) Pete...since we are sensitive to labeling on non OE replacement parts, and since it's not always practical or possible to procure correctly labeled NOS or reproduction examples, Eric has cleverly removed any labeling on our lines with a rag lightly damp with lacquer thinner. I know the windshield washer hose was made in Thailand....we all don't have to read it every 12 inches. If it doesn't say Delco or GM, plain black is our preference.
Old 08-20-2019, 10:37 PM   #181
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Very nice touch sir!
Old 08-25-2019, 03:56 PM   #182
IronCanine
I'm trying....
IronCanine's Avatar
We've had a bit of a hiccup on the core support. For whatever reason it didn't like the paint or the paint didn't like it, so poor Eric has been working on taking it back to bare metal (all while fighting a cold). Since we had the tank in, it seemed like a good idea to drill some holes and get the tank carpet in. This is the carpet we've been working on with ACC to replicate the factory original. I think it turned out great. Here's the thread where you can see how we got to this point with ACC and our install process:
http://67-72chevytrucks.com/vboard/s...=268050&page=2
Old 08-25-2019, 03:56 PM   #183
IronCanine
I'm trying....
IronCanine's Avatar
Thanks Pete!
Old 08-28-2019, 04:20 PM   #184
Yerboogieman
Yerboogieman's Avatar
Very clean and nice. I would not mind feeling how they drove when they were new.
-Taylor
1971 Chevy Suburban 4x4 Build Thread
Yerboogieman is offline   Reply With Quote
Old 08-28-2019, 05:05 PM   #185
IronCanine
I'm trying....
IronCanine's Avatar
Thanks. I can't wait to drive it. On the point of feel...when we did the Blazer, everything was new or reconditioned or rebuilt. But the detents on the column shift for that truck didn't feel near as good as this one. It's not remotely vague. The Blazer was good, don't get me wrong...but I thought it would have been better and figured, 'well this is as good as they get'...but I was wrong. This one shifts tight and lands confidently and crisply on the marks. It was a very pleasant surprise.
Old 08-28-2019, 10:30 PM   #186
Ol Blue K20
My column is sloppy too. When I looked at it I figured it was because it hadn't been lubricated in so long . They forced it out of park without being able to pull back on the lever. Hopefully the tilt I have is better.
Dale
Old 09-02-2019, 07:20 PM   #187
IronCanine
I'm trying....
IronCanine's Avatar
Travel and colds have slowed us a bit...add in the usual restoration struggles and we find ourselves farther from the end than we'd like, but inching closer nonetheless. The core support finally relented. Luckily it gave in before Eric did.
Old 09-02-2019, 07:42 PM   #188
IronCanine
I'm trying....
IronCanine's Avatar
Today Eric polished on the window stainless and I tried to tackle some odds and ends. Classic Auto Air slid farther down my list today. They'd installed a non vented blower motor...with silicone instead of a gasket. Not a huge problem to fix, but it's more time. Got a new motor and sourced a vent hose and gasket, then moved on to running heater hose. Again referenced Jim Pontious' 69 as well as other K truck pics I'd collected. Thanks to member WETOWM for the repro upper radiator hoses.
Old 09-02-2019, 07:53 PM   #189
IronCanine
I'm trying....
IronCanine's Avatar
Two more routing pics that show the heater control valve (which is the unmounted version in '69). And I like it when we complete systems. The fuel system is complete and the drive line is now complete. A/C, electrical and cooling are all very close...then it's fluids and turn the key.
Old 09-02-2019, 10:25 PM   #190
weim55
This is been a really fun thread to keep up with! Thanks for taking the time to walking through the restoration. Question on the AC : are you going to keep a stock and stay with R12??
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 09-02-2019, 10:48 PM   #191
IronCanine
I'm trying....
IronCanine's Avatar
Thanks. We considered a conversion...but we're going to stay with R12. We're trying to stay as original as possible, that includes a stock condenser... so R12 probably makes the most since (in this part of the country).
Old 09-03-2019, 02:11 AM   #192
Chulisohombre
Chulisohombre's Avatar
Great job. Two more systems down. It’s coming together nicely.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 09-07-2019, 09:43 PM   #193
IronCanine
I'm trying....
IronCanine's Avatar
Thanks. Getting there.
Old 09-07-2019, 10:01 PM   #194
IronCanine
I'm trying....
IronCanine's Avatar
Tough week. Spent two nights after work trying to install the windshield. No dice. Tried to make use of the wealth of info on here about it and almost nailed it on the first try...but one spot of the trim didn't lay down and on the second attempt the weatherstrip began to split at the corner...all down hill from there. New weatherstrip on the way, so we'll try again. Waiting on the correct condenser to finish up the A/C. Not getting it from ClassicAutoAir/OriginalAirGroup. I may post a review in the vendor section. Needless to say my experience with them has been wholly negative and I could not in any way recommend them for A/C restoration. We've 're-restored' everything ourselves. Since we've gone about as far as we can assembly wise...the old girl got rolled out and saw sun for the first time in a while so Eric could break the doors back out and prep to shoot some more color. It was nice to see that much blue out in the daylight.
Old 09-08-2019, 04:14 AM   #195
Ol Blue K20
Looking great! The color looks really good outside.
Dale
Old 09-08-2019, 08:53 AM   #196
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks for the update. Bummer on the windshield and good luck for the next attempt. You guys got farther than most professional installers can accomplish anymore. The truck already looks like a million bucks.
Old 09-08-2019, 02:03 PM   #197
IronCanine
I'm trying....
IronCanine's Avatar
Thanks Dale.
Thanks Pete. We'll get it licked.
Old 09-09-2019, 09:19 PM   #198
IronCanine
I'm trying....
IronCanine's Avatar
A little more blue. Door interiors and jambs. Rear fender wells and the correct hump. I made the mistake of letting Eric paint a '72 hump the first time when I knew we were using a '70 transfer case and shifter. Satisfaction in resolving a problem...even if it's of my own making.
Old 09-10-2019, 06:53 AM   #199
Ol Blue K20
That paint sure lays down nice and smooth with a beautiful shine.
Dale
Old 09-10-2019, 09:16 AM   #200
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I would like to invite you two over for a BBQ on the next three day weekend...I will watch you get my truck done
Impressive work. I see this truck and I want to build a 4WD bad now...thanks for that.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
1969, 4x4, cst, k10, swb
