06-13-2021, 03:39 PM | #1 |
Correct Alternator Belt for big block Chevy with A/C?
Working on a 71 402 with A/C. For what worth I'm installing a 61amp 10SI.
I pulled a 56" belt, but the A/C wasn't running and the belt may have been shorter than original. Perhaps it doesn't matter much, because the alternator bracket can take either one, though the belts aren't the same width either. I'm leaning to whatever is right but from here I can't tell what that is, what do you think? Hard to read the images, the top image for C20 doesn't distinguish between A/C & 62 AMP generator. No mention of C10 BBC, they skip to C20. The second image does provide for C10 & distinguishes for A/C & 62 AMP generator, but only for a 396. I have a 402, but guessing they're the same. Alternator Belt: 3917208 - 3/8”, 56”, though maybe a 9433770, 7/16, 59” for A/C & 62 AMP Alternator. Original images: http://www.gmpartswiki.com/getbigpage?pageid=21309 http://www.gmpartswiki.com/getbigpage?pageid=21306
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 06-13-2021 at 03:57 PM. |
06-13-2021, 04:46 PM | #2 |
Re: Correct Alternator Belt for big block Chevy with A/C?
To me it looks like 7208 for the alternator and 3772 for the compressor.
06-13-2021, 05:43 PM | #3 |
BlahBlahBlah
I don’t know if this is any help at all. Here is a picture of my alternator belt on my 71 with 402 with air. I looked it up online and it is a DAYCO OEM equivalent 45.07 in outside circumference
… … … … … … … … ... … … … … … … … … … … … Monroe Swap meet May 18-19. Mike has the same spots for the NW guys he's had forever. Lunch time BBQ at the spaces. If you have stuff to sell bring it along. If you have a question PM stllookn (Mike) here via the board. https://67-72chevytrucks.com/vboard/...d.php?t=851291 |
06-13-2021, 10:28 PM | #4 | |
Wholly smokes 45", different pulley? If anything the indent on my upper bracket is closer to the inside than where yours is bolted.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 06-13-2021 at 10:36 PM. |
06-13-2021, 11:04 PM | #5 |
BlahBlahBlah
I just did a google search to get that number, its very possible I'm wrong on the length haha. But the truck is an 80K original, and as far as I can tell its all stock except for some wiring mish mash and an extra overflow or fluid bottle.
06-13-2021, 11:38 PM | #6 |
You're not wrong on the length, sure that's not a picture of your Corvair or? Which pulley is bypassed Did you stretch it with a Sherman Tank All serious I'm no expert, but 12" plus strikes me a big difference, especially when you have the same bracket I do, you must have a 71 as well.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
