Old 05-25-2009, 08:36 AM   #1
crazyredneck
swapping from 8 to 5 lug
hey guys i just picked up a 72 parts truck for a hundred bucks from some guy. the truck has a 5 lug set up on it with a 3.73 12 bolt posi and 5 lug front spindles. i was thinking about swapping all this into my truck which is a 72 c20 so it has 8 lug all the way around the front spindles and stuff should swap right in but the rear on the parts truck is a leaf sprung rear and my 8 lugger has the coil overs. if i take the spring mounts off the parts truck can i pull some measurements, drill holes and bolt them up to my frame to use the rear and stuff?
crazyredneck is offline   Reply With Quote
