Old 08-13-2024, 08:17 PM   #1
Pinkdubai
New Member
1967 C10 Parasitic draw
I have been chasing a parasitic draw on my1967 C10 project truck and hoping the forum may have some ideas to chase. The battery drains over a few days and requires recharging. I did review prior posts on this issue, which helped me get to my current state.
Here is what I have checked so far. Reading between negative post and cable is 1.20 amps. If I disconnect the red hot wire from the battery to the inside fuse box, then the amp drain is eliminated. As a result, I started looking for short circuits inside the cab. I removed each of the fuses to try and identify the problem circuit with no change in AMP reading. I unplugged the headlight, and wiper switches with no impact as well as the brake switch.
Appreciate any thoughts on how I can chase down this issue.
Thanks,
Lance
Pinkdubai is offline   Reply With Quote
Old 08-13-2024, 10:13 PM   #2
Getter-Done
Getter-Done's Avatar
Re: 1967 C10 Parasitic draw
Do you have another Battery?
Sometimes a Bad Battery causes this issue.
The Battery may not be your issue but it is something to consider.
Another member had a Draw and it was the Battery.
Electrical problems can cause Headache's
So, something as simple as trying an
Extra Battery may eliminate some issues.
84 Chevy K-20
Old 08-14-2024, 01:44 AM   #3
lil hoodlum
lil hoodlum's Avatar
Just a thought, check the bulb in the dome light. I have heard of the bulb being blown out and still drawing amps.
1968 C10 327, 3 speed manual, LWB stock height daily driver.
1968 C20 327, 4 speed manual, LWB stock height custom camper with heavy duty leaf springs rear, 50th anniversary edition. Hoping to press into daily drive status soon.
lil hoodlum is offline   Reply With Quote
Old 08-14-2024, 09:26 AM   #4
Pinkdubai
New Member
Thanks guys, appreciate the suggestions. I believe I stumbled upon the fix. I noticed this morning my aftermarket clock guage was making a clicking sound while doing the drawdown test. Pulled out the guage cluster and the ground wire was not fully seated in the cluster. I tightened back down and now the drawdown is .08 amps, which seems reasonable I need to reassemble and attach the light and wiper switches, but hopefully this is resolved. On to the next item.
battery drain, electrical connection, parasitic draw
