Old 07-12-2022, 04:46 PM   #1
jimmiewalker
71 Rear lowering blocks
I have a 71 C-10 with coil springs. I would like to do a 2" drop with lowering blocks. What are your recommendations? Thank you.
jimmiewalker is offline   Reply With Quote
Old 07-12-2022, 06:02 PM   #2
tommy3horse
tommy3horse's Avatar
Re: 71 Rear lowering blocks
Welcome! I cannot help but theres a world of knowledge here. Maybe try a search. Good luck.
1972 GMC C1500 350/350
1965 Mustang 2+2 289 4spd, show-car
1965 Mustang Coupe 289 4spd, stoplight racer
1/2 dozen Wheelhorse Tractors
tommy3horse is offline   Reply With Quote
Old 07-12-2022, 06:28 PM   #3
Jason Banks
Jason Banks's Avatar
There's a wealth of information on the suspension part of this message board:
https://67-72chevytrucks.com/vboard/...splay.php?f=25
With that said. I used the CPP blocks. They came with the blocks new U-Bolts. Since I also used 4 inch drop springs for a total of 6 inch drop, I needed to adjust the pinion angle with a 3° shim.
The installation is pretty straight forward, basically remove(or cut) the old u-bolts off, put the spacer in and put the new u-bolts on. The new u-bolts came with nylon locking nuts, so I didn't get too crazy with the torque.
Jason Banks is online now   Reply With Quote
Old 07-12-2022, 06:33 PM   #4
Jason Banks
I want to add, after using CPP stuff, I wouldn't buy any of it again.
I'd buy everything from No Limit
https://nolimit.net/store/1967-72-Chevy-Truck-c6157532
Here's their drop blocks:
https://nolimit.net/store/Drop-Blocks-p28240706
Old 07-12-2022, 07:55 PM   #5
jimmiewalker
Thanks for all the help! Great site.
Old 07-17-2022, 10:28 PM   #6
jimmiewalker
I ended up going with the drop blocks from No Limit. Great product and super fast shipping!
Old 07-18-2022, 07:05 AM   #7
One thing to remember, with 2" blocks your U-bolt ends will drag with a flat or super low tire on 15" wheels. From what I have seen, if you have 17" or bigger your OK.
Old 07-18-2022, 08:54 AM   #8
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
That can happen as some of the U bolts that come with the block have really long threaded areas. You can cut them off and still have thread sticking out, or just get some shorter u bolts. I have 2" blocks on my truck with 15s and I would pretty much have to be on bare rim before it thinks of dragging.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 07-18-2022, 03:56 PM   #9
Yep, that's what I meant. Had a flat and drug a u-bolt on the pavement
