02-07-2023, 03:27 PM | #1 |
307 Camshaft
I have 2 bad lifters I found when doing a Q-jet swap.
It's a 1969 307, and which cam would you recommend for a staying a stock motor. Is melling a good replacement brand. |
02-07-2023, 03:39 PM | #2 |
Re: 307 Camshaft
Yes. Melling has good products.
George |
02-07-2023, 08:43 PM | #3 |
driving is in my blood
Re: 307 Camshaft
I would do anything other then a stock cam. The smallest modern grind is what I'd go with if you want stock like. Something like a lunati voodoo.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
02-07-2023, 11:40 PM | #4 |
Re: 307 Camshaft
02-07-2023, 11:42 PM | #5 |
Re: 307 Camshaft
02-07-2023, 11:58 PM | #6 |
Re: 307 Camshaft
Comp cam XE262
02-08-2023, 01:16 AM | #7 |
Re: 307 Camshaft
Stay with stock.
It's a dog, will always be a dog. Don't put a bigger cam in it and make it a mean dog. It seems to be very difficult to get the cams to live past the brake-in period. Don't forget the brake in oil and/or the stuff with extra zinc. Keep the motor above 1700 rpm for the first 20 min. To keep it from overheating during this period add extra fans in front of the radiator. Be sure to remove the heater hose when filling the block so it fills to the top with out air entrapment. Cheers. |
02-12-2023, 12:37 AM | #8 |
Re: 307 Camshaft
02-12-2023, 09:57 AM | #9 |
Active Member
Re: 307 Camshaft
When I put a new flat cam in an engine, I always use GM Lifters and have never had a cam go bad during or after break-in. The 307 used the same cam as the 350 and 400 small blocks. I would go with either a stock replacement cam or one of the "white box" 194* intake 204* exhaust, they are a little more up to date than the stock cam (1970's technology vs 1950's) and not as aggressive as a true modern cam. I have used several Summit Cams in the last two years with no issues, but as I also used GM lifters,
