02-04-2021, 06:25 PM | #1 |
Replacing rusty rocker panels
The only real rust on my 72 GMC is the rocker panels. I know the replacement panels are not very expensive, but I am not a body man by any stretch. What do you think the labor would be for a decent shop to cut out the rusty rockers and replace with new metal?
I don't want a bunch of time and effort put into the paint. Truck has original paint with a lot of patina. I don't care that the patches will show. Could be primer for all I really care. I am just wanting fresh metal in there. Any thoughts?
1972 GMC Sierra Grande (current truck) 1980 Chevy Stepside (gone) 1987 Chevy Blazer (gone) 1972 Chevelle SS Convertible (gone) 1973 Chevy Corvette (gone) 1967 Chevy Camaro (STOLEN!) |
02-04-2021, 06:30 PM | #2 |
Re: Replacing rusty rocker panels
Here in MA I have been quoted $1500-$3500 per side not including paint. The shop I will be using is the one that quoted me $3500 per side. I have seen his work and he does quality work and does it correct.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
02-04-2021, 07:44 PM | #3 | |
Thanks.
02-04-2021, 07:58 PM | #4 | |
The prices above are effing ridiculous. I'd say $500 total would be a fair price if you give the paint/body guy the rocker panels. Even at a shop willing to take on the job, I doubt it would be more than $1,000. I don't know about your area, but in North Texas there are more than a few body shop guys who moonlight.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
02-04-2021, 09:10 PM | #5 |
I could help or do it for you
WTB 71-72 Original paint Medium Red hood WTB 1972 Very nice original Parchment seat belt set |
02-04-2021, 09:28 PM | #6 |
Is there a detailed thread on this?
I have the means to do this work myself, but I’m apprehensive to start. The reason for asking is that I’ve seen some pretty elaborate bracing in place to hold the cab square. Are these needed? Last edited by custom10nut; 02-04-2021 at 09:37 PM. |
02-04-2021, 10:00 PM | #7 |
If your inner rocker panels are solid you won't need any bracing, depending on various things I'd say $1000 bucks would do it at my shop maybe a little less. The main problem when someone asks for rockers you end up [a lot of times] replacing A and B pillars and inner rocker panels along with floor patches and possibly cab mounts and also foot well panels and maybe even cab corners. The above poster is correct it is no big deal to do just the rockers but it is the hidden stuff or stuff you can not see until you tear into it.
I did a job late last year the cab had original paint but clearly need new rockers that ended up getting all the parts I mentioned above with small exceptions of B pillars and cab corners. Good luck If I can help you through it I'd be more than happy to. Jim |
02-04-2021, 10:17 PM | #8 |
You and Gigem are neighbors, right? How cool is that?
02-04-2021, 10:24 PM | #9 |
Cool! I will reach out to you to look at it when I am ready. Getting some wiring done at the moment. Thanks!
02-04-2021, 10:39 PM | #10 |
Sounds good, I'm pretty sure I have the passenger side eyebrow you're missing also
02-05-2021, 01:06 AM | #11 | |
Years ago there was a guy selling rocker and cab corner replacement DVDs here that said the cab bracing wasn't needed. What the post after yours said is quite true. Once you start you'll probably find that work on the inner is needed as well, not to mention corners and braces... |
02-05-2021, 02:35 AM | #12 |
That would be great!
02-05-2021, 08:52 AM | #13 | |
02-05-2021, 09:23 AM | #14 |
I was figuring this. I grew up in Northern Michigan and did quite a few “Rust Repair” jobs in a shop that I worked in, and what you see on the surface is just the tip of the iceberg.
I’m planning on having to replace my inner panels, as the sill plate and Door Seal lip are showing rust. I can’t see any rust from underneath, but I haven’t opened it up to see what’s inside. I’m hoping for the best case, and find that the inners are fine and I just need the the outer. |
02-05-2021, 02:59 PM | #15 |
landarts
Here is the best rocker replacement thread on this forum by a very talented fabricator. You do not need to be body and fender guy to do this, just follow the steps and you can also buy paint in a spray can color matched at Napa Auto stores that have a paint department. Even if you get a few runs that can be buffed or wet sanded to look great.
https://67-72chevytrucks.com/vboard/...d.php?t=271066
71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 69 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
02-05-2021, 10:10 PM | #16 |
OLSKOOL you sayin I am .01 percent lying? I think I can live with those numbers !!!!! LOL!!
02-05-2021, 10:26 PM | #17 |
I have instructional videos up on my youtube channel to do all of it if you want to give it a try.
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
02-06-2021, 12:50 AM | #18 | |
02-06-2021, 07:26 AM | #19 |
3500.00 per side.
puff puff pass. 7k for rockers. Love to hear what the shop name is that quoted a price like that. |
02-06-2021, 08:26 AM | #20 |
02-06-2021, 10:09 PM | #21 |
Thanks for the respect I try to help out
02-06-2021, 10:28 PM | #22 | |
