08-16-2020, 03:22 PM | #1 |
Rear bed support wire harness grommet?
Anyone know where to get one? I'm unable to locate one, perhaps using the wrong name.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-16-2020, 04:13 PM | #2 |
Re: Rear bed support wire harness grommet?
That's just a generic aftermarket firewall grommet someone used after cutting the original harness probably to wire for trailer lights . The original harness has the pass thru grommet built into the harness itself .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
08-16-2020, 05:48 PM | #3 | |
The rear harness runs from the boot connection through this grommet before it distributes to the L & R side. Both my truck have/had the grommet per the OP. Not to say you're wrong. It's a split grommet, so can probably cut something fit. The old one off my C10 is decent enough, the picture is my C20. There are similar holes that run into the passages L & R side. Neither of my trucks had a grommet on either side, though split grommets or? would be an option.
08-16-2020, 05:48 PM | #4 |
Carpe manana
I think that’s oem for the rear lamp harness and I’d like two myself.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
08-17-2020, 09:56 AM | #5 |
71Chevyshortbed402,
I took off the original one that was in bad shape and Made a new on using trailer wire. I copied the one I took off. Used the original connector so I can still plug it in. Ramiro |
08-17-2020, 03:54 PM | #6 | |
On a side, I mentioned a hole in the rear bed support for the passages up to each side of the rear lights - the holes in the panels are not 1". I don't believe GM installed grommets there, so the wires rub the panel if not accounted for. May work. The groove may lean a little thin, but the panel for the rear cross brace is approx. 1/16". https://www.amazon.com/Rubber-Gromme...15&s=hi&sr=1-3 https://www.amazon.com/Rubber-Gromme...32&s=hi&sr=1-2
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s details such as OEM identifications& part numbers, written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 08-17-2020 at 06:31 PM. |
08-17-2020, 04:14 PM | #7 |
Some leads...
Corvette Central Search (no dimensions though): https://www.corvettecentral.com/c1-5...t%26count%3d18 Corvette Central Examples: https://www.corvettecentral.com/c3-6...%26q%3dgrommet https://www.corvettecentral.com/c1-5...t%26count%3d18 Grainger Supply Search: https://www.grainger.com/search/raw-...ubber+grommets
Jim |
08-17-2020, 04:51 PM | #8 |
I just bought 10 grommets for cheap. Don't know the panel size, but they look right, and the ID & OD are correct. Will send some to Deadhead and ? if they work.
08-17-2020, 09:04 PM | #9 |
Carpe manana
Nice! Dying to know if these fit. Thanks.
08-20-2020, 05:05 PM | #10 |
Made in China 55050-K. Cut a slit and like new. Except my bed maybe - the underneath is a rough finish - I'll get one on eventually. If you want PM your address I'll send what you need.
08-20-2020, 08:38 PM | #11 |
Carpe manana
Tony thank you! PM sent. Good info here.
08-21-2020, 09:35 AM | #12 | |
Where did u purchase them? I want to replace mine before I install the wiring harness I made for the rear lights. Thanks, Ramiro |
08-22-2020, 11:39 AM | #13 |
Ebay. If you like PM your address I'll send one.
08-22-2020, 02:01 PM | #14 |
Amazing the generosity of folks on this site.
71 C-20 07 Magnum RT AWD |
08-24-2020, 05:59 PM | #15 |
08-24-2020, 06:35 PM | #16 |
I'd have to look but think that size might be in the box of grommets I bought from Summit a while back.
Summit part number Sum-890090 https://www.summitracing.com/parts/sum-890090 Usually you can find individual ones in the pull out trays above the bolts at better stocked Ace hardware stores though .
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 08-24-2020 at 07:03 PM. |
02-07-2021, 10:51 AM | #17 |
Carpe manana
Think I found some NOS examples. “RTR” is molded on the rubber.
02-07-2021, 12:10 PM | #18 |
02-07-2021, 12:41 PM | #19 |
Carpe manana
Good deal thanks for posting.
02-07-2021, 03:32 PM | #20 |
Old member
I have no idea if the right sizes is in the box but I bought a box with about 8 different sizes @ Lowes the other week. I saw them in the wiring section and figured they would be good to have. Just in case.
https://www.lowes.com/pd/Gardner-Ben...mmet/999954302
