10-17-2020, 11:25 PM | #1 |
71 C10 2wd Center Bore
Can someone confirm the correct center bore for my truck? I thought it was 77.8mm. Tried a 1/8” spacer with 3.060 hole and it was too tight. Called Discount Tire and they’re telling me it’s 78.1mm. Maybe I should just solve my issue by tubbing the rear! Thanks!
71 Cheyenne LWB - RideTech Air, zz502, 20" Torq Thrusts 16 Sierra - Bilstein 6112/5160, 33" Duratracs, Method Race Wheels, GMPP Intake, Borla Exhaust 15 4Runner - Icon Coilovers, 33" Duratracs, Pro Comp Wheels, NFABs 16 Malibu Response TXi |
10-18-2020, 01:35 AM | #2 |
Re: 71 C10 2wd Center Bore
Huh? Whaaaat?
10-18-2020, 01:42 AM | #3 |
10-18-2020, 08:15 AM | #4 |
An 1/8 inch spacer doesn’t need to be hub centric.
Can be a little loose. You guys need to learn metric. |
10-18-2020, 09:36 AM | #5 |
Proprietor of Dale's Corner
What's metric? All my measuring devices are inches.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
10-18-2020, 06:53 PM | #6 |
Went and got a new battery for my digital calipers. Apparently my hub is not very cylindrical. I got readings anywhere from 77.4 to 78.04. I suppose I should error on the large size and go with a 78.1, if I can even find one.
10-18-2020, 07:14 PM | #7 |
I didn't think these were hubcentric. I learn something new every day.
10-18-2020, 07:16 PM | #8 |
I just put on new 20incher AR's and needed no spacer. the hub hole for the wheel was 3.083 or 78.30mm
i just cleaned up the hubs with a paper flapper wheel before i tried to measure them measure the inside of your brake drum center hole if that fits then the bore needs to be close to that.
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
10-18-2020, 07:21 PM | #9 |
Thanks. Wheels and tires fit great with the static drop. With the conversion to trailing arms and bags I get minor rubbing on the inside left rear wheel well when taking left hand corners. Figured I’d try this route before having the wells tubbed
10-18-2020, 07:52 PM | #10 |
i have not gotten mine on the road yet. I went with a 275/55 -20 with stock height all the way around and hopefully i will not have any problems in the front
