03-27-2019, 06:42 PM | #1 |
Has anyone cut the lens off from a sealed beam headlight?
I had a brain fart this morning. I ordered new led headlights for my 67 and got the classic look lens. It looks great but I wondered if you could cut the front lens off of a original t3 headlight and use it on my T4 bulb back housing ? How would you cut the sealed beam in half? Diamond bit?
03-27-2019, 06:50 PM | #2 |
Who Changed This?
Re: Has anyone cut the lens off from a sealed beam headlight?
I know a guy who tried it for some reason or other back in '77. A lot of busted bulbs is all he got for his troubles. I think that the type of glass eventually cracks when it is nicked right, like safety glass does.
03-27-2019, 07:35 PM | #3 |
It's annealed glass, so you could cut it in theory. It would be pretty difficult. If you used a fine diamond blade and a lubricant like water to keep the glass cool you might be successful. Aside from keeping a straight cut, the biggest problem I can see is the heat resulting from cutting and the temperature differential that would create. That's what's going to cause the glass to break.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
03-27-2019, 07:48 PM | #4 |
I saw a video somewhere where someone took a piece of string soaked in alcohol wrapped it around a bottle of jack lit the string for a few seconds then droped it in watter and it split where the string was burning . dont know if it really works but might be worth a try
03-27-2019, 07:50 PM | #5 |
I found this thread from hotrod magazine. I want to do this now. https://www.hotrod.com/articles/1006...rs-conversion/
03-27-2019, 09:26 PM | #6 |
20' Daredevil (Ret)
Looks like an interesting project with a chance of shattering some glass as noted above. Depending on your desired result, consider this: The beam pattern is determined by the bulb, the reflector, and the lens. The T3 lens fluting is different than the fluting on an E-code H4 headlamp, so the beam pattern will be altered. No telling what the end result will be. If you go ahead with this, will you post before & after pics? Good luck, it'll be interesting to see how it turns out!
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
03-27-2019, 09:29 PM | #7 |
I agree, the lens is made for the lights to work properly and with that being said I probably won't do this but it would be cool on my truck because I have such a stock looking truck with no modern upgrades appearance wise these will stand out a bit and if the t3 lens was on the H4 case it would still be stock appearance.
03-27-2019, 09:39 PM | #8 |
That is a good thread. My truck still has both t3 headlights in it. I have not drove it at night but I did have it in the driveway at night with the headlights on and they are very yellow and dim compared to my 2006 truck. I want to leave the t3’s in for the original look but I know I will be driving this at night and it will not be good visibility. Wish they made a t3 upgrade.
03-28-2019, 12:56 AM | #9 |
20' Daredevil (Ret)
If you haven't already done the relay mod, it's worthwhile. Full voltage to the headlamps makes them brighter. Add some good E-codes like Cibies and you'll have excellent safe lighting for those night drives.
03-28-2019, 01:04 AM | #10 |
I had a pair of 7'' halogen headlamps, I left on a '67 Suburban for years. When I took them off, the lenses came right off. They were originally epoxied on I guess.
For my purpose, I glued them back together with Blue RTV [what I had around]. I used one for a week until new headlamps came in from RockAuto. The other fell off my tailgate and broke. I think they were Sylvania. Look at the edge. If it's not a solid glass piece, it may separate easily. The Tungsten lamps are sealed, and if air gets into the ''capsule'' the filament burns out quick. But halogens had a small quartz-halogen capsule inside the reflector housing that is self-contained. Of course, it won't say T-3 on the outside.
03-28-2019, 01:12 AM | #11 | |
03-28-2019, 09:14 AM | #12 |
Chewey; what lights are those?
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
03-28-2019, 10:10 AM | #13 |
They are from octane lighting. They are super nice with the LED's. Much brighter than sealed beams.
03-28-2019, 11:00 AM | #14 |
Who Changed This?
I second this. The relay mod made a much bigger difference than I expected. $30 well spent.
12-03-2020, 10:37 PM | #15 |
Well I'm going to give this a shot hopefully over the Xmas break. I ordered some diamond wheels today and I think I know how I'm going to cut them to Get a straight cut. I'll post here when I do this and we'll see how it goes.
12-04-2020, 08:56 AM | #16 |
I would try to cut it with a tile saw.
12-04-2020, 10:54 AM | #17 |
Subscribed, I want to see how this goes
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
12-04-2020, 12:04 PM | #18 |
Try Googleing hid conversion those guys split open many types of headlights by putting them in the oven warm up the glue that hold the lens on and separate them
12-04-2020, 09:15 PM | #19 |
I Wil post the results. I will try it on a different bulb first. I may try a few ideas. I just hope something will work. If you have any links to videos or such where ppl have split these bulbs please post them.
12-06-2020, 01:03 AM | #20 |
At the body shop.
My ancient Cibie lights fell apart.
Replaced with some Hella H4 and a relay harness way better light output
" That didnt make it any newer " " Dont antique the equipment " |
12-06-2020, 02:00 PM | #21 |
Subscribed
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
12-06-2020, 03:16 PM | #22 |
Proprietor of Dale's Corner
Subbed to watch too.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
12-06-2020, 03:37 PM | #23 |
Also subscribed
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
12-06-2020, 04:21 PM | #24 |
What is the relay harness mentioned by a few fellows?
1972 Chevy Custom Deluxe Highlander, owned 34 years. 1970 GMC Sierra Grande 2500, unrestored, original. 1970 Chevy K10 Short Wide-bed, working on restoration.. 1967 Chevy K10 Short Stepside, unrestored original. 1969 GMC CST (Longhorn) 396, buckets, unrestored. 1995 GMC K2500, 65,000 miles, 454. |
12-06-2020, 04:55 PM | #25 |
Who Changed This?
You connect the relays to the battery and the headlights. When you turn on the headlights, power goes through the relays to the headlights instead of roundy-round from the battery to the headlight switch, dimmer switch and then to the headlights. Much less voltage drop. Here is a thread I made to show the difference from stock to using the relays. I bought them from LMC.
http://67-72chevytrucks.com/vboard/s...d.php?t=782071
