01-29-2021, 11:12 PM | #1 |
Help with Axle / Differential identification.
Looking for information on the differential information for this 12 bolt. We just installed a 430 hp crate motor to a TH350 Transmission and want to investigate a gear package. You opinions, experience and advice is appreciated.
01-30-2021, 10:40 AM | #2 |
Re: Help with Axle / Differential identification.
Look for the factory numbers on the front of the RH axle tube.
01-30-2021, 10:46 AM | #3 |
The Older Generation
Here are the charts. http://67-72chevytrucks.com/vboard/s...d.php?t=578793 Posts #8 & 19 show the locations for some of the code stampings. LockDoc
01-31-2021, 11:39 AM | #4 |
You need to know the installed gear ratio to identify the carrier series.
And if it's a posi or not. Even with the stamping code it's not a guarantee it what you will have. I would pull the cover and count the teeth and see what's there. Truck 12 Bolt Series 2 = 2.73 - down (smaller numerically) Series 3 = 2.76 - 3.42 Series 4 = 3.73 - up (larger numerically) |
01-31-2021, 12:03 PM | #5 |
Your best bet is to remove that rear cover and see what's actually in there. Unless you've owned the truck since it was new, there's a chance it's been swapped. And any rear end deserves fresh gear oil if you're going to put 430 HP into it.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
