11-13-2022, 10:55 PM | #226 |
Re: 2wd swap
Those pics aren't telling as far as set-back isdues.
What are you seeing?
11-16-2022, 02:01 AM | #227 | |
At the body shop.
Re: 2wd swap
We're behind it. J said cut it til it fits. I guess
" That didnt make it any newer " " Dont antique the equipment " |
11-30-2022, 01:33 PM | #228 |
At the body shop.
Re: 2wd swap
Rear back half ?
Sure dad I got that to. Local hot rod shop bent these up for us. Should lay pinch with a 30 inch rear tire. Got axles coming with a 4.75 and 5x5 bolt pattern, like the hubs we have. Should be a roller soon.
11-30-2022, 03:33 PM | #229 |
Re: 2wd swap
Dang.... Back half now? Project creep....
11-30-2022, 04:28 PM | #230 |
At the body shop.
Re: 2wd swap
The apache syndrome.
A patch here Another patch there.
11-30-2022, 04:53 PM | #231 |
Re: 2wd swap
LoL. I'll have to add that one to my list.
11-30-2022, 08:35 PM | #232 |
At the body shop.
Re: 2wd swap
Dad used to describe the Tule fog as apache fog. Apache here and there..
12-05-2022, 05:30 PM | #233 |
At the body shop.
Re: 2wd swap
Nice shocks need a nice bracket.
12-05-2022, 09:37 PM | #234 |
Re: 2wd swap
Clean.
12-06-2022, 12:47 PM | #235 |
At the body shop.
Re: 2wd swap
12-06-2022, 02:55 PM | #236 |
Re: 2wd swap
12-06-2022, 07:48 PM | #237 |
At the body shop.
Re: 2wd swap
Worth every cent so far.
This should lay pinch with a 30" tire.
12-07-2022, 12:15 AM | #238 |
Re: 2wd swap
Stronger as well.
12-07-2022, 02:13 PM | #239 |
At the body shop.
Re: 2wd swap
Strong maybe, but it's low enough if it gets hit.
All the energy will miss the bumpers.
12-09-2022, 11:24 PM | #240 |
At the body shop.
Re: 2wd swap
Axles/Weld Friday night.
All while I'm stuck at work
12-15-2022, 11:11 PM | #241 |
At the body shop.
Re: 2wd swap
That's it.
Back half engaged
12-18-2022, 01:54 AM | #242 |
At the body shop.
Re: 2wd swap
Housing is ready for links
01-07-2023, 12:41 AM | #243 |
At the body shop.
Re: 2wd swap
Some 295 40 -18
Nitto 555 Gonna get a 245 45 up front
01-07-2023, 03:41 AM | #244 |
Re: 2wd swap
P... P... P... P... Pudgy....
01-07-2023, 03:09 PM | #245 |
At the body shop.
Re: 2wd swap
That's the plan.
Caliper brackets came today
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 01-07-2023 at 05:29 PM. |
01-23-2023, 07:36 PM | #246 |
At the body shop.
Re: 2wd swap
I'm beginning to wonder about these bag plates.
Crossmember is 3-1/2 The bag plates are 2-1/4 Or do I even care?
01-24-2023, 10:08 AM | #247 |
Re: 2wd swap
I like the bottom plate/mount flush w/the tubing if possible. I contemplated re-working my PB lowers but left them alone in the end.
01-25-2023, 02:03 PM | #248 |
Junior Member
Re: 2wd swap
Any chance you can share the files for the uca bracket? Thanks
01-25-2023, 09:34 PM | #249 |
At the body shop.
Re: 2wd swap
Sure could. It's designed around a 1.5" pancaked crossmember Dm an email address.
01-26-2023, 07:49 PM | #250 |
Re: 2wd swap
Nice work. What width are those wheels ?
81 short step. |
