Old 11-10-2021, 01:30 AM   #1
smupser
Active Member
Steel wheel info
Have a 73’ jimmy and 74’ blazer that I picked up this year. Both completely stock except wheels. I want to restore both to use factory steel wheels for use with dog dish caps. Does anyone know what the exact sizes where from the factory? Were they 15” or 16” and do they cross reference with the k/10 trucks? I’ve also seen the aftermarket steel wheels that use the factory dog dish caps but are wider. Anyone know who makes them?
smupser is offline   Reply With Quote
Old 11-10-2021, 08:54 AM   #2
ky-donzi
Re: Steel wheel info
They were 15” from the factory, I do not know the width.
I bought one wheel from “the wheel smith” out of California. I only ordered one to check fitment and quality. Before it was delivered I found a set of CUCV wheels that I bought. So the wheel smith wheel will be my spare.
It isn’t a complete factory replacement, but it is very nice looking and available in different widths
http://thewheelsmith.net/
61 GMC 4x4 1-ton flatbed 4bt cummins, ranger od, sm465, np 205, d60F, d70R 4.11 10,000 ramsey PTO winch.... SOLD
73 k5 gm crate 350-265 / sm465 / np205 3.73 posi
ky-donzi is offline   Reply With Quote
Old 11-10-2021, 11:19 AM   #3
smupser
Active Member
Thank you. I would assume that the ones from a K/10 would probably be the same then. Was it the 3/4 tons that used a 16” diameter?
Old 11-10-2021, 11:56 AM   #4
ky-donzi
To my knowledge yes, 16” didn’t become standard on half tons until 88....at that point with the use of different offsets on the 4x4 front axles and larger brakes it became necessary
Btw if you look at the wheel smith wheels you will see they don’t have the 4 slots that are between the flat lug part of the wheel and actually air holding portion of the wheel, other than that they are really close to the originals
